Any recommendations on an exhaust system or exhaust(flowmaster/magnaflow/etc)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco_26, Apr 24, 2017.
  1. Apr 24, 2017 at 2:12 AM
    Taco_26
    Taco_26 [OP] New Member
    2017 TRD 4x4 Tacoma
    Any suggestions on an exhaust system or exhaust? (flow master/magnaflow/etc) greatly appreciated
  2. Apr 24, 2017 at 5:16 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Magnaflow.. FTMFW. :popcorn:
    Also performs best with a TRD air filter!
  3. Apr 24, 2017 at 5:18 AM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
  4. Apr 24, 2017 at 7:49 AM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
  5. Apr 24, 2017 at 7:52 AM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    Banks cat back
    Had one on my 05
    Have one for my 14 but cant install yet had surgery on arm
  6. Apr 24, 2017 at 8:01 AM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    Running a Flowmaster super 44 muffler
  7. Apr 24, 2017 at 8:05 AM
    hoski_in_sd
    hoski_in_sd Well-Known Member
    San Diego
    2017 Tacoma SR5 4WD DCSB
    IMO Magnaflows sound a lot better than Flowmasters on a v6 application. I put 14" Magnaflows on my truck and they sound very clean, and aren't as loud as you might expect given the amount of cat's on the 3rd gens. It sounds good when you get into the pedal but not excessive in the cab. If you aren't sure on the muffler, when you have it done ask the installer to hear a couple different options on it before they weld it up. Any exhaust shop should be able to set the muffler on the existing pipe and let you hear it to get an idea of what the finished product will sound like.
    Whatever muffler you choose, One major point I'd make with the 3rd gen specifically, is to make sure you replace from the Y pipe back when doing the exhaust. The factory Y pipe is a bad design that's almost partially crushed when you look at the cross section of it, its more of a box than a circle. Additionally, there is an overlap inside the Y pipe where the pieces were joined at the factory that effectively reduces the size of the pipe, thus unnecessarily restricting the exhaust flow.
    Taco Addiction likes this.
  8. Apr 24, 2017 at 8:16 AM
    Blazingbluesport
    Blazingbluesport Well-Known Member
    The OC!
    2016 TRD Sport 4x4 double cab.
    I had a Magnaflow. Too loud and dronie for me. Got a TRD exhaust. Perfect.
  9. Apr 24, 2017 at 8:31 AM
    tacouk
    tacouk Well-Known Member
    David
    Truckee, CA
    Ram 1500 Rebel, (sold) 2017 DCLB TRD Sport 4x4
    I have an MBRP cat back. From what I've seen on here, you just need to pick from: Magnaflow, MBRP, or the TRD.
  10. Apr 24, 2017 at 9:03 AM
    gamason
    gamason Well-Known Member
    Randy
    2017 F-150 Eco Beast
    Just my personal opinion, but anything less than a V-8 sounds terrible with an aftermarket exhaust. 4 cyl sound like they have a fart can attached, V6s' just make a lot of noise for no other reason than to be noisy. To each his own though, I hop you find what you like.
    BlakeM, taco2010trd and smitty99 like this.
  11. Apr 24, 2017 at 9:05 AM
    MattScatt28
    MattScatt28 2017 Seattle Mariners AL West Champs!
    Snoqualmie
    Spintech
    Z7Xtreme and tacouk like this.
  12. Apr 24, 2017 at 9:06 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I'm starting to feel the same way. And the extra noise just reminds you of all the extra revving and shifting that this engine does. It's really starting to get on my nerves, and I might put the stock exhaust back on.
    Anybody wanna buy a Magnaflow catback?
    boynoyce likes this.
  13. Apr 24, 2017 at 9:06 AM
    Hagendazsss
    Hagendazsss Well-Known Member
    San Diego, CA
    2017 3.5 4x4 sr dcsb
    I have trd exhaust and it sounds nice. Not too loud not too quiet
  14. Apr 24, 2017 at 9:12 AM
    skale240
    skale240 Well-Known Member
    Arthur
    San Diego, California
    2017 Magnetic Gray TRD Off Road DCLB
    SR5 Grill Plastidipped OR Rims
    I agree. When you roll up to my house it's not too loud but still has a step up on the OEM exhaust.
  15. Apr 24, 2017 at 9:15 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    This.
    Save your money and buy something that is actually a functional upgrade.
    rdjr17, taco2010trd and Hank Heel like this.
  16. Apr 24, 2017 at 9:44 AM
    tacouk
    David
    Truckee, CA
    I know someone with a Spintech in a 2nd gen and it sounds pretty good. Definitely quieter than the MBRP.
  17. Apr 24, 2017 at 9:52 AM
    2017OR
    2017OR Well-Known Member
    2017 TRD Off-Road
    TRD exhaust, Pro Grill, Access Tonneau cover, TRD Pro wheels, BumperShellz, Pro shift know, Yota LED grille lights
    I have TRD exhaust. Sounds good. But as others have said, maybe spend dollars on functional upgrade unless it matters to you. If so, TRD is a good option. Not too loud no drone.
  18. Apr 24, 2017 at 10:01 AM
    UTAH GetMeTwo
    UTAH GetMeTwo Well-Known Member
    Cave Creek, AZ
    21 4RUNNER ORP KDSS
    I have the TRD exhaust as well. Can drone at times at highway speeds, but not nearly as much as a Magnaflow. It's subtle at idle, but has some balls when you get on it. Overall I'm very happy with this exhaust. There's a sweet spot between 2500-3000+ RPMs that sounds so sexy. Can't help but mash the gas to get it there every time!
  19. Apr 24, 2017 at 10:05 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    You have literally the best username ever.
    UTAH GetMeTwo[QUOTED] likes this.
  20. Apr 24, 2017 at 11:24 AM
    MadDaddy
    Many & varied
    I have a Magnaflow. It was absurd at first, but settled down after the 1,000 mile break in period.
    bobrown14 likes this.
