Any plumbers here?
Discussion in 'Garage / Workshop' started by anotherreject, Mar 6, 2019.
  1. Mar 6, 2019 at 11:10 AM
    anotherreject
    anotherreject [OP] Well-Known Member
    Wife wanted the bathroom redone, i didnt...so the bathroom is now gutted down to subfloor and studs.
    Old tub/shower was a one peice fiberglass unit, went to put in a standard bathtub and hit a snag.
    The drain for the old bathtub is 2 inches above the level of the floor, too high for the new tub.
    The existing drain pipe for the tub is fucky, it goes over top of a floor joist, so the tub drain kits from home depot/ lowes wont even work
    Anyone have suggestions before a professional gets called? 20190305_183831.jpg 20190305_183816.jpg
    Kolunatic likes this.
  2. Mar 6, 2019 at 11:15 AM
    Bigdaddy4760
    Maner
    Poolville Texas
  3. Mar 6, 2019 at 4:20 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Can you move tub to the right?
    Slashaar likes this.
  4. Mar 6, 2019 at 4:25 PM
    tcjacado
    tcjacado Well-Known Member
    What is moving it the right going to do??
    It's still to high and the joist is still in the way.
    The holes need to be lowered 2 inches.
    Remove the pipe and coupling it lower. It's the cutting into or coring a hole on the joist I am unsure about. If so may need framing for support
  5. Mar 6, 2019 at 4:27 PM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Clawfoot tub
  6. Mar 6, 2019 at 4:28 PM
    TacoMTga
    TacoMTga Well-Known Member
    Brian
    Notch the floor joist, it will be fine as long as you keep it as small as possible.
  7. Mar 6, 2019 at 4:32 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    add more sub floor
  8. Mar 6, 2019 at 4:32 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    Do what TacoMTga said
  9. Mar 6, 2019 at 4:36 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Build a platform for the tub to sit on.
    The joist can only be notched if it is close to the load bearing support, notching the middle 1/3rd section is a no-go. Even if you are in the green zone to notch, I'd recommend reinforcement by sandwiching it in metal stock.
    Pickeledpigsfeet and tcjacado like this.
  10. Mar 6, 2019 at 4:42 PM
    03coma
    New Jersey
    2015 DCSB TRD, SR5
    If you don’t want to notch it drill a hole.
    tcjacado likes this.
  11. Mar 6, 2019 at 4:44 PM
    tcjacado
    Thanks for confirming post #4 guys :thumbsup:
  12. Mar 6, 2019 at 4:46 PM
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    Ugh. Way more headaches than you want to deal with. I installed one in my house.
    This would only be acceptable under certain circumstances and peramiters.
    Not recommend.
    Depends on where or if you have walls underneath, and the size, location of the hole and your floor joists. It can be done though. Drilling a hole in the floor joist is possible but it looks like you would have to move the whole stack, Tee and vent down.
    This is an option if you want to scotch the tub up off the floor.
    If it were me, I would cut all that out and figure out drilling a hole in the floor joist if it is feasible.
    Pickeledpigsfeet and wilcam47 like this.
  13. Mar 6, 2019 at 4:47 PM
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    What size are your floor joists?
    This may help you
    "Keep the hole at least 2 in. from the top and the bottom if it's a dimensional lumber joist. The hole cannot be larger than one-third the depth of the joist, so the maximum hole size for a 2Ă—12 joist (actual size 1-1/2 x 11-1/4 in.) is 3-3/4 in."
    Pickeledpigsfeet and SC4333 like this.
  14. Mar 6, 2019 at 4:49 PM
    tcjacado
    @23Skidoo how can we over engineer this??
    wilcam47, 23Skidoo and 03coma like this.
  15. Mar 6, 2019 at 4:55 PM
    03coma
    New Jersey
    2015 DCSB TRD, SR5
    You got that right JaCado, doing this for over 20 yrs. drill a hole or notch it, that’s hows it’s done. The only problem I see is that his trip lever waste is all glue so no adjustability. Might have to cut it out and get a Gerber trip lever waste kit, all depends on how the tub lays out.
  16. Mar 6, 2019 at 4:55 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Well then go help him out. I’m a licensed plumber here and asked for a reason . :popcorn:
    scocar, Biscuits and tcjacado[QUOTED] like this.
  17. Mar 6, 2019 at 4:55 PM
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Wait, where is your P trap?
    synaps3 likes this.
  18. Mar 6, 2019 at 4:56 PM
    tcjacado
    And I asked what good it would do:notsure:
  19. Mar 6, 2019 at 4:56 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    I wouldn’t notch it. Drilling a hole would be better. In center area of joist but I’ve been away from “cottage” plumbing for decades
  20. Mar 6, 2019 at 4:57 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Chicago pd on
    Yota_Ivan likes this.
