Any one else do this? Oil change funnel trick.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by snefo, Nov 7, 2017.
  1. Nov 7, 2017 at 7:27 AM
    snefo
    snefo [OP] Well-Known Member
    I have always assumed that other people use this trick when changing oil, but I have never heard it mentioned. IMG_0902.jpg I discovered that an empty one quart oil bottle screws into the oil fill port of my 2016 4 cyl. I don't think the threads are an exact match but it is very secure after screwed in. Makes it super easy to dump in a 5 qt. jug of oil.
    I keep the funnel in a gallon zip lock freezer bag in between oil changes.
  2. Nov 7, 2017 at 8:00 AM
    phsycle
    phsycle Well-Known Member
    CA
    Yep, I do the same thing. I'm too cheap to buy a $2 funnel. :)
  3. Nov 7, 2017 at 8:02 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    LOL, this is exactly what I did, too. Great minds think alike!
  4. Nov 7, 2017 at 8:08 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    :thumbsup:
    yep, I've done it forever, just figured everyone did it as well.
  5. Nov 7, 2017 at 8:47 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I have done that many times when I did not have a funnel.
  6. Nov 7, 2017 at 8:52 AM
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    Interesting. All my empty's get filled with old oil for recycling though.
  7. Nov 7, 2017 at 8:55 AM
    CJREX
    CJREX Well-Known Member
    Georgia
    And don't forget the sheet of aluminum foil under the oil filter.
    Form the foil into a funnel to catch the dripping oil.
  8. Nov 7, 2017 at 9:14 AM
    shakerhood
    Southern Ohio
    I usually use a couple rags or paper towels.
  9. Nov 7, 2017 at 9:20 AM
    BuddyS
    BuddyS Well-Known Member
    Maryland
    2013 TRD Sport 4x4 MT
    I use a plastic jar from yogurt/sour cream or whatever... just rest it under there and let it catch whatever drips down, then pull it out when you're wrapping things up.
  10. Nov 7, 2017 at 9:23 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    I'm apparently rich. I have a funnel. Its also easier to use said funnel to drain my drain pan into the empties.
    shakerhood likes this.
