Any issues running 1 degree shims + axle shim for extra lift?
Discussion in 'Suspension' started by junkyarddogg, Nov 15, 2022.
  1. Nov 15, 2022 at 8:39 AM
    junkyarddogg
    junkyarddogg [OP] Well-Known Member
    New Jersey
    2021 TRD Off Road
  2. Nov 18, 2022 at 11:06 AM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    Yes and yes. I would measure when the gas tank is full and then when its empty to get a more accurate difference in height first.
    You could even go with 1-2 degrees of an axle shim. Some of the tacomas out there came from the factory with a small axle shim.
    Then you could try a carrier bearing drop. But really what you should do is watch a few utube vids on how to measure the axle angles to see what it looks like as well.
    I would also examine your tires. Are they worn, have they been recently rebalanced?
    Have the U-bolts been re-torqued?
    Not in any particular order for any of it.
    junkyarddogg[OP] likes this.
  3. Nov 18, 2022 at 12:03 PM
    junkyarddogg
    New Jersey
    2021 TRD Off Road
    Thanks, im gonna take more measurements. Im wondering if maybe the ground isnt flat which may cause differences. Tires have 7K miles, they are the original.
    JFriday1[QUOTED] likes this.
