Any interest in a swaybar disconnect?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gman36, Feb 22, 2018.
  1. Feb 22, 2018 at 8:56 AM
    gman36
    gman36 [OP] Well-Known Member
    San Diego, CA
    2018 Cement DCSB OR
    My buddy and I are thinking about building a single sided disconnect for the 05+ tacomas. ANy interest? How much would you pay? The price would probably be cheaper if you send your stock swaybar back as a core charge.
    Amchuge, Carter'sTaco and Tac0maSteve like this.
  2. Feb 22, 2018 at 8:58 AM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    Thought about it at one point but removing the sway bar completely is just sooo much better.
  3. Feb 22, 2018 at 8:59 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Right here. I had my sway bar off last week and was loving it. I'm thinking about removing it permanently, but the ability to quick connect it for twisty roads would be good?
    I am wondering though. What is this one sided part? I thought that the bar end would snag the CV boot with only one side disconnected?
    gman36[OP] likes this.
  4. Feb 22, 2018 at 8:59 AM
    gman36
    San Diego, CA
    2018 Cement DCSB OR
    Thats what I did as well, but Im thinking about the guys who think they may roll over instantly on road. ;)
    tonered likes this.
  5. Feb 22, 2018 at 9:01 AM
    gman36
    San Diego, CA
    2018 Cement DCSB OR
    It would be similar to this. Some guy made it for FJs but it never went into production. I would have a different endlink though, Im not a fan of this design.
    ChadsPride likes this.
  6. Feb 22, 2018 at 9:02 AM
    TacoRD16
    Houston, TX
    For a stock Tacoma disconnect sway bar link would be ideal since the suspension ins't as stiff. I believe you may have trouble with just a single disconnect with the bar and CV boot but haven't tested to confirmed.
  7. Feb 22, 2018 at 9:07 AM
    D2.
    D2. Well-Known Member
    Dan
    Nova Scotia, Canada
    2009 Tacoma - access cab 4x4 2TR-FE
    Cruise Control install. Intermittent wipers Hood lights Bed Lights Sliders 3" lift 886's on Billy 5100's Icon AAL 285/75 R16 Falken Wildpeak AT3W's
    I'd be interested based on price point.
  8. Feb 22, 2018 at 9:15 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    On the surface, that looks good, but. . .
    In that design, given how close that bolted connection is to the main torque section, it is going to see some huge moment loads. There are a lot of elements there (bolt bending / shear, welds, and base material) that would have to be incredibly beefy for long term use. Not to mention some tight tolerance holes.
    IMVHO, you'd want that connection to be a lot closer to the joint or do a spline and collar?
    Just making some hopefully helpful pointers?
    Tharris242 likes this.
  9. Feb 22, 2018 at 9:18 AM
    SDTaco4x4
    SDTaco4x4 Well-Known Member
    San Diego
    2016 Black TRD Sport 4x4
    Pardon my ignorance, but why would you not want the swaybar connected, or not have it at all?
    tonered likes this.
  10. Feb 22, 2018 at 9:21 AM
    gman36
    San Diego, CA
    2018 Cement DCSB OR
    That's what we are looking into as well, but also still keep it rather inexpensive!
    tonered[QUOTED] likes this.
  11. Feb 22, 2018 at 9:22 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    I want one and would pay a fair amount for it. Please build, and or let me test it for you. Lol. Thanks.
    Carter'sTaco likes this.
  12. Feb 22, 2018 at 9:24 AM
    phsycle
    phsycle Well-Known Member
    CA
    Flex
  13. Feb 22, 2018 at 9:25 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    We have rounded driveway curbs like these:
    Going over them at any angle tosses us side to side with the sway bar. With it off, you can barely feel it.
    It is the same with speed bumps, potholes, and just about anything off road. Also, it lets the suspension function independently. So, if you are close to getting hung up, esp with the limited travel up front, you have a bit of extra margin.
    TacoRD16 likes this.
  14. Feb 22, 2018 at 9:27 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Good stuff! It is a challenge.
    Anything that you can do to increase the bolt spacing will help.
  15. Feb 22, 2018 at 10:01 AM
    SDTaco4x4
    San Diego
    Interesting. Thanks.
  16. Feb 22, 2018 at 10:45 AM
    TacoRD16
    Houston, TX
    I like the idea and I believe there is a market for quick disconnect sway links for Toyotas but unlike the jeeps folding up the sway far enough out of the way will be the biggest challenge. The jeep sway bar tucks closer to the body so tire turning wont cause rubbing while the Tacoma bows out that will cause interference with CV boot, UCA and tires. If you could figure out the sway bar then maybe it would all work. An idea if you could cut the sway bar in half weld 2 plates one on each and have a locking mechanism like the T-locks on swing out tire carrier (Obviously a lot stronger than the lock in the picture) to lock and unlock.
    Jeep
    Tacoma
    All food for thought...
  17. Feb 22, 2018 at 10:45 AM
    CrawlerJunkie
    CrawlerJunkie Active Member
    1999 Regular cab, 2017 dcsb TRD OR manual
    99: only thing that hasn't been touched is the engine 17: bone stock....for now
    Would something like this work? I had a set on my 1st gen, not 100% fimilar with the newer gens. They are from wabfab...
    phsycle likes this.
  18. Feb 22, 2018 at 10:47 AM
    phsycle
    CA
    Sweet, I had a set of those on my old 4Runner from Wabfab. Quality product.
  19. Feb 22, 2018 at 10:52 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Sway bars reduce body roll/flex. Good for handling, bad for articulation. Generally for sportier cars, you want to balance the front sway bar for stiffness versus understeer. Bigger sway bars can improve turn-in, reduced body roll, etc. Too thick up front and you'll get more understeer.
    On stock OR suspension I, personally, would not remove it as the OR suspension is so boat-like already. However on my firmer Icon shocks, I'm debating on removing it.
    tonered likes this.
  20. Feb 23, 2018 at 4:07 AM
    House Forsaken
    House Forsaken Well-Known Member
    Paul
    2015 Tacoma TRD Off Road (Traded) 2017 TRD Off-Road (Traded) 2018 TRD Off-Road
    ^This!!
