Any ideas or advice? Start problems.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PackCon, Dec 25, 2016.
  1. Dec 25, 2016 at 6:10 AM
    PackCon
    PackCon [OP] Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Bought my 2013 DCLB TRD Sport used December 2015 with 27k miles on it.
    From the time I bought it I've had intermittent start issues. The truck will continuously crank but not start for about 3-4 seconds.
    I noticed this happened only every once in a while and usually when temps would be different in the morning vs the night. Happens usually when I leave work at night after the truck has been sitting for 8 hours. Parkinglot at work is flat, not slanted.
    Took truck into dealer and they found the following codes:
    P1603 Engine Stall History
    P1604 Startability Malfunction
    P1605 Rough Idling
    Said they could not find a clear issue to fix.
    I had my oil tested my last change by Blackstone Labs. They found some fuel in the oil but minimal. Said it was normal if I do a lot of idling, I don't. I do put a lot of miles on the truck though. I am 14 miles shy of 50k miles so 23k this year so far.
    My warranty expires at 60k, I'm concerned I might be looking at an expensive problem and want to know what I can do to rectify the issue prior to the warranty ending.
    Anyone have any ideas on the issue or how to do some diagnostics?
    Should I test the oil again?
    Thanks and Merry Christmas.
  2. Dec 25, 2016 at 6:13 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Take it to the dealer and have them fix it under warranty. I don't understand what you are having trouble with
  3. Dec 25, 2016 at 6:15 AM
    PackCon
    Connor
    According to them there is nothing to fix.
  4. Dec 25, 2016 at 6:45 AM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    Can you take it to another dealer? I'm not sure what's causing the problem with your truck but there's obviously an issue if it's throwing codes. For the dealer to just shrug their shoulders is not acceptable.
    Hunter7 likes this.
  5. Dec 25, 2016 at 6:50 AM
    1Shifter
    Jeff
    09 PreRunner
  6. Dec 25, 2016 at 7:04 AM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    T
    Take it to a different dealer. Call corporate if needed
    1Shifter likes this.
  7. Dec 25, 2016 at 7:08 AM
    1Shifter
    Jeff
    09 PreRunner
    Agree with you Gainman , always good to have a paper trail regarding issues that pop up under warranty.
    TexasWhiteIce likes this.
  8. Dec 25, 2016 at 7:09 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Have you done a compression test? Have you checked fuel pressure before and after the regulator? What do you spark plugs look like? These are things I would check. You will eventually find your smoking gun.
  9. Dec 25, 2016 at 7:18 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    It's under warranty so I'd push the dealer to do everything in their power to fix the truck. To me it sounds like a wiring issue due to changes in temp that you noticed. Maybe electrical connection expends or contracts.
