Any high mileage 4 cylinders?
Discussion in '4 Cylinder' started by Samurai49, May 5, 2013.
  1. May 5, 2013 at 9:24 PM
    Samurai49
    Samurai49 [OP] Member
    Al
    Casper,WY
    Who has a high mileage a 4 cylinder? How high? What's you experience? Auto or manual?
  2. May 6, 2013 at 4:56 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    143k and counting on my 05. It's a manual. Very few problems. Clutch slave cylinder, drive shaft U-joints (factory joints are sealed on a 5 lug), and sway bar bushings are all I've replaced aside from the mods I've done. I've just changed the fluids regularly and spark plugs according to the maintenance schedule. About every 5k I run some Seafoam through it. I use Mobil 1 or AMSoil in the engine, AMSoil and now Redline in the tranny, AMSoil and now conventional in the rear end (added mechanical LSD), the Toyota premixed coolant in the radiator, and OEM spark plugs. Honestly the biggest problem I have is getting my tires balanced right on the aftermarket wheels.
    Currygoat and TEEIAM like this.
  3. May 6, 2013 at 5:01 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    Toyota 4 cylinder...high mileage?? No such thing as a high mileage 4 cylinder toyota...just a regular 4 cylinder toyota.
    :D
    With that said....
    My 1997 3rz 2.7L, manual 5 spd...189,XXX...replaced a radiator, rack and pinion...and thats it....other then preventative maintenance.
    SOLID motor.
    Bicycleman and austin2009 like this.
  4. May 6, 2013 at 5:40 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Better yet, I bought a 94 five lug, new, five speed, 4 cylinder. When I sold it at 217k, it still never had the drive shaft or valve cover removed. Rear axle, including rear brakes never replaced, (I replaced ONE wheel cylinder after breaking off the bleeder screw when changing brake fluid), never removed the radiator or water pump, ball joints and tie rods were original, as was the alternator. What caused me to get rid of it was a transmission popping out of gear.
    I never had a vehicle as cheap to maintain, and probably never will again...However, I did do PM's including yearly changes of gear box fluids.
    I did have to change the coil once, due to a rusted bracket causing a damp day miss...
    If they would sell the pre-95 style truck again, I would certainly buy another 4 cylinder, but this time in 4 wheel drive.
    davidstacoma likes this.
  5. May 6, 2013 at 5:48 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    My wife's old 96 had almost 170K when it was bought back. Brakes, tires, AC condenser, the exhaust manifold..all I can think of and she bought it near 100k.
    She had one before that, not sure of the year but it was pre-Taco. Bought with 100 and ran to 200k. I think she did a major brake job and tires. The bed was rusting out as well. A friend of hers at work bought it and put a wooden bed on, ran it near 300k and it only needed a radiator..was still running when he dumped it.
    In high school a mutual friend's buddy had 250k on his (early 80's model). It rolled into the harbor near us and was almost totally under for 20 minutes. Started right up after he had it winched out.
  6. May 6, 2013 at 6:55 AM
    coma98
    coma98 Well-Known Member
    zach
    ky
    98' built 2rz turbo
    Lowered 4/5 Stage 4 clutch. Fidanza flywheel. W58 trans, arias pistons, pauter rods, arp mains an head studs, cosmetic gasket, T3/t4 15psi and more coming!
    I'm at 251k on stock internals on a 2rz. Never been apart. It runs as good now as it did when it had 150k. Its not been drove easy since I've had, it had 150k on it when I got it. Still don't burn a drop of oil or make a noise one. I've kept the oil changed every 3k. Its been ran at the 1/4 mile track every summer since 2009. Its indestructible! So far I have a k&n intake, maf calibrator, stage 2 clutch an short throw shifter.
  7. May 6, 2013 at 8:21 AM
    cowboy50
    cowboy50 Well-Known Member
    Dexter,MO
    05 Tundra 4x4
    206,000 on my 01'. Spark plugs, AFE filter, manual tranny, just put 16's on it. Don't want to brag too much, it seems to always haunt me later. Newest one I have had since 92. Had a 90 that I bought with 70k on it in 1996 drove it till 2006 had 220k showing but drove it for a year without a speedo. Sold it to a guy that was shipping them to Mexico and the British Honduras, the only thing I had to do was one clutch and a syncraniser (sp) between first and second, kept popping out of gear. Didn't drive it hard but did use it like a truck should be used.:)
  8. May 6, 2013 at 9:03 AM
    lock
    lock Well-Known Member
    greg
    N.W.OHIO
    tacoma
    I have a 09 access cab 4/auto with 101,000 miles. Thats not high but its a good start.
  9. May 6, 2013 at 9:04 AM
    Large
    Large Red
  10. May 6, 2013 at 9:06 AM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    This is the base model stick shift Tacoma today, that I bought brand new in January of 1996. :)
    I've never owned such a reliable vehicle except for the 1988 Toyota pickup truck before it. I'm anal about oil changes and driving a vehicle easy and it has rewarded me with 17 years and 158,000 miles of flawless service. It's had seat covers on it for 17 years so the original upholstery is pristine.
    I have a 2012 now so it's for sale in the 1st gen market section.
    Brice and Hartford like this.
  11. May 6, 2013 at 11:01 AM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    The body of my '96 Taco is just short of 144k. (Not very high for a 96, I know.) Just did a rebuild not even 30 miles ago, because the dude that owned it before me absolutely trashed it. I bought it like that, rebuilt it with my best friend. I don't understand how the previous owner could beat the shit out of this truck so bad. Hey, I don't mind though- now I have a flawless (mechanically, not aesthetically) truck. I have no doubt that this truck will serve me well in the years to come.
  12. May 6, 2013 at 11:21 AM
    tooter
    Greg
    Los Angeles
    That's something I'll never understand...
    ...why people abuse the machines which serve them. It just doesn't make any fucking sense. Might just as well take money out of their own pockets and set fire to it. :confused:
  13. May 6, 2013 at 11:42 AM
    ABA180
    East Bridgewater MA
    Even my older cars that I had in college I took care of, and some really were pieces of crap. Reason? If I break it, that means I have no way to get around. All the more important now that I have 2 jobs and a parent that needs help.
  14. May 6, 2013 at 11:47 AM
    Milota95
    Milota95 Mall Crawling Specialist
    Qrampage
    B.F.E
    97 SX Single Cab V6 ~ 95.5 SX Single Cab 4c ~ 81 Pickup
    Driven Safely
    227,000 on my 95:D
  15. May 6, 2013 at 11:52 AM
    coma98
    zach
    ky
    98' built 2rz turbo
    I had a 95 for a while an when it turned over 300,000 miles I sold it, I had repainted it an did all body work, sharp truck but the people who bought it beat the hell out of it an trashed it also. It was a nice truck i should if kept it.
  16. May 6, 2013 at 11:54 AM
    gastoverat
    gastoverat Active Member
    Fortson Georgia
    96 Tacoma Lx 4x4
    245K on my 1996
  17. May 6, 2013 at 11:56 AM
    Fenwick1993
    Not Fenwick
    Chesapeake, VA
    Me neither... why beat the shit out of your ride? What are you going to do without it? I can understand being rough with a truck (ie, offroading, driving hard,) but I can't understand downright neglect- no maintenance, letting severe problems ride, etc.
    But hey, I can't complain too loudly- if people didn't treat their vehicles like crap, I'd have never gotten my Taco. :D
  18. May 6, 2013 at 4:31 PM
    theGastone
    theGastone New vehicle/Tacoma *****
    Ian
    Leesburg, VA
    '97 Standard
    '97 2.4L 4 Cylinder 265xxx miles on the original motor. Not a single major replacement under the hood. The original muffler rusted off a few days ago though! Just replaced it. lol
  19. May 6, 2013 at 4:52 PM
    coma98
    zach
    ky
    98' built 2rz turbo
    You got me beat! Lol
  20. May 6, 2013 at 5:00 PM
    Skinny Rogers
    Skinny Rogers U know fish can hear u thinking just b4 u sneeze
    Lance
    NC
    10 taco
    A guy at my work had a 98 I believe and I know it has 325 on it. It's 5 spd 5 lug. It's his driver to keep the miles off his tundra. I know this isn't a tacoma but I work with another with 340 on a tundra. They both commute daily to work.
