Any good suggestions on removing clear rock protector sticker thing....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NoLove, Feb 25, 2020.
  1. Feb 25, 2020 at 6:58 PM
    NoLove
    NoLove [OP] Member
    2010 Ext. Cab 4x4 TRD
    Can anyone tell me how to remove this ugly thing off of my fender flare without damaging the paint and without making more of an eyesore of it then it already is..
    This is the clear protective coating on my rear fender flare that has lost it purpose and any aesthetics may have once had. I am afraid I will mess things up worse trying to take it off but it is UGLY. Any help or suggestions would be appreciated.
    Thank you in advance.
  2. Feb 25, 2020 at 7:06 PM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    Wash the area real good, heat gun and peel, 3m eraser wheel, cleaning wax and buff!
  3. Feb 25, 2020 at 7:10 PM
    19QUICKSANDTACOTRD
    19QUICKSANDTACOTRD OUTLIER
    19 DCSB TRD SPORT
    I second that and elbow grease
    buckmaster243[QUOTED] likes this.
  4. Feb 25, 2020 at 7:22 PM
    Silentshredr
    Silentshredr Well-Known Member
    Chuck
    16 DclbOr4x4
    Heat and Wd-40 that you probably have around
  5. Feb 26, 2020 at 4:22 AM
    NoLove
    NoLove [OP] Member
    ok, thank you for the reply i will give that a try.
  6. Feb 26, 2020 at 7:44 AM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    Used a harbour freight heat gun and some wax and tar remover to get mine off.
  7. Feb 26, 2020 at 9:59 AM
    BuschWacker
    BuschWacker Well-Known Member
    Calgary, Alberta
    2015 TRD Sport DCLB
    There is a trick to removing the chip film without leaving a lot of glue behind. Warm it up with a heat gun, get an edge or corner started and stretch it parallel with the panel. The more you can stretch it, the better. If you pull it directly away from the panel at 90 degrees, it usually leaves more glue behind and a bigger clean up afterwards. It’s basically the same way that those 3M command strips, come off of a wall so easy. I hope that makes some kind of sense.
    JGO likes this.
  8. Feb 26, 2020 at 10:45 AM
    Turdyota3000
    Turdyota3000 Well-Known Member
    Round da corner
    07 dcsb trd off-road
    Icon 2.5's, TC, yackety shmackety....
    BD5C2497-36E6-4AFD-AB8B-A266CACCF6F1.jpg Yours look brand new lol....
  9. Feb 26, 2020 at 10:57 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    In addition, something that might help is a scraper with a plastic razor blade. I never knew there were plastic razor blades until a few years ago and there are a lot of uses for them.
    Greenedmc and Turdyota3000 like this.
  10. Feb 26, 2020 at 11:28 AM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Hair dryer or hot sunny day. It’ll peel off pretty easily. The adhesive underneath is a bit of a pain to clean up. Wd40, cleaner wax, goo gone, ect will work.
  11. Feb 26, 2020 at 12:37 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    I've never seen that happen before, what are you guys doing with your trucks?
  12. Feb 26, 2020 at 12:51 PM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    Maybe it’s just me but I love how that plastic sticker looks. I wouldn’t dare take mine off
    Turdyota3000[QUOTED] likes this.
  13. Feb 26, 2020 at 1:31 PM
    Turdyota3000
    Round da corner
    It’s just you... :rofl:
    JeRoc28, steveo27, honda50r and 2 others like this.
  14. Feb 26, 2020 at 1:32 PM
    Turdyota3000
    Round da corner
    Using it like the Tacoma gods intended.
    pdaddy and Rick's 2012 like this.
  15. Feb 27, 2020 at 4:37 AM
    NoLove
    NoLove [OP] Member
    Awesome, will give this a try tonight. I appreciate the help.
  16. Feb 27, 2020 at 5:33 PM
    K-DubTaco
    K-DubTaco Well-Known Member
    Ken
    VB
    ‘25 TRD Off Road
    A0E0357E-A8B4-4F63-8746-5EB3BBC4E9C5.jpg I just removed mine a couple weeks ago. I used a heat gun and plastic squeegee. I’d be careful using the 3m eraser wheel on the plastic flares. It could burn the paint right off and gouge the flare.
    Kolter45 likes this.
  17. Apr 5, 2022 at 8:43 AM
    MonolithMotors
    MonolithMotors Member
    SE Pennsylvania
    2006 Indigo Ink PreRunner
    I am starting on this project and hit a snag. How do I remove this black trim piece at the front and bottom of the bed? I removed the rear clip from below the bed without any problems. There is a second clip under the bed toward the front that has a large square body on the inside of the bed. I tried a few different things; poking, prying twisting but no luck. Any suggestions?
  18. Apr 5, 2022 at 11:15 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Perhaps a (kitchen) pan scraper. Don't hold me to the accuracy of the name, but i believe that they are for scraping burned on food from the bottoms of pans.
  19. Apr 6, 2022 at 10:29 PM
    Dcallicoat
    Dcallicoat Member
    Dalton
    2005 blue Toyota Tacoma Pre-runner
    Roof rack, tires wheels, lift, suspension
    Where would you find another one to replace it after you take it off?
  20. Apr 7, 2022 at 1:37 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    58741-04110
    58742-04110
    Double check on that but pretty sure thats them
