Any good step by step tutorials on paint chip repair?
Discussion in 'Detailing' started by patzed, Jun 17, 2021.
  1. Jun 17, 2021 at 1:32 PM
    patzed
    patzed [OP] Well-Known Member
    Pat
    SE Wisconsin
    2019 TRD OR Cement DCSB
    I've got a few paint chips, mostly on the hood and one on the tail gate i can't get right. Had one on the edge of the rear passenger door that filled in nicely but the rest of them I can't get to match well.
    Any tips? Also my first time doing paint chip repair so my expectations may be a bit high.
  2. Jun 17, 2021 at 2:26 PM
    gorram
    gorram Well-Known Member
    2016 Limited
    These should give you some good tips:
    Lookup Dr. Colorchip too for a more DIY friendly method, should be many videos on it.
    igno1tus and patzed[OP] like this.
  3. Jun 18, 2021 at 9:04 AM
    rfranklin1
    rfranklin1 Well-Known Member
    2021 Tacoma TRD Pro
    Dr. Colorchip is a great DIY option. They color match for your vehicle. No clear coat to apply - just layer their product to fill the chip. It's a permanent solution and you can polish over it if needed. If you're the video type, Anthony from The Rag Company has a great walk through on his YouTube channel.
    https://www.youtube.com/watch?v=9Akhpiw_x8w
  4. Jun 18, 2021 at 9:10 AM
    patzed
    Pat
    SE Wisconsin
    Wish i would've seen this earlier..i already bought the toyota color match pens
  5. Jun 18, 2021 at 9:17 AM
    rfranklin1
    2021 Tacoma TRD Pro
    No worries. Before using Dr. Colorchip, I would use the touchup pens, but I would apply the paint to the chips with a dental gum stimulator (you can get packs of them on Amazon). Make sure you clean out the chip really well (use the same process in the video I linked). From there, I would put some paint on a paper plate, dip the tip of the gum stimulator into the paint, and dab it into the chip. If it's deep, you may have to layer it a little. Once you get close to it being level, finish it off using the same method with the clear paint. Takes a while, but it will look better than if you were trying to cover it up with the small brush in the touch-up pens. If you have the stuff, you could give it a very light sand and polish when you're done, too. Just give it a couple days to make sure it's good and dry before you do.
    igno1tus likes this.
