Any fit issues with 215/85R16 on stock wheel?
Discussion in 'Wheels & Tires' started by Stereo, May 29, 2011.
  1. May 29, 2011 at 9:16 AM
    Stereo
    Stereo [OP] Well-Known Member
    Laura
    Colorado
    2003 DLX Xtra Cab SR5 4WD M/T 3.4
    OK, once the laughter dies down...
    I'm considering a 215/85R16 A/T tire on a stock 7" wheel for my 2003 4WD Taco. The tire specs say it will fit that wheel. Are there any non-cosmetic issues with that size tire on that size wheel?
    I need a higher-ply tire to carry a full-size load (pop-top camper) and I'm looking to do it as inexpensively as possible. The narrower tire will be better in snow, is lighter in weight, is D-rated for lower cost (vs. 235/85R16's which only come in E in the tires I'm looking at), I assume will give me better gas mileage than a wider tire, and it's much less expensive. It's also closer in size to stock 265/70R16 than the 235/85R16's.
    Thank you for your help.
  2. May 29, 2011 at 2:22 PM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    No. Do it, take pictures, and post them on the forums.
  3. May 29, 2011 at 2:23 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    you mean 255/85/16s right????
  4. May 29, 2011 at 2:28 PM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    She is wanting 30.5", skinny tires.
  5. May 29, 2011 at 2:41 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    That is a size used on dual rear wheel work trucks and should have a high weight load rating.
    They are of course heavy so keep that in mind too.
  6. May 29, 2011 at 6:23 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    i believe a bigger tire circumference would be worse on mileage than a wider footprint?
  7. May 29, 2011 at 6:27 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Tough to say. It would be like a balancing act between weight and contact patch... I'm not sure which one makes more of a difference :notsure:
  8. May 29, 2011 at 8:39 PM
    Stereo
    Laura
    Colorado
    Yep, I do need a higher-ply tire for the camper I'll be carrying. I can get the 215's in D. The 235's only come E in the brand tires I'm considering.
    Weight-wise, the 215 D-rated tires area about the same as the 265/75R/16 A/T standard ply I've got on now.
  9. May 29, 2011 at 8:59 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  10. May 30, 2011 at 2:41 PM
    Stereo
    Laura
    Colorado
    Yep, I'm not anxious to see my mileage when I put that puppy on there, but it will only be on for the summer months - at least until I retire... if I ever can. ;) Thanks for confirming the ability to go with the 215. I'll post pictures if you promise not to tease me too badly. :D
  11. May 30, 2011 at 9:31 PM
    Stereo
    Laura
    Colorado
    After re-reading the threads, I wanted to respond that the diameter of the 215/85R16's are only 0.2" smaller than stock. The tire sizes that are under the recommended maximum 3% difference in diameter to stock 265/70R16 are:
    215/85R16 -0.17%
    235/80R16 +0.64
    245/75R16 -0.45
    255/70R16 -1.8
    275/70R16 +1.8
  12. May 30, 2011 at 9:47 PM
    KenLyns
    Belly of the Beast
    If speedometer/odometer accuracy is what you are after, look at the "Revs Per Mile" spec on TireRack, which is an actual measured value that takes into account sidewall flex.
    As an extreme example, BFG Commercial T/A Load Range E in 215/85R16 gives 696 revs per mile. Geolander Load Range D gives 676 revs per mile - 3% difference on the same numerical size.
  13. May 30, 2011 at 10:11 PM
    Stereo
    Laura
    Colorado
    Hmmm. Thanks for pointing that out. It's amazing that two like-size tires could be that different.
