Any cons to having ECT power on all the time?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by In2Ndo, Oct 9, 2016.
  1. Oct 9, 2016 at 2:55 PM
    In2Ndo
    In2Ndo [OP] Well-Known Member
    California
    MGM 2021 Tacoma TRD OR
    Hello everyone.
    Since driving with ect power always on seems to be a more aggressive kind of driving.
    Could it have any negative effects in the long run when it comes to engine and transmission longevity ?
    I'm planning in making my 2017 DC sport 2WD my last vehicle. And I don't want to be driving around like an old lady. but also don't want to make the truck run like is a race car all the time. If that is what ect is trying to do.
    Thanks in advance.
  2. Oct 9, 2016 at 2:56 PM
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Fuel economy will suffer potentially but that's it.
  3. Oct 9, 2016 at 3:06 PM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    I have never used the ETC - your 6cyl does not have enough power? You have tried with and without? If this will be your last vehicle, driving conservatively is probably a good idea, at least some (most) of the time.
    Junkhead, nv529 and Modesto Tacoma like this.
  4. Oct 9, 2016 at 3:22 PM
    SamChieftan
    SamChieftan Well-Known Member
    Dallas, Texas
    2016 TRD OR AUTO 4x4 Super White
    Interior LEDs, Truck Mat, Door sills
    I use ECT all the time. I have 17,000 miles on my Taco. My fuel mileage INCREASED 3mpg since turning it on. I live in Texas and drive 60 miles one way to work mostly on the Interstate at 75mph. I am sure there will not be any problems by running the ECT. EPA requirements require all manufacturers to make their engines low power for emissions.
    You should be fine using it all the time. Plenty of people on this forum do it all the time; that's what convinced me to try it. Now my low power Taco; is drivable.
  5. Oct 9, 2016 at 3:25 PM
    avitaco
    avitaco Well-Known Member
    A
    2017 DCSB 4x4
    I hate the low end power of this engine/trans config. Its like a lie saying at redline it gets 278... who drives a truck at such high rpm. Ive been thinking about running the ect in town to make it drive like it should have. I basically look at it like like an ECO button.
    auskip07 likes this.
  6. Oct 9, 2016 at 3:28 PM
    In2Ndo
    California
    I've used both. The truck has a how to drive it learning curve compared to a regular engine. And I think I'm getting to the end of it. in other words. at first I didn't like it. but than I started to listen to the engine and learning the transmission behavior. Now I'm very happy with it.
    My issue is I live around Los Angeles and there is always traffic around here. So with ect off it can some times be frustrating running in and out of traffic. And most of my driving is street driving. Not that the fwy is any different now days. :-(
    I can live without using ect all the time. I think I've learned the gas pedal play that this engine requires. but I was wondering if the quick fix of using ect would shorten the life of the mechanics.
    hooliganrick, Huang618 and JK like this.
  7. Oct 9, 2016 at 3:40 PM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    Not sure either - time will tell....
    I hear you about "learning" the new engine. It is definitely different than anything else I have driven.
    I never owned an auto trans before and I think this helped me with this truck, in some strange way.
    I also do mostly stop and go street driving.
    One thing I really love about this truck and something I have never seen mentioned is the "engine braking"-almost like driving a stick if you are in tune with the gas pedal.
    t2c, RonGrfx, Takemehome678 and 2 others like this.
  8. Oct 9, 2016 at 5:13 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    do you push the button every time you drive or have you figured out a way for it to default to ON at startup?
  9. Oct 9, 2016 at 5:18 PM
    HalfWayThere
    HalfWayThere Well-Known Member
    SLO, CA
    2016 DCSB TRDOR 4x4
    You didn't mention if you have had the TSB done. Make sure you get the transmission TSB done and then evaluate using ECT mode all the time.
    I can see both sides. I would guess you would get lower mileage around town with ECT on. Not sure about the highway.
  10. Oct 9, 2016 at 5:54 PM
    Smokestogi
    Smokestogi Active Member
    NJ
    2016 TRD Sport
    Without an ECT option, I would have gotten rid of the truck. With ECT on all the time it's barely enough for me to be content.
  11. Oct 9, 2016 at 5:59 PM
    ArnieSea
    ArnieSea Well-Known Member
    Arnie
    Salish Sea, WA
    2016 Double Cab TRD Sport 4X4
    Blazing Blue, with full tech package, Tow Package, & Tonneau cover.
    I'm much happier since I had the TSB done. The tranny now shifts when I would expect it to. Much smoother starts. Averaging 18-19 MPG mixed driving. I only use the ETC when towing or mountain driving. I have the TRD Sport.
    shift96 likes this.
  12. Oct 9, 2016 at 9:02 PM
    In2Ndo
    California
    I took the truck to the dealer last week. They kept it most of the day.
    The trans fluid was physically checked and it was fine. And no TSB required.
    With a mix of Street and fwy I get 19 to 23 per gallon. This last tank.. has been all Street one quarter tank left and is showing an avg of 16.5
  13. Oct 9, 2016 at 9:03 PM
    SamChieftan
    Dallas, Texas
    Yes, I need to push the button each time I start my Taco. I have also had the tranny TSB done as well. I had considered trading my Taco, but the TSB made a HUGE difference for me the past 2000 miles, and learning to turn on the ECT makes a TON of difference, and I love my Taco again.
    I have tried tons of highway driving with the ECT off. If your posted speed is 60mph, you will probably get great gas mileage with ECT off. My posted speed is 75mph. The Taco REALLY REALLY struggles to maintain that speed. If it is windy it will constantly shift from 5th to 4th to 5th .... 30 times in a 60 mile drive. The ECT turns off the atchinson cycle, which never would get used often unless on flat ground with no wind.
    The engine has a TON of power you just need to get it up past 3000 rpm otherwise it has no power.
    EDIT: Forgot to mention, some other mechanics said they used tech stream to check if there was an ON/OFF setting for the ECT in the ECM. No one has found a setting yet: so the ECT button must be pushed after each start. Also all major manufacturers test high limits on their engines. There is nothing wrong with running ECT all the time except that it perhaps creates more emissions.
  14. Oct 10, 2016 at 3:42 AM
    vinkon235
    vinkon235 Well-Known Member
    vince
    steubenville oh
    2016 white tacoma trdor access cab
    opt7 cree series fog lights busman aux relay box viair 450c oba opt7 fluxbeam led headlights
    Personal preference when it comes to driving style.Using ect mode shouldn't alter longevity of drivetrain at all.
  15. Oct 10, 2016 at 6:33 AM
    kerrdog
    kerrdog Well-Known Member
    2016 trdor mgm
    I dont use ECT unless I am towing something. I hear alot about it not having enough get up and go. I notice mine will take its time getting up to speed if I let it but giving it about a half inch more pedal it gets up very satisfactorly. My advice is use your foot and give it a little more pedal and it will do what you need it to do.
    HiBillyMaysHere and Sgt.Tee like this.
  16. Mar 10, 2017 at 4:47 PM
    BirminghamTaco
    BirminghamTaco Member
    Birmingham, AL.
    2016 SR5 White 2.7 DblCab Taco
    I use the ECT on the highway all the time. I need the extra power for the 2.7 4cyl.
    u wish u could ride likes this.
  17. Jan 11, 2019 at 10:54 AM
    tractng
    tractng Well-Known Member
    I just picked up a 2019 Gen 3 4 banger to replace my 2008. For towing around 1200 lbs, do I use ECT and put it in 4 gear on highway speeds?
  18. Jan 11, 2019 at 10:59 AM
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    There was a member who rigged up some thing to flip it on every time - it was something where when you went from P to R or something it triggered something to switch ECT on. I think initially he had some reliability issues with it working all the time, don't know if it was all sorted or not.
  19. Jan 11, 2019 at 11:01 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Placebo effect
    Check out a few YouTube vids were the 0-60 is pretty well the same with or without it on!
    County 37, geo8866, Paul631 and 2 others like this.
  20. Jan 11, 2019 at 11:01 AM
    OdiN1701
    Colorado
