Any advice on replacing my AC compressor?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aerose91, Mar 11, 2025.
  1. Mar 11, 2025 at 9:37 PM
    Aerose91
    Aerose91 [OP] Well-Known Member
    Connecticut
    07 TRD Sport 4x4
    The AC unit may be the only thing on a car is have never worked on. My compressor locked up and I got junk in the lines, so it has to be replaced. I bought an OEM Delphi compressor and OEM expansion valve. I was going to remove them, then take the truck to the shop to have them clean the lines and evaporator, then replace. Any advice on stuff I may be missing? I appreciate any help.
  2. Mar 12, 2025 at 5:33 AM
    eherlihy
    eherlihy 2009 Access Cab TRD Off Road
    Florida or Massachusetts
    2009 TRD Offroad Access Cab in Silver Streak Mica
    Replace the condenser too. If the compressor grenaded, there are bits of stuff in the pipes that you do not want to get in the evaporator coils.
  3. Mar 12, 2025 at 6:25 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Had a similar issue on a different (Toyota) car a few years back. For what an A/C shop would charge, bought the compressor and condenser on RockAuto, vacuum pump and A/C gage set from Harbor Freight and was still considerably cheaper than taking it somewhere to have it repaired.
    If you're somewhat mechanically inclined, this should be doable. Watch a couple of videos, it's really pretty straightforward.
  4. Mar 12, 2025 at 6:44 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
  5. Mar 12, 2025 at 8:39 AM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    Is the condenser what is mounted to the inner firewall, which requires the whole dash to come out?
  6. Mar 12, 2025 at 8:39 AM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
  7. Mar 12, 2025 at 10:59 AM
    eherlihy
    No. The condenser is where the high pressure refrigerant is cooled. Physically, it is mounted in front of the radiator. I used a Denso 477-0839 - which at the time (2023) was about $110. This Denso unit is used on Lexus vehicles and is a direct replacement for the Denso unit that Toyota installed, but it has a filter/drier that is replaceable, without requiring that you replace the whole condenser.
  8. Mar 12, 2025 at 11:13 AM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    OK, whew. You saved me a panic attack
  9. Mar 12, 2025 at 11:14 AM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    Is that not something that can be flushed with the lines?
  10. Mar 12, 2025 at 11:51 AM
    eherlihy
    no, it cannot.
    Aerose91[OP] likes this.
