Anti theft devices
Discussion in '4th Gen. Tacomas (2024+)' started by TacoRancher, Sep 23, 2024.
  1. Sep 23, 2024 at 8:04 PM
    TacoRancher
    TacoRancher [OP] Well-Known Member
    Houston
    2024 Trail Hunter, 2022 Lime PRO (RIP)
    Have you all heard of Ravelco or Igla as anti theft devices that sort of work like two factor authentication to start your truck? Trying to get a feel for what works best with our trucks.
  2. Sep 23, 2024 at 9:16 PM
    miqie
    miqie Well-Known Member
    On a related note.............for insurance purposes, does the 2024 have any type of basic anti-theft installed as standard?
  3. Sep 23, 2024 at 9:38 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Ravelco requires hacking up your wiring harness to splice in the module to a number of different systems and is not easily reversible. Any warranty issues that could be blamed on the affected components are an easy denial for service.
    IGLA is a software based solution owned and based in Russia if that is a concern of yours. It offers a lot of other benefits over Ravelco but is all software rather than a physical prevention.
    For a lot less money you could go with a Mobilistics relay replacement. Several options for an activation using a Bluetooth remote keyfob, remote activation with a different switch or wiring it into another system such as headlights so the relay isn’t energized unless your left blinker is on, for example.
    https://www.mobilistics.com/nostart...relay-w-remote-starter-fuel-pump-immobilizer/
  4. Sep 24, 2024 at 7:06 AM
    Wighty
    Wighty Active Member
    Rob
    2021 Tacoma Off Road 4X4
    The most common way they're stealing the newer cars these days is using the OBD port.
    PUMPKINKING and SH10151 like this.
  5. Sep 24, 2024 at 7:23 AM
    TacoRancher
    Houston
    How do you prevent that?
  6. Sep 24, 2024 at 7:26 AM
    Wighty
    Rob
  7. Sep 24, 2024 at 8:38 AM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    To those interested in not wasting brain cycles watching a Youtube video edited for monetization length, just google, "OBD port lock" and go down the rabbit hole.
    JB_TN likes this.
  8. Sep 24, 2024 at 8:53 AM
    TacoRancher
    Houston
    Did you go this route @snickers ?
  9. Sep 24, 2024 at 8:56 AM
    snickers
    From a prone position stuck my head over the ledge and said, "I'll come back another time". Going to need my canyoning gear.
  10. Sep 24, 2024 at 9:03 AM
    TacoRancher
    Houston
    I get it. Lots of projects to complete. Given my last truck was stolen, I’m shellshocked and going to over index on security.
    snickers[QUOTED] likes this.
  11. Sep 24, 2024 at 9:54 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    & then theres me...
    Go to the gym daily & just leave the credit card key & my wallet in the truck with the doors unlocked...
    TacoRancher[OP] likes this.
  12. Sep 24, 2024 at 10:45 AM
    SchwarzeEwigkt
    SchwarzeEwigkt Well-Known Member
    Central NY
    ‘24 Tacoma TRD Sport 4x4, Solar Octane
    Is it? I thought it was just via accessing the CANBus. I remember seeing a few videos of guys rolling up, prying the headlight out of a car (an Acura?) and then splicing some CANBus gizmo in and using it to put the car into a state where it could be started and driven without a fob or a key.
    I might just be splitting hairs here. I think there's a CANBus endpoint in some of the unused (for OBD) pins on the OBDII plug, anyway.
    Either way, it really does make a guy wonder how the fob really is better than pushing a button to unlock the car and turning the ignition stick to start it. I can't say as I've ever really sat there and thought "man, pushing this button is hard and turning this key is just too much work." In fact, I thought the opposite last time the battery in the key on my current car died and the alarm went off then I unlocked the door with the key.
  13. Sep 24, 2024 at 4:59 PM
    TurboDA6
    TurboDA6 Well-Known Member
    Back in the 90's when I used to install alarm systems, I'd offer to wire up an ignition or ECU kill relay to the driver's seat belt switch. To start the car, you'd have to put your belt on first.
  14. Sep 24, 2024 at 5:13 PM
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    The problem with the obd port lock is just like wheel locks the thief will just have multiple keys.
    the mobilistics is pry the best solution. I installed a kill switch device to my starter in an old Corolla since cars where getting stolen at my old place of work. Similar thing. If they can’t start it, they ain’t going anywhere
  15. Sep 24, 2024 at 6:03 PM
    TacoRancher
    Houston
    Mobilisitics seems super simple and clean
  16. Sep 25, 2024 at 4:23 AM
    513Mugsy
    513Mugsy Well-Known Member
    Cincy
    2020 VOODOO AC OR MT sold now
  17. Sep 25, 2024 at 4:50 AM
    TacoRancher
    Houston
    I love simple. I’d just need help with installing something like this. I wonder if anyone does this where I live.
  18. Sep 25, 2024 at 9:42 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    What if there was a removable OBD port you could take with you? I guess it would have to be wired in line, but if you could get a quick connector that no one else could replicate. Disconnect the conector and know one else could tap into the OBD port. Car theives would eventually find a work around.
  19. Sep 25, 2024 at 11:43 AM
    soupy1234
    soupy1234 Well-Known Member
    2024 Celestial Silver TRD OR LB
    Or could go low-tech.
  20. Sep 25, 2024 at 11:44 AM
    TacoRancher
    Houston
    I got one of those and then saw one on a torn off steering wheel a few days later.
