Anti-seize lubricant on spark plug threads?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaJunkie8691, Oct 17, 2021.
  1. Oct 17, 2021 at 3:55 PM
    TacomaJunkie8691
    TacomaJunkie8691 [OP] 1999WineTacoma
    WA State
    1999 Wine Tacoma SR5 Exta-Cab 4wd V6
    Completely Stock except for Ranch 5000 Shocks and Struts.
    Hello Fellow Tacoma Junkies,
    What do people in Tacoma World think about using Anti-Seize Lubricant on their spark plug threads when changing out their spark plugs?
    Thank you in advance for your replies.
    Take care,
    Paul Muzinich
    davidstacoma and tacotoe like this.
  2. Oct 17, 2021 at 5:27 PM
    TRD8
    TRD8 Active Member
    North Georgia
    There’s different schools of thought in regards to the answer to your question. But, because the spark plug torque value spec is based on non lubricated threads I don’t use any anti-seize.
  3. Oct 17, 2021 at 6:47 PM
    Madjik_Man
    Colorado Front Range
    I always use a little dab and never torque spark plugs to spec. The “good and tight” method has been working fine for me for 30 years.
  4. Oct 17, 2021 at 6:54 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    spark plugs are over tightened by many
    just a dab will do with proper torque
  5. Oct 17, 2021 at 6:55 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    If you do, be sure to use the high temp anti-seize. Just a dab, no need to Rembrandt the threads.
    You can torque the plugs using an old school method.
    Run the plugs in until the plug gasket makes firm contact. Turn an additional 1/4 turn.
    The goal is the deform the metal gasket to make a seal.
    Slick Taco, syswalla, tacotoe and 3 others like this.
  6. Oct 17, 2021 at 9:51 PM
    TACOTU3
    TACOTU3 Well-Known Member
    2000 Xtracab V6 4x4 TRD
    Same here, add 20 years to the anecdotal evidence.
  7. Oct 17, 2021 at 10:38 PM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    I anti-seize anything and everything that can be safely treated...including my toast every morning. It's the greatest tool in the world. This, after 3 decades of wrenching trucks, heavy equipment, etc used in my past business.
    For the want of a penny's-worth of anti-seize, I have tens-of-thousands of dollars in labor and sometimes fabrication expenses all because it was assembled by the mfg without it.
    I do use it VERY SPARINGLY on plugs but torque to a lower standard than spec if the fitting isn't spec'd to use it in the first place.
  8. Oct 17, 2021 at 10:39 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    I think your nuts if you dont....especially on aluminum heads...
    Iridium plugs could be in there 80K ~ 100K...
    I dont think it has to be anti-size even through thats what I do now..
    worked on motorcycles since 60's and we always put a dab of disc brake grease...
    All structural threads need something for maximum performance...
    a dry thread is an uncertain seat unless locked mechanically...
    And thats before we get into dissimilar metals.....
    tacotoe likes this.
  9. Oct 18, 2021 at 2:54 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Once I get the plugs out the first time I use Copper based Anti Seize plus the silicone on the boots.
    Then I have never torqued a spark plug in my whole life.
    I buy Anti Seize by the case internal Engine Bolts are the only place I don`t use it.
    tacotoe and NSDON like this.
  10. Oct 18, 2021 at 3:02 AM
    Tacoma Mike
    Southern Maine
    Never
    golfindia and tacotoe like this.
  11. Oct 18, 2021 at 3:16 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    I've never used anti-seize on plugs and always tightened them by feel. Never had a problem. I've also worked on cars for 30 years so I know how tight they should be.
    tacotoe likes this.
  12. Oct 18, 2021 at 3:18 AM
    NSDON
    NSDON Well-Known Member
    Don
    NS
    02 SR5 TRD 4X4 Step Side
    I have seen lots of shops having to deal with seized original spark plugs in aluminum heads, it’s frequently a major job and new threads needed. That means head removal. New plugs can be speced from the factory to be changed at 160,000 kms/100,000 miles, then owners change them later than that. Anti seize works.
    I’ve removed stud bolts in exhaust manifolds which had anti seize on them years ago, no problems on my old cast iron bolts. Usually removal of the manifolds is required and a torch.
    My thought is, why would you not use it on spark plugs?
    tacotoe and Bivouac like this.
  13. Oct 18, 2021 at 3:22 AM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    NGK says don't use it.
    https://ngksparkplugs.com/en/resources/5-things-you-should-know-about-spark-plugs
  14. Oct 18, 2021 at 3:28 AM
    Bivouac
    Rambo MARINE Recon, tacotoe and NSDON like this.
  15. Oct 18, 2021 at 3:29 AM
    NSDON
    Don
    NS
    I’ve used it with ngk, just don’t over tighten the plug. Use 20% less torque. (I never use a torque wrench on plugs).
  16. Oct 18, 2021 at 3:35 AM
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    I am 48. I always use anti-sieze.
    Rambo MARINE Recon and tacotoe like this.
  17. Oct 18, 2021 at 4:18 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
  18. Oct 18, 2021 at 4:20 AM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Not put on at the factory, not in the service manual, not needed at all. Just torque correctly and all is well.
    tacotoe, Tacoma Mike and Kevins60 like this.
  19. Oct 18, 2021 at 5:48 AM
    NSDON
    Don
    NS
  20. Oct 18, 2021 at 5:49 AM
    NSDON
    Don
    NS
