another oil thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 99TacoDriver, Jul 25, 2024.
  1. Jul 25, 2024 at 8:46 AM
    99TacoDriver
    99TacoDriver [OP] Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    maybe we should just have a whole forum for oil discussions.
    I'm thinking about grabbing some Valvoline Restore and Protect, but not sure yet. They are running a deal for BOGO 50% off with free shipping.
    I guess I'm just looking for opinions. My truck is approaching 210k miles and i run the 5w30 Valvoline synthetic blend for high mileage engine. Any reason to not switch to the Restore and Protect?
    https://shop.valvolineglobal.com/co...e-protect-full-synthetic-motor-oil-sae-5w-30#
  2. Jul 25, 2024 at 8:51 AM
    ieizxxnsaeomeostfd
    ieizxxnsaeomeostfd Well-Known Member
    2014 Tacoma Base
    ARB Bumper Warn winch Icon lift 35s
    Personally I get the full synthetic Kirkland oil from Costco. Super cheap and has been good to me so far.
    RHHousehold, Firn, gr8-wrx and 5 others like this.
  3. Jul 25, 2024 at 8:54 AM
    99TacoDriver
    South Louisiana
    i guess my main concern is, will running the restore and protect cause issues because i havent ever run full synthetic in my truck. its always been dino or blended
  4. Jul 25, 2024 at 9:00 AM
    captrussia253
    captrussia253 IG: ruslan.khinotskiy
    PNW
    2017 Tundra CrewMax 2016 Toyota 4Runner
    This! I have been using Kirkland 5w30 in the GX, 4Runner and Tundra for years.
  5. Jul 25, 2024 at 9:01 AM
    ieizxxnsaeomeostfd
    2014 Tacoma Base
    I assume by issues you're referring to leaks. Based on my limited knowledge, full synthetic in older vehicles causing leaks is an old wives' tale. That said, there could be some truth to it in the sense that if you have a gasket that's just about to go and is hanging on by a thread with the help of some sludge, the better detergents in full synthetic could dislodge that sludge and therefore appear to cause a leak.
  6. Jul 25, 2024 at 9:13 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    I used it in my latest oil change and have about 2000 miles on it with no issues, but it's too early to tell. Otherwise, I've been a Costco Kirkland, Walmart Super tech, or Havoline user and change oil every 5000 miles. Our HHR is changed once a year because it doesn't ever get to the 5000-mile mark and has a percentage of use monitor. In the most recent oil change on the HHR the monitor said there was like 65% oil life.
    99TacoDriver[OP] likes this.
  7. Jul 25, 2024 at 9:18 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    Why change brand/type oil now, obviously that oil has served you well. Pretty sure you won't feel any "improvements" over what you're putting in now.
  8. Jul 25, 2024 at 9:25 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Listen to everyone so far in this thread. There are no magical products when it comes to engines.
    If you've been running good quality oils and changing frequently, then you aren't likely to gain anything.
    But 210k miles is 210k miles. Nothing can reverse that fact.
  9. Jul 25, 2024 at 9:39 AM
    99TacoDriver
    South Louisiana
    it mainly got me curious because valvoline claims that it will remove 100% engine deposits over a couple oil changes. that plus the deal they are running with half price got me thinking of trying it.
    Black97v6MT likes this.
  10. Jul 25, 2024 at 9:43 AM
    dtaco10
    Dave
    I don't think Valvoline would put out anything that's going to cause your engine to fail. With today's olis and if you follow the recommended OCI and your engine fails I would think there's something else going on in the engine or abuse. Years ago when I was at Cummins one engineer with the alternator group told me Valvoline Blue was their recommended oil and in particular we were looking at one unit they converted from diesel to natural gas.
    In a side note, Cummins has Cummins spark plugs, a rebranded Denso, and at a steep price. The Spark plug says Cummins on it.
  11. Jul 25, 2024 at 9:47 AM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    That is correct on why full synthetic got hated on when it was introduced, the dino oil sludge helped seal the old gaskets and the full synthetic cleaned the sludge away like its suppose to.
    Personally if your engine isn't making any noise I would just use regular oil, not high mileage or restore or magic fix-it. As a few people have already said I also happily use Kirkland full synthetic in both my 05 civic and 08 tacoma, no issues at all with civics at 180K and tacoma is at 230K.
  12. Jul 25, 2024 at 9:51 AM
    99TacoDriver
    South Louisiana
    i used to run only dino up until 160k-ish. started going to a new shop after relocating and they didnt even have dino oil at the time and i needed the oil change bad. thats when i switch to the blended valvoline. the past couple years i've been doing the changes myself and kept using the blended oil. i have thought about switching to the kirkland full synthetic but never pulled the trigger. next oil change i may just switch to kirkland or try this R&P.
  13. Jul 25, 2024 at 9:57 AM
    joeyv141
    New Jersey
    Nothing is really wrong with reputable blended oil but my understanding of blended is that its got part dino and part synthetic but I've never seen a bottle say what the percentage is so in theory it could be 95% dino and 5% synthetic and count as blended. I just use kirkland cause its good and cheep, I'm sure mobi1 and royal purple are better but my vehicles are basic boring engines.
    Is your engine making any abnormal noise?
  14. Jul 25, 2024 at 10:06 AM
    99TacoDriver
    South Louisiana
    hard to say. i did get the valve cover gasket changed last year and after that it started making an odd vibration type sound, but i never really got concerned with it because it goes away on its own and seems to do it randomly.
  15. Jul 25, 2024 at 10:14 AM
    joeyv141
    New Jersey
    I've had good luck putting about one cup of NOT synthetic transmission fluid in the engine to fix lifter noise. Im sure others have other such fixes as well.
  16. Jul 25, 2024 at 10:19 AM
    99TacoDriver
    South Louisiana
    sounds scary to me lol
  17. Jul 25, 2024 at 10:28 AM
    ridefreak
    NM
    2006 DCSB TRD
    minor tweaks
    If you want to clean the inside of your engine, add 1oz of seafoam per qt of oil in the motor 1000mi before your next oil change, take the rest and dump it in the gas tank. It's a one time deal. For me it got rid of a subtle valve clatter Id hear when accelerating away for the first time in the day when the engine was cold. I take it easy on the motor when it's cold but anything above a mild acceleration sounded like a bad lifter, it always went away quickly as the engine warmed but it was annoying. That went away almost immediately and was easily noticed. My used motor oil is typically a dark golden brown when it's changed @ 5K interval, when I dumped out the oil after putting in the seafoam for 1Kmi it was like ink, jet black. Next change it was back to golden brown. Did it clean it? I really don't know but it looked like it did and I had some noticeable improvements post treatment.
  18. Jul 25, 2024 at 10:37 AM
    joeyv141
    New Jersey
    Honestly no idea why not synthetic but a much older mechanic taught me that and it works, he said something along the lines of non synthetic transmission fluid has more detergents then motor oil does and that cleans it up.
  19. Jul 25, 2024 at 10:49 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Restore and protect? Sounds like the usual marketing lingo. They need new and exciting ways to get people to buy oil.
    The concern about synthetic oil causing leaks goes back to the days of old push-rod engines that had crappy seal designs, like rope lol. These modern toyota engines are for the most part, well designed and rarely leak.
    Bottom line, if you've got leaks with Dino oil, fix the leaks
    If you've got leaks with synthetic, fix the leaks. Switching back and forth trying to remedy a leak is a waste of time
    Running a quart of ATF with 4 qts of engine oil is a old backyard mechanic trick. You just run the engine for a few minutes at idle, don't drive it around .. I don't think it really works anyway
  20. Jul 25, 2024 at 11:11 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    After reading the product documentation, it seems you have to use it regularly. So unless you can always get that deal, it sounds like they are trying to suck you in. I'd stick with what you have been doing with the High Mileage and just stay consistent. Or, commit to using this new stuff and stick with it regardless of price.
