Another low profile roof rack build
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bonnfabrication, Jun 15, 2019.
  1. Jun 15, 2019 at 7:54 AM
    bonnfabrication
    bonnfabrication [OP] Well-Known Member
    Brandon
    Bremerton
    2018 Tacoma TRD OR DCSB 4x4
    Dobinsons HD MRR lift SCS F5 wheels BFG K02s front bumper, custom roof rack
    Well now that I have finally finished some side projects and more importantly my front bumper I can get started on my roof rack. Like many others I'll be taking some inspiration from a few racks that are currently in production and from a few guys on here who have also decided to do the same. I'll be using .25" plate aluminum which should be more than enough to make for a strong rack. Now for the fun part of getting all the curves measured so that this will sit low to the roofline and not look like crap. Shout out to @ORNG TACO for answering some questions in his thread about how he went about doing a few things.
  2. Jun 16, 2019 at 1:25 AM
    hirod
    hirod Well-Known Member
    hawaii
    16 double cab short bed OR
    I'm working on a similar project. i have an existing pipe rack that I'm trying to work around. the rack is largely to mount a deflector. the pipe rack creates a bit of wind noise after 40mph. didn't want a deflector mounted to the pipe rack so going the route of a mini cab rack. while I'm at it I'll be throwing on some lights.
    are you going to try keep the side pieces straight or follow the weatherstripping and be wider in the front? cross pieces welded or bolted? going with a flat fairing in front or rounded like meso's?
  3. Jun 16, 2019 at 7:42 AM
    bonnfabrication
    Brandon
    Bremerton
    The side pieces will be straight. The cross pieces will be bolted in place using aluminum extruded bars from 8020.net. and I'll be using a flat fairing that matches the curve of the windshield.
    mcharfauros and JoeCOVA like this.
  4. Jun 17, 2019 at 1:38 PM
    bonnfabrication
    Brandon
    Bremerton
    So after taping some cardboard and rough cutting it to the curve of the roofline, I then used my handy sharpie to trace the curve then taped the cardboard to my dining room table and marked out a straight line and the wind deflector angle and back of the cab departure angle. Marked out every .5 inches and used that to measure from the straight line down to the curve so I can use that to input this into fusion 360.
    mcharfauros and rlx02 like this.
  5. Jun 24, 2019 at 7:45 PM
    bonnfabrication
    Brandon
    Bremerton
    Well this is what I have come up with so far. Still need to make some test pieces and check the fit. Not sure how the TRD logo Is gonna work out though. It's kinda thin in a few spots.
    mcharfauros likes this.
  6. Jun 24, 2019 at 7:51 PM
    mcharfauros
    mcharfauros IG: mcharfauros
    MO
    2017 Black TRD OR DC
    Dumb Truck Thangs
    Staying tuned, awesome rendering
  7. Jun 24, 2019 at 7:58 PM
    s7726
    s7726 Well-Known Member
    2019 DCLB TRD OR Cement
    Your width is off. The "Toyota Racing Development" should go edge to edge of the "TRD". Making it a little wider should help with the thin parts a bit.
  8. Jun 24, 2019 at 8:01 PM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
  9. Jun 24, 2019 at 8:02 PM
    SpeySquatch
    2016 TRD OR DCSB
    For metal integrity purposes shouldn’t the logo be centered vertically with even spacing above and below in this pic?
  10. Jun 24, 2019 at 8:08 PM
    mcharfauros
    MO
    Dumb Truck Thangs
    I support it! Looks great to me
  11. Jun 24, 2019 at 8:24 PM
    bonnfabrication
    Brandon
    Bremerton
    @s7726 I do agree that it needs some fine tuning in terms of ascetics. The part im worried about is that the R is about .02" thick between the curve and the vertical portion of it. im hoping to make some test pieces tomorrow to be able to see it full size.
  12. Jun 24, 2019 at 8:25 PM
    bonnfabrication
    Brandon
    Bremerton
    I should also add that I didn't make the TRD logo. I found it online on Grabcad. so that was a huge win.
  13. Jun 24, 2019 at 9:06 PM
    caribe makaira
    Caribbean, Puerto Rico
    https://youtu.be/Pjep8oKTqzE
  14. Jun 24, 2019 at 9:27 PM
    bonnfabrication
    Brandon
    Bremerton
  15. Jun 24, 2019 at 9:28 PM
    caribe makaira
    Build it...:D, You could even place a L bracket where the bolts go for a sure fixture placement as you get the contour.
  16. Jun 25, 2019 at 4:02 PM
    bonnfabrication
    Brandon
    Bremerton
    Well I think my test piece came out pretty good. Used our laser engraver to make a test piece to check the fit as close as I can right now. Have to say it came out pretty clean and all the roofline mounting holes lined up which is surprising. I figured at least one would be off. I still need to add the mounting holes for my quick fist mounts and clean up anfew things like the TRD logo.
  17. Jun 25, 2019 at 4:02 PM
    bonnfabrication
    Brandon
    Bremerton
    Not a bad idea. I'll have to keep that in mind.
  18. Jun 25, 2019 at 4:55 PM
    S5sTacoma
    S5sTacoma Member
    2019 TRD Off Road
    that's pretty sweet! great job. can't wait to see the final result
  19. Jun 25, 2019 at 8:27 PM
    bonnfabrication
    Brandon
    Bremerton
    @S5sTacoma Thanks man. Im hoping in the next few weeks I can get all the parts ordered and then start assembly. I still need to mill out my spacer blocks for in the drip rails.
  20. Aug 5, 2019 at 7:58 PM
    bonnfabrication
    Brandon
    Bremerton
    well its been a while. I got another rack designed for my brothers Lexus GX470 and finally got them both rendered to see if there were any issues in the design before cutting. found one or two and got them fixed. here are a few pics from fusion 360 of mine. tacoma Render v1.jpg tacoma Render v2.jpg tacoma Render v3.jpg
    S5sTacoma and mcharfauros like this.
