Another E-locker Converstion Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by wesb1023, Mar 24, 2013.
  1. Mar 24, 2013 at 9:03 AM
    wesb1023
    wesb1023 [OP] Well-Known Member
    Westley
    Eastern NC
    04 Double Cab
    OK, So my 04 has an open rear axle. From what I have read while searching it is an 8.4" ring gear. I have found a truck with a e locker rear axle in the junk yard. From what I have read it is a 8" ring gear. The problem is that it was wrecked in the rear and the housing is bent. The third member looks to be in good shape, and according to the door codes the ratio is the same on both trucks. So can I modify my 8.4" housing to accept the locker third member, or not? I have read several posts, and done some searching and cant figure out if they are saying that it can be modified to the 8.4" housing, or the older toyota truck rear axle housings. I would also like to know if my axle shafts will work with this third member set up, as my truck has abs, and the wrecked one does not. Any info would be great, as I can get this third member at one hell of a deal!!! :cool:
  2. Mar 24, 2013 at 9:28 AM
    jdkilroy
    jdkilroy Well-Known Member
    Jon
    Southern NH
    '02 4x4 SR5 Access Cab
    Can my diff housing be modified to accept the e-locker?
    Yes, you will need to grind out an area in the driver side of the diff housing mounting flange to allow the actuator to fit.
    Before:
    After:
    Will my ABS axles work?
    Yes, The ABS sensors pick up the rotational speed signal from teeth cut into the outboard end of the axle. The drive splines are the same. Since you are fitting this locker to your existing axle beam, the only concerns you have are fitting the third member to your diff housing.
    You will need to sort out the wiring as well.
    There is a good write-up here: http://sonoransteel.com/phong/retrofit_electric_locker.html
    It is being done on a 4Runner but essentially the same.
    Bandido likes this.
  3. Mar 24, 2013 at 9:40 AM
    wesb1023
    Westley
    Eastern NC
    04 Double Cab
    Thanks!! I can get the third member, ecu, switch, and connector ends off this same truck. Price he gave me was $250.00.... Cheap enough I guess!!
  4. Mar 24, 2013 at 11:01 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Where at in nc did you find this truck haha ? cant find yotas anywhere near me
  5. Mar 24, 2013 at 11:13 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Holy crap thats a deal!
    Yeah, it can be done as stated above, it requires mods though.
  6. Mar 24, 2013 at 11:16 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Dang that's nice
  7. Mar 24, 2013 at 11:20 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    That's awesome! Thanks for posting that. So if I clearances my 8.4 for the e locker third I could reuse my stock 8.4 4.56 gear and put it in the e locker third and put all that back in the clearenced axle.
  8. Mar 24, 2013 at 11:20 AM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    That is an 8" housing. The 8.4" housing mounting flange is larger than the 8", meaning the studs will not line up, and the studs are larger in diameter. You are better off finding a complete 8" elocker axle, retrofit a elocker into a non-elocker 8" housing like the above article shows, or getting an ARB locker for your 8.4" housing.
  9. Mar 24, 2013 at 11:22 AM
    ajohnson
    Andy
    Charlotte, NC
    It is possible, but slightly more involved than that article posted above.
  10. Mar 24, 2013 at 11:44 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Nvm then! After reading that it appears to be a huge disaster. Much more expensive than just buying a 4.56 8" ring and throwing it in the Trd axle
  11. Mar 24, 2013 at 12:09 PM
    wesb1023
    Westley
    Eastern NC
    04 Double Cab
    Ughhh! That sux!!! I may purchase the third member anyway, and wait to find a more compatable housing.
  12. Mar 24, 2013 at 3:55 PM
    jdkilroy
    Jon
    Southern NH
    My apologies Wes, I did not notice that you were using two different sized housings. Just look for a locker that matches your diff housing size.
    I have been looking myself and they are out there. Not usually as cheap as you found it though. Best of luck.
  13. Oct 15, 2018 at 4:08 PM
    ToyotaRoamer86
    ToyotaRoamer86 Well-Known Member
    Brandon
    Frisco, CO
    2007 Tacoma TRD Sport
    This is very old but, So I can retrofit my 8.4" non locking with a 8" from any gen elocker?
  14. Oct 15, 2018 at 4:13 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Did you read the thread at all? The mounting flange/hole is larger on the 8.4 so the studs will not line up.
  15. Oct 15, 2018 at 4:17 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Nah, I don't think that's the verdict they arrived at.
  16. Oct 16, 2018 at 1:35 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    It can be done but it's alot of work and fabrication. 2 stud holes have to be welded up and redrilled and the 2 long studs added. Along with grinding housing
  17. Oct 16, 2018 at 2:12 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    The relatively easy swap requiring grinding a notch and adding the long studs is for putting an e-locker into an 8" non e-locker housing. It was popular in the 3rd gen 4Runner crowd because the factory 4R non e-locker was also an 8" just without the notch and longer studs.
    ECGS once sold a "kit" consisting of the longer studs and a factory e-locker gasket to serve as the drill/grinding template.
    As mentioned the Taco "8.4" non e-locker housing has a completely different (larger) mount base requiring lots more work. Doable but not really practical.
