Another boat trailer question
Discussion in 'Towing' started by dexdawg, Feb 15, 2011.
  1. Feb 15, 2011 at 9:44 AM
    dexdawg
    dexdawg [OP] Well-Known Member
    Frederick, MD
    2010 DC SB OFF-ROAD
    My boat trailer that I just bought has a 5 pin connector on it. I have a 7 to 4 pin adapter for my Tacoma. Can I or should I just use the 4 pin adapter or should I get a 7 to 5 pin.
    I know the 5 pin usually has something to do with brakes and putting the trailer in reverse. Do I need the 5 pin for this reason or just as long as all brake and turn signals works it should be good.
  2. Feb 15, 2011 at 10:06 AM
    MushyB
    MushyB Well-Known Member
    MA/CT
    05 Taco TRD Off-Road
    i did some quick research on google and found
    [FONT=Verdana, Arial, Helvetica, sans-serif]White - Ground
    [FONT=Verdana, Arial, Helvetica, sans-serif]Brown - Running Lights[/FONT]​
    [FONT=Verdana, Arial, Helvetica, sans-serif]Yellow - Left Turn, plus Stop[/FONT]​
    [FONT=Verdana, Arial, Helvetica, sans-serif]Green - Right Turn, plus Stop[/FONT]​
    [FONT=Verdana, Arial, Helvetica, sans-serif]Blue[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif] - Wire to the backup lights (this wire releases the brakes when backing up)
    [/FONT]
    it seems the blue wire for your backup lights is necessary if you have electric brakes, so that the trailer isn't on the brakes when you're backing it up when you press the brakes... makes sense so you don't jack-knife it. if you're not worried about back-up lights or you hitting the brakes too hard to cause it to jack-knife that i guess you don't need it.
    what kind of boat are you rockin??
    [/FONT]
  3. Feb 15, 2011 at 10:20 AM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    does your trailer have surge brakes?
  4. Feb 15, 2011 at 10:20 AM
    dexdawg
    Frederick, MD
    2010 DC SB OFF-ROAD
    I found the same info searching the internet. Pretty sure my trailer does not have electric brakes. I don't even think there is a blue wire running through the trailer but it has a 5 pin connector. I have to double check when I get home today. I know all the lights work because I just had to reconnect the ground wire to the trailer and I checked all brake lights and turn signals.
    I had to back it up into parking spot the other day with no problems but was on pretty level ground. I just recently bought a 2002 Monterey 180 Edge w/2003 Load rite trailer.
  5. Feb 15, 2011 at 10:22 AM
    dexdawg
    Frederick, MD
    2010 DC SB OFF-ROAD
    It's a single axle boat trailer so I would say "probably" but not 100% sure!
  6. Feb 15, 2011 at 10:32 AM
    borderbrat
    Jeremy
    Victoria BC, Canada
    There are a few different senarios i can think of.
    1. who ever manufactured the trailer uses 5 way plugs on all their trailers and the blue is not connected
    2. the trailer is wired for brakes but doesn't have them installed
    3. there are brakes you have never used them because you need a brake controller
    if there are brakes on the trailer you might as well use them. get a 7way to 5 way adapter and get a brake controller.
  7. Feb 15, 2011 at 10:37 AM
    borderbrat
    Jeremy
    Victoria BC, Canada
    it would also be easy to either put a 7way plug on your trailer or make an adapter using a 7way plug and 5way vehicle wire harness.
  8. Feb 15, 2011 at 10:41 AM
    borderbrat
    Jeremy
    Victoria BC, Canada
  9. Feb 15, 2011 at 11:23 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Usually single axle trailers don't have brakes.You should be good with the 4 pin as long as all your lights work properly. Just make sure your trailer doesn't have brakes if you are gonna use the 4 pin.
  10. Feb 15, 2011 at 12:50 PM
    tonto340
    tonto340 Well-Known Member
    Gambrills, MD
    I don't know where you are in Maryland. Bass Pro shop sells a 7-pin to 5-pin adapter. The 5th pin will keep the brakes from locking up when backing into down the ramp.
  11. Feb 15, 2011 at 4:33 PM
    MushyB
    MA/CT
    yea it seems the 5th wire would be to deactivate your electric brakes or to actuate your servo in the tongue (if you have that accessory) for surge/hyrdaulic trailer brakes. this will prevent your ball hitch from pushing on the master cylinder of the trailer brakes in the tongue. otherwise for surge brakes you have to manually set the pin to prevent your brakes activating on your trailer upon backing up your trailer. if you don't have electric brakes or the servo accessory for your tongue then you don't have any worries for that fifth wire. best of luck on that. on another note, what kind of boat do you have??
  12. Feb 15, 2011 at 6:07 PM
    dexdawg
    Frederick, MD
    2010 DC SB OFF-ROAD
    When I got home today I looked and no blue wire going through trailer and no brakes at all. The trailer is a Load Rite so I guess the probably wire all their trailers with 5 pin.
    I already have two 7-5 converters so I'm good there. For those that are wondering I just bought a 2002 Monterey 180 Edge bowrider w/2003 trailer.
    Thanks for all the help. I'm new to boating so I'm sure some more questions will come up in the future.
  13. Feb 15, 2011 at 7:25 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Surge brakes have a master cylinder in the tongue. Electrics have coils in the hub. Both have drum brakes.
    Trailers with GVW over 1k lbs are supposed to have a braking system. The truck is only supposed to stop it's own loaded weight, not a trailer.
    Make sure the hubs have no brakes before you rule out electrics.
  14. Feb 15, 2011 at 7:42 PM
    MushyB
    MA/CT
    sick boat!! i just bought an 88 imperial with an inboard volvo penta 4 banger. for a 4 cyl. it cruises. def. one of the best investments i've ever made, besides the tacoma. between the fun, fishing and just plain hanging out drinking some brews, it's great! enjoy the boat fun, i wish the lake would thaw out here alreadyyy.
  15. Feb 16, 2011 at 7:57 AM
    borderbrat
    Jeremy
    Victoria BC, Canada
    depends on the state.
  16. Feb 16, 2011 at 8:16 AM
    borderbrat
    Jeremy
    Victoria BC, Canada
