Amsoil Products ATF, MTF, Gear Oils
Discussion in 'Buy / Sell / Trade - Other' started by Pablo8, Nov 22, 2019.
  1. Apr 26, 2020 at 9:23 AM
    #61
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    wilcam47[QUOTED] likes this.
  2. Apr 26, 2020 at 9:36 AM
    #62
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  3. Apr 26, 2020 at 9:45 AM
    #63
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    CygnusX191 and wilcam47[QUOTED] like this.
  4. Oct 14, 2020 at 8:05 PM
    #64
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Just peeking in, starting planning/prep to do pretty much every fluid this truck has, approaching 50k
    daveeasa and Pablo8[OP] like this.
  5. Oct 14, 2020 at 8:54 PM
    #65
    jdiola
    jdiola Well-Known Member
    jay
    Echo park los angeles
    13 tacoma dcsb off road
    Ovtune, anytime locker mod, pelfrey hybrid bumper, pelfrey rock sliders baja designs s8 and sqaudron pros, group 31 interstate battery with TW memeber coupe trd battery strap, osram 100/90 watt headlight bulbs, hkb voltage booster, meso 3 pod 3rd brake light, archive hammer hangers at the helm motorcycle holder/bed stiffiner prinsu rack gfc superlite rotopax 2.5 gas 2 water sua deaver hd springs with icon hydro bumps 12” fox 2.5 dcs w/ accutune on archive shock relocation ext icon cdc front coil overs jdfab 2.25 lt w/currie axles fox 2.5 front bumps jdfab double shear uca jdfab spindle gusset bypass shock hoop with icon s2 falken wildpeak 265/75-17 carhart seat covers
    hello i am an amsoil user how do i sign up for the preferred customer?
  6. Oct 14, 2020 at 8:55 PM
    #66
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    mcharfauros and CygnusX191 like this.
  7. Oct 31, 2020 at 6:35 AM
    #67
    Ensemble88
    Ensemble88 Well-Known Member
    San Diego, CA
    2017 Black OR DCLB
    King suspension, SSO bumper w/winch, Pelfreybuilt sliders, morimoto fogs
    I think I'm going to get amsoil for my next oil change. And I'm thinking of doing the same for my wife's Subaru Forester. Since she has to change her oil per manufacturer rec. Every 6k for full synth. Would she also change to once per year with amsoil? Or would it require a slightly more frequent changing?
  8. Oct 31, 2020 at 6:43 AM
    #68
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    Photos of an Amsoil By-pass Oil Filter kit mounted on the cross member and protected by a mid-skid plate. It is on a 2.7L - so the exhaust system cooperates with this location.
    I used treated lumber for a riser, nylon plate as a foot, and aluminum plate as a head. Everything coated with Amsoil heavy duty MP (note the orangish color). Very solid, sturdy mount with no movement. Later, I wrapped the exhaust downpipe with fiberglass tape to shield the oil hoses from heat. Works perfectly!
    CygnusX191 and Grossomotto like this.
  9. Oct 31, 2020 at 6:45 AM
    #69
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    How many miles does she drive per year? If more than 6K, just use the OE line and change at 6K. If right around 6K or less, every year is fine.
  10. Oct 31, 2020 at 4:54 PM
    #70
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Great install. How many miles oci are you going with the bypass? Just curious.
  11. Nov 1, 2020 at 5:31 AM
    #71
    TartanEagle
    '17 ACLB 4x4 MT
    Yet to be determined. I've been doing 25k with a 12,5k filter change (normal full flow filter). I'll let the oil analysis tell me what length now. I expect quite long, given that I have the Japan built engine.
  12. Nov 1, 2020 at 6:01 AM
    #72
    Ensemble88
    San Diego, CA
    2017 Black OR DCLB
    This is an interesting set up I haven't thought about before. Let me get this straight, the amsoil is clearly great oil, but the oil filters still need to be changed out at their own end of life. And you can't really change out the cartridge oil filter without draining the whole thing. Is that the purpose for your set up then? To change the filter without losing the engine oil?
    wilcam47 and CygnusX191 like this.
  13. Nov 1, 2020 at 6:12 AM
    #73
    TartanEagle
    '17 ACLB 4x4 MT
    It won't drain the whole amount because the orig filter is above the oil level in the pan. BUT it will drain out the contents in the hose and that is more than I'd like to lose. I will try to catch it in a clean container and if I'm happy it stayed uncontaminated, I'll put it back in the engine. Could even put it back through a paint filter for extra peace of mind.
    Because of the oci, it won't happen very often. If I don't reuse, that additional amount of oil to replace - coming from new oil - will really enhance the additive package until then next filter change.
  14. Nov 1, 2020 at 7:40 AM
    #74
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Japan built engine?
  15. Nov 1, 2020 at 3:04 PM
    #75
    TartanEagle
    '17 ACLB 4x4 MT
    My understanding is that the 2.7L powerplants are built in Japan.
    CygnusX191[QUOTED] likes this.
  16. Nov 1, 2020 at 5:25 PM
    #76
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Let me know where you end up. I’m hoping to tackle mine over thanksgiving while my wife is traveling with #1. Think I can just do it in the garage if I clean up well. Leaning 51% redline but might just go all in on amsoil. Need to get my order in soon I think.
  17. Nov 1, 2020 at 5:26 PM
    #77
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Damn that's cool. Makes me miss my SR5 even more
    TartanEagle[QUOTED] and daveeasa like this.
  18. Nov 6, 2020 at 6:39 AM
    #78
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    Promotion for P.C.s and Catalog Customers – $5 Shipping or Spend $100 for Free Shipping*
    Offer: $5 Shipping or Spend $100 for FREE Shipping*
    Promo Code: BUY1020
    Be sure to use my referral number 515729 in the process if you are not a PC (preferred customer). Or start here: https://www.amsoil.com/offers/pc/?zo=515729
    Effective Dates: Oct. 21 - Nov 10, 2020
    This special offer is effective from 9 a.m. Central 10/21/2020 to 11:59 p.m. Central 11/10/2020.
    Receive $5 shipping with any purchase or spend $100 ($130 in Canada) for free shipping.
    To redeem: Shop online at AMSOIL.com (AMSOIL.ca in Canada) and enter code BUY1020 at checkout. You must log into your account to ensure proper pricing is applied. Or, call AMSOIL Customer Service at 800-777-7094 between 7 a.m. and 7 p.m. CT Monday–Friday. Provide your customer number and promotional code to the representative.
    *Offer is not transferrable and void where prohibited. Cannot be combined with other offers. Offer limited to items available for shipment within the continental U.S. and Canada. Offer not valid for orders shipped to Alaska or Hawaii, or orders requiring expedited handling or other special freight terms. Shipments to a small minority of outlying areas in Canada remain subject to additional interline fees. Other taxes, environmental fees, etc. may apply.
  19. Nov 6, 2020 at 7:38 AM
    #79
    daveeasa
    David
    PNW
    @Pablo8 If my memory is still intact, you have done one full change of all fluids? Or at least both diffs and MT? I think you posted your selections in the MT fluid thread but I haven’t pulled them back out yet. Think you could cross post here? I guess we need to use that thread to figure out the crush washers and filters and other items which must be purchased separately?
    CygnusX191 and Pablo8[OP] like this.
  20. Nov 6, 2020 at 7:56 AM
    #80
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    Yes, all oily fluids changed. I have not done a brake fluid or coolant change, too early for that, but clutch hydraulic is Amsoil Brake Fluid.
    I bought the washer set from Amazon
    Front Diff: Amsoil SG 75W-90 (SVG) https://www.amsoil.com/p/severe-gear-75w-90-svg/?zo=515729
    MT: Amsoil MTG 75W-90 (MTG) https://www.amsoil.com/p/manual-transmission-transaxle-gear-lube-75w-90-mtg/?zo=515729
    TC: Amsoil MTF(MTF) https://www.amsoil.com/p/manual-synchromesh-transmission-fluid-5w-30-mtf/?zo=515729
    Rear Dif: Amsoil SG 75W-110 (SVT) https://www.amsoil.com/p/severe-gear-75w-110-svt/?zo=515729
    No leaks, all was smooth. Use heat and hammer taps on the front differential drain. Super easy to strip the hex hole (10mm) - I replaced mine with a Dimple brand plug, plus that one uses the copper crush washer. The rear on mine was 15/16", NOT 24mm. Others 24mm, fill on front dif is also hex 10mm, but not as tight.
    CygnusX191 and daveeasa[QUOTED] like this.
