Amsoil or Redline for Gear Oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gerry Pope, Nov 1, 2008.
  1. Nov 1, 2008 at 9:59 PM
    Gerry Pope
    Gerry Pope [OP] Well-Known Member
    San Diego
    07 4X4 PreRunner
    Which do you prefer. I am going to replace my manual tranny fluid. I have a 3rd gear that refuses to slide in It kinda bumps in when it gets warm.... O' say after the first 5 minutes.. When I had the rear springs replaced I asked the dealer to check the tranny and the rep told me "they all do that and it is fine!" I don't buy it. I test drove a couple of 6-speeds and the first AC I tried did not have problems. Anyhoo.. I have read the raves about Redline MT-90 and that of Amsoil.. I can't find either local so I have to mail order.. Any preference ?
    Thanks..
  2. Nov 1, 2008 at 10:13 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i say either one will be fine. both are outstanding oils.
  3. Nov 2, 2008 at 12:28 AM
    P. Bauer
    P. Bauer Well-Known Member
    San Jose
    08 Tacoma 4x4 TRD Off-Road
    TRD S/C :: Intake Camburg SwayAway Magnaflow American Racing Donahoe Racing Wheelers OffRoad
    I used Mobil 1 75W90 in the rear diff, tranny, transfer case and front diff.
    I've used both Motul and Redline in other vehicles (Audi/Mazda RX7 racecar), can't say I've noticed that one was far superior to the other.
  4. Nov 2, 2008 at 8:13 AM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    u change ur tranny fluid? u have a auto or manual? they say my auto is a new type and I dont have to change it for 100K miles. I dont have the dipstick to check tranny fluid
  5. Nov 2, 2008 at 8:14 AM
    Joe B
    Joe B Well-Known Member
    I went with Amsoil Severe Gear 75w90 in Diffs and transfer case..:)
  6. Nov 2, 2008 at 8:23 AM
    P. Bauer
    San Jose
    6-speed manual.
  7. Nov 2, 2008 at 4:17 PM
    Gerry Pope
    San Diego
    07 4X4 PreRunner
    Thanks for all the replies.. Six of one etc. Found a place that sells the Redline for $9 a quart.. Think that is the route I will go..
    Will let you know if it does anything for my problem..
    User_86 likes this.
  8. Nov 5, 2008 at 11:52 AM
    papabear050
    papabear050 Well-Known Member
    11 dc 4x4 TRD OR Auto
  9. Nov 5, 2008 at 12:14 PM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    I'll put my vote for Amsoil - I'm using it for engine oil, but not going to mess with what isn't broken or easy to fix myself (the tranny). I believe that the redline price you found is quite good.
    For Amsoil you can try the dealer locator.
  10. Nov 5, 2008 at 12:21 PM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    I called my dealers and no answer
    I dont want to order it online, then i have to pay for shipping and tax, then it would get too pricey. Prices too high, then i rather just take mobil 1
  11. Nov 5, 2008 at 12:23 PM
    Joe B
  12. Nov 5, 2008 at 2:16 PM
    papabear050
    yup,
    when the time comes it'll be Amsoil SG in the Transfer case and Front. Diff
    Redline MT-90 in the Manual Transmission
    And Dino (Valvoline or Penn 80s-90 and LSD additive in the rear)
    Wish I could use Amsoil all around but not good for LSD
  13. Nov 5, 2008 at 2:25 PM
    Joe B
    Amsoil is fine with the LSD.
    I was told the Severe Gear oil has tha posi additive.
    If it makes you feel better you can add the additive with the Amsoil Severe Gear.
    I did.
    NOTE: AMSOIL Synthetic Gear Lubes do not require the use of this additive. However, not all differentials respond the same and if chatter is noticed, the addition of AMSOIL Slip Lock will eliminate it. For chattering differentials not running AMSOIL Gear Lube, this product is an excellent solution to the problem.
    http://www.amsoil.com/storefront/ada.aspx
  14. Nov 5, 2008 at 2:36 PM
    papabear050
    Yeah, but I bet the LSD in the 05-08 will chatter with any syn. Rather not risk it.
  15. Nov 5, 2008 at 3:12 PM
    Joe B
    It may not and if somehow it does,you can add the 4 ounce additive.
    I added the additive when I changed over and have no problems.
  16. Nov 5, 2008 at 3:50 PM
    papabear050
  17. Nov 5, 2008 at 4:01 PM
    Joe B
    Reading the first two pages it seems Mobil 1 is the only fluid that caused a problem.
    I have no problems.
    A Amsoil Rep said the Severe Gear has the friction modifier but I could add a 4 ounce bottle of any brand modifier if I'd like.
    I chose to add Amsoil's friction modifier just in case.
  18. Nov 5, 2008 at 4:27 PM
    papabear050
    Wise decision.... However, I think the 2009 moved away from a traditional mechanical LSD.
    They use a auto LSD which utilizes the computer and brake control to limite wheel slip. Therein lies the difference, hence no mech. lsd, no chatter.
    "It's basically cost-cutting on Toyota's part. A mechanical LSD is a clutch operated device within the rear end (differential assembly) of the Tacoma w/ Sport Package 2005-2008. On an open differential, there isn't such a device, and when a difference in wheel speed between the left and right rear wheels is achieved, power is delivered solely to the spinning wheel since it has the least resistance in a wheelspin situation. With a mechanical LSD, the difference in wheel speed is reduced (not eliminated) because the clutch can partially lockup (hence why it's called limited slip) the differential, thus allowing power to reach the wheel with traction. The amount of differential lock is limited, so LSDs can be overpowered. The threshold is usually dependent on how aggressive the LSD clutch is, and usually, road going production trucks generally don't see very aggressive LSDs from the factory.
    Toyota's new Auto-LSD system is completely electronic, eliminating the need for the mechanical LSD. This system uses the rear brakes to limit the amount of wheelspin achieved. Think of the clutch in the mechanical LSD as an internal brake when its activated except it acts on the actual differential and not the wheels. When the Auto-LSD system detects a wheel spinning faster than the other (through the ABS speed sensor), it activates the rear brake on that wheel so the other wheel can get power.
    They have the same premise, they just go about it in different ways. An electronically simulated LSD only wears the vehicle's brakes, whereas a vehicle equipped with an LSD wears the clutch/clutches in the LSD itself."
  19. Nov 5, 2008 at 5:30 PM
    Joe B
    Very interesting.
    Thanks,papabear.:)
  20. Jul 11, 2011 at 3:14 PM
    hellboundsoldier
    hellboundsoldier Member
    Raleigh
    09 4x4 Double Cab Sport
    AVID off-road sliders and bumper, Hi-lift jack mount, AVIC Z120 nav, tacotunes stereo
    I know this is an old post, hoping for an answer yet. Does this mean that the Automatic LSD does not require the LS additive? I have been asking every dealer in the area and can not get a straight answer on the rear diff fluid I need.
