Amsoil metal protector for anti rust on frame?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Njdan67, Dec 19, 2018.
  1. Dec 19, 2018 at 11:16 AM
    Njdan67
    Njdan67 [OP] Active Member
    Dan
    2014 Tacoma dbl long bed
    None
    Has anyone used this or any other spray on “diy” coating? I’d like to get some ideas before I take the leap and make a purchase. Thanks very much
    Rambo54 likes this.
  2. Dec 19, 2018 at 11:18 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
  3. Dec 19, 2018 at 11:19 AM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
  4. Dec 19, 2018 at 11:25 AM
    Njdan67
    Dan
    None
    Thank you!
  5. Dec 19, 2018 at 12:27 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I use Amsoil metal protector on my truck. It works well and dries to a waxy coating. About 3 cans will do the underside of the truck. I've been using it since the truck was new and there isn't any rust under there. Seems to work good considering CT lays down the "liquid rust" deicer if there is any threat of cold weather...
    Njdan67[QUOTED][OP] likes this.
  6. Dec 19, 2018 at 3:31 PM
    Charger92
    Charger92 Built for pure function!
    British Columbia Canada
    2007 Tacoma double cab long box
    Love the stuff. Get the heavy duty MP.
    I've used fluid film and it works ok but is always greasy and collects dust.
    Amsoil HDMP is dry waxy.
    Great on leaf springs too. My top choice but does not deliver to Canada any longer. I get a case once a year when I go down.
    Njdan67[OP] and vssman like this.
  7. Dec 22, 2018 at 8:29 PM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    I’ve used Amsoil HDMP two winters in a row now and I like it . It dries to a waxy film and smells kinda like wax/crayons when it’s drying. The first winter I used 4 cans and this winter I used 6 for extra coverage . Just wear old clothes you don’t mind getting ruined , it’s sticky and will stain. I also suggest long sleeves as it’s a pia to wash off , I also use disposable gloves . It does protect and in the spring I use a pump weed sprayer filled with simple green HD then run it through the car wash
  8. Dec 23, 2018 at 5:03 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Eastwood makes (made I guess as I haven't checked if it's still available) an extension hose that fits a spray can. It fit the old style cans perfectly but I did have to modify it for the new type. The hose has a brass end that sprays in 5 directions and I run that through the inside of the frame.
    igno1tus likes this.
  9. Dec 23, 2018 at 5:09 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Krown
  10. Dec 23, 2018 at 9:17 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Use what you like, the key is being proactive and keeping up with it as long as you own the truck. Once a yr. for me does the trick.
    vssman likes this.
