Amp Research Powerstep Install Issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dano7891, Jul 29, 2016.
  1. Jul 29, 2016 at 1:15 PM
    Dano7891
    Dano7891 [OP] Member
    2016 Tacoma TRD Offroad 4x4
    So, I decided to install my powersteps yesterday and now have a little problem. The driver's side installed without issue when tapping in the wiring (got it right the first try even with multiple wires of the same color) but the passenger side was a different story. Anyway, the steps work great and lower appropriately, but now I have a blinking seat belt warning light and a steady red airbag looking light. Thinking that I may have jacked up one of the four purple wires that I had to test to get the back passenger side door to activate the step.
    Anyway, before I attempt to repair the passenger side wiring, does anyone have another idea on what I may have done? The wires all looked ok after removing the tap, but they were very small wires so there may be some damage that can't be seen. A wiring harness guide might also help if someone has one and can share.
    Thanks in advance & Cheers!
    Dano
  2. Jul 31, 2016 at 11:04 PM
    Dano7891
    Also, just noticed that when either of the passenger doors are opened the little info graphic in the guage cluster shows both doors opening. Anyone out there have an idea what might be happening here? (besides just that some of the wiring is now screwed up?)
    TIA- Dano
  3. Aug 1, 2016 at 4:16 AM
    kzrpk5
    kzrpk5 Well-Known Member
    Wisonsin
    2016 Tacoma
    TC Long Travel, SUA, Bed Cage, Fiberglass, 38", JD Fab LCA mounts, roll cage, manual hub conversion + Stickers!
    may not be a technical fix, but worth a try, disconnect battery for a few minutes and then reconnect, see if that resets anything. couldn't hurt and cost is nothing.
    Dano7891[OP] likes this.
  4. Aug 1, 2016 at 10:11 AM
    mr.BeBoT
    mr.BeBoT Well-Known Member
    '16 SSM DCLB Sport
    all mods requested by the wife (seriously)
    @Dano7891 Give AMP a call, they have awesome CS! Not sure where you are located but they were local to me (Tustin,CA) and ended up having me drive there to fix the door issue. I'm not sure if it was additional ECU programming or wiring in the harness but they said they would be updating the kits...my guess is you received your steps before the update since it's only been 2 weeks since I've been.
    As to your original problem, I did not encounter that during my install but got lucky with the right wire so that may be user induced :annoyed:
  5. Aug 24, 2016 at 7:11 PM
    Dano7891
    Thanks! I'll give them a call tomorrow!
    Cheers! -Dano
  6. Apr 10, 2017 at 11:15 AM
    Ram5493
    Ram5493 Well-Known Member
    Rafael
    2017 Tacoma TRD Pro
    How did it work out for you. I'm considering installing these steps on my taco
