AMP RESEARCH POWER STEPS INSTALLED.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Scott W, Mar 1, 2021.
  1. Mar 1, 2021 at 4:49 PM
    Scott W
    Scott W [OP] Well-Known Member
    Scott
    Saranac Lake, NY
    2018 Tacoma TRD PRO. Calvary Blue.
    TRD Performance Air Intake. TRD Shift Knob. KTJO 4X4 Red TRD Push Button Start/Stop. Calvary Blue FOBIK by AJT Design. 12volt Solutions Remote Start with CAR:LINK Smartphone Remote Start and GPS app. Sprint Booster V3 Throttle Response Enhancer. AFE Silver Bullet Throttle Body Spacer 46-38010. 2" Supreme Suspension Lift Kit. TOYO 265/75R16 Open Country A/T2. EGR Matte Black In-Channel Vent Visors. REK GEN Offroad Mud Guards. AMP RESEARCH Power Steps. JDMastar 10000lumes LED Low Beam Lighting T1. JD Mastar Raptor LED Lighting. TRUXEDO Tonneau Cover.
    So I can't deal with side steps or step bars seeing how I live in the Adirondacks. They are nothing but snow, salt and frozen slush sand catchers. I've been considering power steps for a while. The few vehicles I work on that have them have held up well the last couple winters so I took the plunge. It took me about 5 hours to install and that includes a few extra steps of my own as far as 2K sealing the motors and weather sealing connections. Being able to maintain the hinge brackets they should hold up.
    I am really happy with the results and now my girlfriend, dog and son (and me) can get in my truck after the 2" lift.
    https://twitter.com/Scttwd64/status/1366569655024902144?s=19
    Kolohe07, VicNic3, tollster64 and 8 others like this.
  2. Mar 1, 2021 at 5:06 PM
    skibums_toyo
    skibums_toyo Well-Known Member
    Kevin
    2018 Tacoma TRD Off-Road Cement
    They look good.
    Scott W[OP] likes this.
  3. Mar 1, 2021 at 5:07 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Sweet
  4. Mar 1, 2021 at 5:09 PM
    mike s
    mike s Well-Known Member
    South Carolina
    2019 TRD OR
    Those look nice, and I like the color of the truck too
  5. Mar 1, 2021 at 5:12 PM
    averagejp
    averagejp Well-Known Member
    2005 Black Tacoma Extended Cab
    Work in progress
    This is a great solution for you ! Bravo!
    Question: Was it hard getting power to the steps? How was the product designed to make that happen?
  6. Mar 1, 2021 at 5:15 PM
    Scott W
    Scott
    Saranac Lake, NY
    Thx.
  7. Mar 1, 2021 at 5:16 PM
    Scott W
    Scott
    Saranac Lake, NY
    Thx
  8. Mar 1, 2021 at 5:16 PM
    Scott W
    Scott
    Saranac Lake, NY
    Thx
  9. Mar 1, 2021 at 5:23 PM
    Scott W
    Scott
    Saranac Lake, NY
    Not bad at all. The enclosed directions are good but I found a YouTube video which was really good. I also have over 30 years of auto electronics experience. Check the video out.
    https://m.youtube.com/watch?v=KqadENoyiuU
  10. Mar 1, 2021 at 7:31 PM
    Lancejoker
    Lancejoker Well-Known Member
    Lance
    Williamsburg,Va
    2017 TRD Pro
    These look great. Best looking option out there in my opinion.
  11. Mar 1, 2021 at 7:39 PM
    Scott W
    Scott
    Saranac Lake, NY
    Thx
  12. Mar 1, 2021 at 8:27 PM
    averagejp
    Work in progress
    You clearly have more skills than I do! Looks really good and that video was very solid !
    Scott W[QUOTED][OP] likes this.
  13. Jul 25, 2024 at 6:15 AM
    Dwreck1
    Dwreck1 Member
    2022 Tacoma TRD PRO
    I love my amp running boards, I found most running boards were to close to the rocker and useless. So happy with them
    Scott W[OP] and VicNic3 like this.
  14. Jul 25, 2024 at 9:35 AM
    Scott W
    Scott
    Saranac Lake, NY
    Can't beat them. I'm still really glad I went with these.
  15. Aug 4, 2024 at 5:37 PM
    Andretti
    Andretti Active Member
    Kansas City, Missouri
    2023 Tacoma TRD Sport, 2008 Shelby GT500
    I have an appointment to get mine installed tomorrow morning.
    I'm curious....did you opt for the bypass switch that allows you to either keep them in the up position, the down position, or lower when you open the door? I ask because I opted for the switch, but if you did as well, I'm curious as to where you had them install it.
  16. Aug 4, 2024 at 11:14 PM
    2020SilverSky
    2020SilverSky Well-Known Member
    Seattle. WA
    2020 TRD Off Road 4WD 6MT
    I have this option, definitely place the switch anywhere to the left of the steering wheel. That makes it super easy to drop or raise them without having to get inside the truck. Good example is when washing the truck, you can simply open the door and hit the button to drop both steps. It's also a convenient place to access it when exiting the truck. More often than not, I don't use the steps when exiting so you can hit the switch on the way out and keep them retracted.
    Another bonus to having the override switch, the steps drop low enough that they can be a cat thief deterrent. Lock them in the down position when you leave the truck and it would take an insanely skinny thief to squeeze under them, so they'd have to access from the front or rear which is not ideal for a quick getaway. It's not foolproof of course but I consider it an added bonus to having them.
    VicNic3 likes this.
  17. Aug 4, 2024 at 11:29 PM
    hersheck
    hersheck Well-Known Member
    mike
    23 Sport Lunar Rock DCLB
    just curious did you install or take it somewhere, and if so how much did it run you?
    considering getting these on my 23 sport
  18. Aug 5, 2024 at 6:04 AM
    Andretti
    I am having mine installed literally right this moment by a local shop. When mine is done, I'll let you know total cost.
    when I dropped it off, we discussed the switch placement and I too am having it done on the left near the traction control (going from memory at this moment) button where I have one blank spot.
    once they are done I’ll take it to another shop about 20 minutes away and leave it overnight so the new leather interior with heated seats can be installed
  19. Aug 5, 2024 at 7:19 AM
    Radd
    Radd Well-Known Member
    Santa Cruz Ca
    2023 Tacoma TRD Offroad
    Yup, great product....Not cheap but well worth it.
    I have them on my 23' Off Road and really like them. They tuck in nicely to the body of the truck so that you don't even notice them when not deployed. When open they sit low and wide giving the best foot placement of any side step I have seen. They work great for my disabled wife.
    Andretti likes this.
  20. Aug 5, 2024 at 8:27 AM
    Scott W
    Scott
    Saranac Lake, NY
    Andretti[QUOTED] likes this.
