Amber vs Selective Yellow
Discussion in 'Lighting' started by 95 taco, Sep 20, 2022.
  1. Sep 20, 2022 at 12:21 PM
    95 taco
    95 taco [OP] Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    I haven’t been able to find a lot on google, for those that use Amber and/or Selective yellow for fog/off road lights, is there any difference performance wise between them?
    I’m adding some driving lights to my motorcycle and I’m trying to decide between selective yellow and Amber, the selective yellow looks better to me but if I got the Amber lens I could set it up as a turn signal, so the deciding factor to me is visibility in fog/rain/dust.
  2. Sep 20, 2022 at 2:52 PM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    M9nochromatic amber will perform slightly better in heavy airborne dust/snow/rain, however it offers much less useful information for you to interpret what you're able to see than selective yellow.
    Selective yellow is a legal fog color, amber is not federally speaking, unless your state regs (state mv codes can regulate passenger vehicle fog/aux.driving lights) allow it or have no standard for some reason.
    Both will result in significantly less glare from retroreflecrive signage or blue-metallic based reflective paint. In my experience you'll still clearly illuminate such signage/markings with SY, but its dimmer and much easier on the eyes. "The glow that illuminates vs the glare that obscures" kinda thing. Amber should be even less reflective, as its monochromatic.
    Some light manufacturers offer yellow/selective yellow but call it "amber," so that makes comparisons a bit more difficult between offerings.
    Neither amber nor selective yellow is legal as an auxiliary highbeam color, federally, so if you are looking at actual driving lamps in either color, be prepared for potential for LE interactions. Check your local/state/province regs.
  3. Sep 20, 2022 at 6:13 PM
    95 taco
    Thanks for the info @Toy_Runner i went ahead and ordered the selective yellow lenses.
    Local LE doesn’t care about lights, in my state laws are very vague and there aren’t many on the books.
    I did find this little tidbit:
    “(4) Any lamps illuminated when the vehicle is in motion, other than those expressly required or permitted by the provisions of this chapter or other law, shall, if visible from the front, display only a white or amber light;  if visible from either side, display an amber light;  and if visible from the rear, display a red light.”
  4. Sep 21, 2022 at 7:09 AM
    Toy_Runner
    99 4Runner SR5
    Which state? I can poke around and see if I find anything
  5. Sep 21, 2022 at 7:12 AM
    95 taco
    Mississippi
  6. Sep 21, 2022 at 10:04 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Selective yellow is the correct choice. The minor gains in poor weather performance for lower wavelength amber are easily negated by the monochromatic color interpretation, so selective yellow will be higher performing. There are also very few products available in actual amber, vs a significant growing number in selective yellow.
    Examples:
    Amber: KC Amber
    Selective yellow included here: Diode Dynamics SS3
    Toy_Runner and Puppypunter like this.
  7. Sep 21, 2022 at 10:49 PM
    GRN305L
    GRN305L Well-Known Member
  8. Nov 11, 2022 at 9:01 PM
    ODSC1
    ODSC1 Well-Known Member
    London ON
    2017 DCSB Sport MT
    I have selective yellow DD fog lights and would like to add a DD 30 inch light bar. The light bar as per DD is available in amber or white. Is there less of an advantage for selective yellow in a bar vs pods?
  9. Nov 12, 2022 at 8:27 AM
    95 taco
    I believe the form factor doesn’t really matter, I have the selective yellow lenses for my D3’s and then I ordered some Amber D3 fog lights that I’ll be using as additional blinkers and fill light. I’ll be able to compare Amber and selective yellow a bit better.
