Amber Fog Lights 3rd Gen Recommendations
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BigE4115, Mar 19, 2019.
  1. Mar 19, 2019 at 12:18 PM
    BigE4115
    BigE4115 [OP] Member
    Ethan
    Pittsburgh
    2016 Silver 4WD Access Cab SR
    Anybody have any good recommendations on 3rd gen fog lights that will fit in the stock bumper without any cutting or anything? I've heard amber is better than clear but not entirely sure what I should do. Thanks in advance.
  2. Mar 19, 2019 at 12:19 PM
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    Nokya NOK7618 Halogen Bulb https://www.amazon.com/dp/B000U3TTN6?ref=ppx_pop_mob_ap_share
    I have these and love them! Cheap and an improvement over the stock bulbs. Definitely recommend.
  3. Mar 19, 2019 at 12:20 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  4. Mar 19, 2019 at 12:21 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Amber is better but get clear and put Amber film over them. Get some KC Hilites G4 in clear.
    Taco1.1, crashnburn80 and tonered like this.
  5. Mar 19, 2019 at 12:21 PM
    Onwarrds
    Onwarrds @onwrrds
    Tyler
    Southern California
    2017 Black TRD OR 4x4 DCLB
    Fox 2.5 DSC Adjusters (Extended Travel), Camburg UCA, RCI Rear Bumper, Cali-Raised Zero Degree Step Rock Sliders (with filler plates), Softopper, TRD Pro Skid, Rigid, Baja and KC lights, H9 Headlight Upgrade.
  6. Mar 19, 2019 at 12:21 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Seventh, Taco1.1, Yann and 3 others like this.
  7. Mar 19, 2019 at 12:22 PM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    Best ones out there! I had a set of these in white which i recently swapped out for these amber lights and I love them!!!
    http://kustom54lighting.com/12-18-T...g-Lights-IN-STOCK-LIMITED-QUANTITY_p_355.html
    https://www.tacomaworld.com/threads/fs-morimoto-led-amber-fog-lights-preorder-gb.566140/
    Seventh and Yann like this.
  8. Mar 19, 2019 at 12:24 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  9. Mar 19, 2019 at 12:29 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Post 558 has a comparison on the amber Morimotos vs the amber G4s. The G4’s have 2x the pattern area coverage.
    https://www.tacomaworld.com/threads...fog-light-review.554813/page-28#post-19408787
    Clear G4s are definitely higher output, but if looking specifically for amber the amber G4s are the best so far.
  10. Mar 19, 2019 at 12:31 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    This will give a selective yellow output, which will be higher output than amber, but not amber in output.
  11. Mar 19, 2019 at 12:31 PM
    Dragonaut
    Dragonaut Well-Known Member
    Dennis
    SoCal
    2017 TRD OR AC (MGM)
    Baja Designs fog light kit ( amber wide cornering) . Plug and play. Lighting improvement is night an day from stock.
    medicfung likes this.
  12. Mar 19, 2019 at 12:33 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Baja Designs has not yet released their fog lights, they are due out in a few months. As covered in the linked threads the wide cornering pattern is not a fog pattern. It has no cut offs and blinds other drivers. Baja Designs warns users to not use those on the street with oncoming traffic.
    Tibetan Nomad and Midknight like this.
  13. Mar 19, 2019 at 12:34 PM
    BigE4115
    Ethan
    Pittsburgh
    Thank you all for the input. what about the best setup for around $100? I am wiring all of this myself so I'm already into it with some money.
  14. Mar 19, 2019 at 12:35 PM
    moe2o4
    Corey
    Pittsburgh PA
  15. Mar 19, 2019 at 12:38 PM
    Dragonaut
    Dennis
    SoCal
    Thanks for the clarification. I understand the actual lighting pattern/lighting zone might not strictly constitute a fog light pattern. I interpreted op as looking for lighting options that are intended to replace the factory fogs. I have found mine to be quite effective with increasing visibility in foggy conditions, they are aimed straight forward and only on a handful of occasions has anyone flashed there brights at me, usually its a lowered tuner vehicle that puts thier line of sight on the same axis as the beam pattern. However I typically use them in the same way you would brights,turning off and on as you encounter oncoming traffic. Appreciate the input though man
    crashnburn80[QUOTED] and tonered like this.
  16. Mar 19, 2019 at 1:44 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Just pointing out to others the pattern difference, which is very often overlooked when selecting a fog light. What helps in your case is that amber/yellow light is not as harsh on the eyes as the white/blue that human eyes are highly sensitive to, which makes the white/blue light much more excessively glaring.
    MESO, r1200gs4ok and Boghog1 like this.
  17. Mar 19, 2019 at 1:47 PM
    BigE4115
    Ethan
    Pittsburgh
    Thanks for all the help fellas. I ended up going with the Amber Morimoto's recommended by moe. The others were a little too pricy!
    EnBoo likes this.
  18. Mar 19, 2019 at 1:51 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Gotta pay for quality but it is what it is.
  19. Mar 19, 2019 at 1:57 PM
    BigE4115
    Ethan
    Pittsburgh
    fair enough. I think these will be a solid middle ground.
  20. Mar 19, 2019 at 2:36 PM
    NorthTexasTaco
    NorthTexasTaco Member
    Mathew
    2017 White Sr5 DCSB 4x4
    32in tires, 30in hidden lightbar, catback exhaust...
    Look up rago fabrication they have a kit with Baja designs led pod lights with an amber filter on them. Took less than an hour to put on and no need to rewire or cut anything
