Amazon Prime Day Deals? Anyone seen any?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by VERTIGO, Jul 12, 2023.
  1. Jul 12, 2023 at 9:32 AM
    VERTIGO
    VERTIGO [OP] Just a guy with a Tacoma. WA STATE.
    ALEX
    Seattle Area, Washington
    2022 DC LB
    Prinsu Roof Rack, Roof Rack Light Bar, MaxTraxx Mounted, Tint, Hidden Light Bar, Trd Pro Grill, Trd Pro Skid Plate, Demon Mounts and Shackles, Window Guards, Baja Design Fog Lights, Baja Design Ditch Lights, Roam Adventure Box, Air Raid Snorkel, METHOD 703 on Atw4 33s, Relentless Fab Front/Rear Bumpers And Swingout, OME BP51s, Warn 10s Winch, Meso Customs tail lights,etc
    Anyone seen any good Amazon Prime Day deals? Looking for any cheap accessories or anything bigger mods that are a good deal. Feel free to post them.
  2. Jul 12, 2023 at 9:33 AM
    Tacospike
    Two Trucks
  3. Jul 12, 2023 at 9:54 AM
    Hogleg918
    Hogleg918 Well-Known Member
    Oklahoma
    Ranger Raptor, sorry TW
    I ordered 15 Mach3 razor blades for $17 with tax, I feel great about it.
    Rhody929, Kolohe07 and bkhlrTaco's like this.
  4. Jul 12, 2023 at 10:14 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
  5. Jul 12, 2023 at 10:18 AM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
  6. Jul 12, 2023 at 10:18 AM
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    Xx_Evilvirus_xX likes this.
  7. Jul 12, 2023 at 10:56 AM
    Silver-Taco1
    Silver-Taco1 Well-Known Member
    I bought some bluetooth speakers for my bug @ 60% off.
    BTW-- this is the wrong category for the topic.
  8. Jul 12, 2023 at 11:16 AM
    ayojiao
    ayojiao Member
    Some good discounts I saw were Tekton torque wrenches, Jackery's, pressure washers, and Meguiars/Chemical Guys products.
    808stateofmind likes this.
  9. Jul 12, 2023 at 11:26 AM
    Xx_Evilvirus_xX
    Xx_Evilvirus_xX Well-Known Member
    Houston, TX
    2018 Tacoma TRD Offroad 4x4
    Dang thats not bad. OEM is like 150-250 *cries*
    Rainoffire[QUOTED] likes this.
  10. Jul 12, 2023 at 11:34 AM
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
  11. Jul 18, 2023 at 5:37 PM
    FBHam
    FBHam Well-Known Member
    Jack
    SW Louisiana
    2023 Red Tacoma Sport DCSB
    How did this work out? I bought one - it is going back. One of the threads for a bolt that attaches the arm to the main body stripped well below the torque spec. Not the quality it needs to be. It was not well packed either. The box showed exterior damage, but the contents arrived undamaged. In any case, I'm not happy with what arrived.
  12. Jul 18, 2023 at 10:22 PM
    Rainoffire
    Mine arrived just fine, packaging was double boxed, so there was zero damage. I compared it to my OEM part, and other than it being painted vs powder coated, it was identical. The weight between them is off by an ounce or 2. The spring is also a little different, the faux step being louder when moving between positions.
    For the install, i used the upper part from the faux step and the lower part is OEM. I used OEM hardware too, so I had no issue. Was it the bolt itself that failed or the hole it threads into?
    So far so good. But my OEM broke after 4 years, so time will tell if it will last.
  13. Jul 19, 2023 at 10:27 AM
    FBHam
    Jack
    SW Louisiana
    It was double-boxed, although the outside box was more of a shell that was open at the top ends. The step was already mounted to the hinge, and had moved quite a bit in shipment, damaging the inner box. The step itself is in pretty good shape.
    The mounting bolts are in great shape - definitely not stripped. It is the top of the hinge is where they drilled the mount hole and tapped it where the problem is. Both bolts did not fit quite right, as if the tap was metric and the bolt is SAE. The one towards the left of the step is definitely stripped - at this point the bolt simply turns. There is some threading left, and it took a bit of work to remove the bolt. There is not enough strength to hold the bolt though.
    I can't say I am impressed with the workmanship of the step. Proper tapping and better casting of the arm would make it a better product. I'm trying to decide if I want to try a replacement or just get my money back.
  14. Jul 19, 2023 at 11:24 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    i got 100 for $7.99. but i use a DE razor. Wilkinson Sword.
  15. Jul 19, 2023 at 2:50 PM
    Hogleg918
    Oklahoma
    I shave my scalp, I’m open to trying new blades.
  16. Jul 19, 2023 at 7:13 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  17. Jul 19, 2023 at 9:14 PM
    Rainoffire
    I would try for a replacement, then if that fails, go for a refund. I guess the hassle is that you will have to pack and mail it out for the process to go through.
  18. Jul 20, 2023 at 6:04 AM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    Got my Düvkori® installed and added a privacy screen and drink holder. Added a one-gallon gravity fed hose along the side for rinsing.
    ricphoto, vivid02 and Xx_Evilvirus_xX like this.
  19. Jul 20, 2023 at 7:35 AM
    Rainoffire
    So I just tested out the hardware on the step that I didn't use. The bolts threaded in fine, but I noticed a problem with the little spacer that separates the step to the mount.
    The spacing between the holes is just too narrow, just ever so slightly too close to each other. Which would cause one of the bolts to thread in at an angle.
    You can move the spacer up the shaft, towards the non-thread part, then thread them in straight. Just tighten them evenly, it should go in without an issue. Or you can widen the holes so it isn't as tight.
  20. Jul 20, 2023 at 8:37 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    i returned my shitty germ guardian air purifier that was loud af and not very effective. went with a newer model Winix. I loved my last one but it started to stink after 4 years of constant use even with new filters. My old house was a bit musty and running with candles burning i think contributed to the smell.
    this is the model i got:
    https://www.winixamerica.com/product/5500-2/
    got it for $159.99
