Aluminum vs Steel: Animal Strikes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by boston23, Nov 20, 2020.
  1. Nov 20, 2020 at 5:02 PM
    boston23
    boston23 [OP] Well-Known Member
    Adam
    Bend, OR
    2019 SR5 DCSB 4x4
    Hey guys,
    Thinking i may finally buy a bumper this Black Friday. I live in a rural area and mainly want it for animal strikes (elk, deer, bunnies).
    I’d rather go aluminum to save weight.
    My question is:
    What are your thoughts on the strength of aluminum for protection against animal strikers at speed?
    Is steel really worth the weight? (No pun intended)
    I can’t imagine aluminum tubing bending very much more than steel when hitting an animal.
    Also, it appears to me that a “low center” tube may provide more radiator protection than the full hoops that go to the top of the grille. I could imagine a deer possibly still destroying a radiator through that space.
    Using Max Powell’s and Spartanx’s taco’s for examples of the two tube styles i mentioned
    Low center:
    Full hoop:
    Northerntaco69 likes this.
  2. Nov 20, 2020 at 5:06 PM
    9mmMike
    9mmMike Well-Known Member
    Michael
    SE PA
    2019 TRD OR 4x4 DCLB - Cement
    My opinion:
    Deer will usually go up and over.
    Most of the bumpers I see here are for anchoring a winch not for "hittin' stuff'.
    Both ally & steel bumpers will be ruined, at least cosmetically, by a strike.
    A bumper big enough to slap a deer down would be huge/heavy. Maybe an ARB.
    Of course I could be wrong.
  3. Nov 20, 2020 at 5:07 PM
    theluharlifestyle
    theluharlifestyle Well-Known Member
    Parth
    SoCal
    2019 DCSB TRD OR
    Honestly I think if you are that worried about damaging the vehicle on impact I would go steel. I’m not sure if this is valid or not but I think I remember seeing something about the ARB bumper being rated for impacts. Might be something to look into
    boston23[OP] likes this.
  4. Nov 20, 2020 at 5:11 PM
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    I have the CBI low tube , full aluminum bumper. It’s noticeable lighter vs Steel ( friends have honey badger steel on their 3rd gen as my comparison). I have hit bushes , and small trees with it , zero issue. I have scraped / dropped down on rocks on the under side and no issues. It’s very thick aluminum so it’s not fragile.
    i say if it’s a part that will see a lot of sliding against rocks it should be steel . My rear CBI high clearance Bumper is Steel and my rock sliders are steel. For a front bumper I don’t think it will see a lot of sliding action on trials vs sliders , skids or rear bumpers so Aluminum is ok in that case ?
    don’t underestimate the impact weight will have on your front suspension and handling... especially weight that is distributed way out in front of your tires (balance , leverage )
    Vmax88 and boston23[OP] like this.
  5. Nov 20, 2020 at 5:18 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Seen these deer yesterday evening.
  6. Nov 20, 2020 at 5:21 PM
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    If it’s a hybrid, you’ll bend a wing. Dead center, you’ll be fine.
    If it’s aluminum full plate, you’ll probably bend a wing or crack a few welds. Dead center you’ll be fine; maybe a dent or something.
    If it’s a full steel plate, there’s a chance you’ll bend a wing, but odds if it being straight are high. Dead center you’ll be fine.
    If it’s an ARB, it lol’d @ the deer.
  7. Nov 20, 2020 at 5:26 PM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    TITLE ONLY: STEEL!
    Ive bounced a few deer off my SOS steel bumper! Never any major damage only a thick of fur here or there!
  8. Nov 20, 2020 at 5:27 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    i tape tree branches to my tires to avoid these occasions
  9. Nov 20, 2020 at 8:49 PM
    GladiatorNOT
    GladiatorNOT Well-Known Member
    2017 TRD OR
    Old Man BP51 coilovers Dakar HD leaf springs Icon Delta control arms TRD Pro rims with Kenda Klever RT 33x10.5 tires Exhaust mod TRD front skid, RCI tranny and transfer case skids Southern Style Slimline front bumper Baja Designs S8 bumper light Warn Zeon Platinum 10s winch 4.88 Nitro gears ARB front locking differential ARB twin air compressor X2 Power 27 battery RCI rear bumper with Rigid SRQ lights RCI rock sliders RLD canopy Dometic CFX3 55 refrigerator TRD Pro grill Front & Rear anytime camera Seat Jackers Diode Dynamics Pro fogs
    Could you post some pictures of your bumper? I’m thinking about moving on from my SSO Slimline to a CBI Baja aluminum with the low bar. Like the looks of this bumper along with the weight savings. Can also use the 20” Baja light from my current bumper and my Diode Pro fog lights also.
  10. Nov 21, 2020 at 11:52 AM
    boston23
    Adam
    Bend, OR
    2019 SR5 DCSB 4x4
    That’s what i’m thinking. Having the aluminum would still provide a ton more protection than stock... and having steel hanging way out on the front end sounds like it would negatively impact performance
    Luke-Maine likes this.
  11. Nov 21, 2020 at 12:16 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    @GladiatorNOT - Dibs on the SSO Slimline! (If you decide to let go...) Does it have wings? Loop? I'll look for pics...
