Aluminum fender liners
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Formidable, Apr 15, 2019.
  1. Apr 15, 2019 at 6:31 AM
    Formidable
    Formidable [OP] Well-Known Member
    2017 TRD PRO 6MT
    Trying to gauge interest in custom aluminum fender liners for the Tacoma. These are popular with the Jeep crowd but for some reason not a thing with Toyota’s. Probably because no one makes them.
    RCR4WD presently makes these out of mild steel which in my opinion is prone to rock chips damaging the powder coating with resultant corrosion. I am trying to get these guys to make them out of lightweight aluminum. They said not unless there is significant interest. As you can see, these offer significantly more protection than the stock liner. Total surface area is 90% vs 33% with the OEM liner. There were concerns about bolting the body to the frame. These are secured with rubber grommets and designed to flex. There is no metal on metal rubbing. Additional request for more UCA clearance for those with aftermarket UCA’s that need more room to adjust, and another request to make the cutouts perforated or mesh to allow more air flow through the radiator will be available. There is no increase in road noise on the highway due to rocks. Off-road obviously this changes.
    I have no affiliation with the fabricator. I just want the product made.
    This spans other models that share the same platform including the GX460, 4th and 5th gen 4runners, Tacoma, and FJ. The interest is already significant, (halfway point in one day).
    PM me for more details.
    Tacomajunkie likes this.
  2. Apr 15, 2019 at 6:35 AM
    Formidable
    2017 TRD PRO 6MT
    Mesh style to allow more air flow to radiator pictured below. Won’t look exactly like this as the mesh will likely be in the form of cutouts but you get the idea.
  3. Apr 15, 2019 at 6:38 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    Is there any practical advantage to these besides bling?
  4. Apr 15, 2019 at 6:41 AM
    Formidable
    2017 TRD PRO 6MT
    They look spiffy but there is a functional component here.
    These will reduce the amount of water, mud, rocks that sling into the engine bay. If you look at the bottom of any 100k mile Tacoma or 4Runner you will notice the bottom of the engine has rust due to exposure to the elements and heat cycles. Some folks fender liners are getting beat up and they want a metal option.
    12TRDTacoma likes this.
  5. Apr 15, 2019 at 6:50 AM
    Bobby18
    Bobby18 Well-Known Member
    Bobby
    2008 Tacoma Prerunner
    DTF +6 LT, Kings 2.5x10 C/O, 2.5x2 Bump, Adv Fiberglass 1 Piece Conversion
    Id be down for a set, I know someone on here sells precut rubber ish ones already
    12TRDTacoma and Formidable[OP] like this.
  6. Apr 15, 2019 at 7:02 AM
    Bobby18
    Bobby
  7. Jul 19, 2020 at 6:00 PM
    SuperRAD
    SuperRAD Member
    I'd buy a set
  8. Jul 19, 2020 at 6:58 PM
    summithightacoma22
    summithightacoma22 Well-Known Member
    michael
    denver
    2013 grey tacoma trd sport
    front +2 allpro long travel with kings. Marlin crawler lca reinforcements, alpine design cab mount. All pro spindle and upper control arm reinforcements. Willwood 6 piston front calipers and 2 piece rotors. rear 7 pack expedition soa, 12 2.5s, archive garage shock relocation kit. Archive garage shackle flip kit. wheels 285/75/17 geolander g0003 on 17x9 with a zero offset. engine bay. antigravity atx hd-20 lithium battery arb high capacity air compressor. 3* exhaust cam timing. intake spacer custom stuff custom made sliders, custom bed rack system, custom drawer and bed system, modified mounts for arawak awning. Fiberglass/lexan cap door. Boxed out frame in spots I could reach. soon to be a chopped bed at the rear axle interior -lathewerks co polymer stainless shift knob, modified from a wrx to fit. -pioneer mid and treble speaker replacement. -future mods -4.56 gears arb front and rear lockers -traction bar for the rear. -full carbon front clip. -supercharger eventually.
    I would be extremely interested in a set.
  9. Jul 19, 2020 at 7:11 PM
    tx novice
    tx novice Foward momentum
    Ron
    OAHU
    11 DC 4X4 TX PRO silver
    Trd, Cal Tech, Weather tech, Viper, Al's tinting . L.E.D's , Hide a Hitch or Chrome Stinger , Walker Evans Resi's w/AllPro 3" lift ,FLM, ProComp Xtreme MT2 , Diff Breather Mod, 4x4 Switch Light mod, Plastic Derped. Trailer Socket Relocate mod via Miles , 4:56 G2 gears. Blue Intake Spacer, S.S. Brake Lines F&R, Sway Bar Deleted, Roll-X, Pop-N-Lock Electric. Red metal TRD badges. Paid Off Mod- Chee Hu, Superbumbs(f),Timbrens(r).Pelfrey Bilt, Bamf, Urd. Cobra Heat Shield.CMC .Mishimoto (custom bracket by Nate), Powerstop, Rampage 50".Depo Taillights,SPPC Black Headlights, Rigid Industries. Factor 55.American AirFlow.
    So would I :thumbsup:
  10. Jul 19, 2020 at 9:20 PM
    crtx
    crtx Well-Known Member
    Also Intrested.
  11. Jul 19, 2020 at 9:33 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I would be very interested as well.
    Then again, the fact I don't have liners on mine is not so much a bad thing either because it sure does make it easy to work on since it allows so much access to the side of the engine bay.
  12. Jul 19, 2020 at 9:53 PM
    DJSpeed
    DJSpeed Well-Known Member
    So where do we biy these?
  13. Aug 3, 2021 at 10:32 AM
    Soulstice07
    Soulstice07 Well-Known Member
    Granite Falls, WA
    2010 TRD Off Road
    6" Pro Comp lift KMC 17x9 XD137 FMJ Wheels 35" Mastercraft tires Custom Bilstein extended length adjustable coilovers 700lb Eibach springs Bilstein rear shocks DV8 Off Road front bumper Custom skid plates/armor Smittybilt 10klb winch Cali Raised LED sliders Cowl air induction ABS kill switch Rear air ride suspension Trailer plug relocate Clazzio leather seat covers Various lighting mods
    Any progress with these? I would definitely be interested in a set!!
  14. Aug 3, 2021 at 11:05 AM
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    I'd buy a set!
  15. Aug 8, 2021 at 8:10 AM
    Doublecross
    Doublecross Well-Known Member
    Robbie
    New york
    Work in progress
    ARE cap, wade inchannel vent visors, weathertec floor mats, ranch hand grill guard, tuffy security boxes in bed, lockable tailgate handle. Still have stuff that needs to be installed and still have stuff ordered lol.
    just front or front and rear?
  16. Aug 8, 2021 at 10:00 AM
    Soulstice07
    Granite Falls, WA
    2010 TRD Off Road
    Are there supposed to be liners in the rear? I never had any
  17. Aug 8, 2021 at 10:07 AM
    Soulstice07
    Granite Falls, WA
    2010 TRD Off Road
    I guess if you're talking full liners in the rear, im just looking to replace the fender flaps in the front that always seem to come loose. Not looking to replace the entire fender liners
  18. Aug 8, 2021 at 10:50 PM
    dirtydan2008
    dirtydan2008 Well-Known Member
    Dan
    Bellingham Washington
    2014 TRD OFF ROAD TACO
    bunch of stuff goin on
    looks like another thing to rattle around and drive me nuts. I opted to buy shower pan liner from Home Depot and make some better skirts to fully block out mud dirt etc
    Island Cruiser likes this.
