Alternator Wire Fire ...?
Discussion in '1st Gen. Tacomas (1995-2004)' started by moweebo, Sep 11, 2018.
  1. Sep 11, 2018 at 5:09 PM
    moweebo
    moweebo [OP] Member
    Sooo my alternator wire caught fire today...any idea of why or how this could happen?
  2. Sep 11, 2018 at 5:16 PM
    2JHilux
    2JHilux Level 8 Tinkerer
    Denver, CO
    2001 Tacoma Double Cab 4x4
    manual swap in progress
    if the shielding degrades or any reason that wire touched the side of the alternator, it would melt and/or catch fire cause that is a power wire and the alternator case is grounded.
    maybe it was tight and rubbing against it for some reason, may have not been put back on properly? not sure
  3. Sep 11, 2018 at 5:19 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Battery secured? Hit a good enough bump and jostle those wires, it could cause it short out and burn.
  4. Sep 11, 2018 at 6:12 PM
    Indy
    Indy Master of all I survey.
    Easy, the wire got took hot. :)
    But that is likely just a corroded connection.
    License2Ill likes this.
  5. Sep 11, 2018 at 11:39 PM
    moweebo
    moweebo [OP] Member
    After closer inspection it appears the insulation wore off and was creating an arc with the shield. Luckly i wasnt driving far and caught it before it got to bad. I wrapped it with electrical tape for now to prevent further arcing but eventually i would like to replace the whole wire.
