Alternator smoking after jump start...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by philwill, May 6, 2020.
  1. May 6, 2020 at 10:28 AM
    philwill
    philwill [OP] Well-Known Member
    Phillip
    Atlanta, GA
    '07 TRD Offroad
    '12-'15 front end swap, 255/80/17s on stock suspension
    So I'm pretty sure I toasted my alternator but curious to hear what everyone thinks.
    I stopped to help a stranded driver this morning, it was a diesel V8 F-250. He asked me to give him a jumpstart. He had dual batteries and we hooked up my truck to one of his batteries. Our trucks were probably hooked up for 10+ mins and several times I revved mine up and held it at 2-3k rpm to try to charge his... Not sure if that was the wisest thing.
    After that, my battery warning light came on the dash and I started hearing what sounded like the bearings on the alternator or something went out. And then it started smoking. I shut it off and the alternator smoked for a good 30 minutes. A tow truck just picked it up and took it to a local shop. I'm waiting to hear but I assume it just needs a new alternator. I have the tow package with the high output alternator. I told the shop I want another OEM Denso put on.
    Anybody ever had this happen before? The shop said it'll be in the $500 range to get this done. Called my local Toyota dealer and they said the 130amp alternator is $327.84.
    OldManTacoFeels likes this.
  2. May 6, 2020 at 10:50 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Did you connect battery to battery?
    And did you get the other truck started?
    No, fortunately I have never had this issue.
    I try not to ever jump battery to battery.
    It’s always better to jump from an external (Off battery) ground location.)
    Here is an example.
    The credit for the picture goes to https://bestjumpstarterreview.com/how-to-properly-connect-the-jumper-cables/
    BTW, I think you did a good thing asking for a OEM Alternator.
    You will save yourself lots of trouble later.
    And Thank You for actually helping some one.
    It’s hard to find someone that’ll help these days.
    Sorry it cost you an alternator. That’s sucks.
    (Truthfully, I do get really nervous every time I jump start someone)
    06Tacooo, 74cam, ChamYota and 11 others like this.
  3. May 6, 2020 at 10:55 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    This ^^^^^^^^
    I agree it was cool of you to help also.
    Gunshot-6A, JimIowa and TnShooter like this.
  4. May 6, 2020 at 10:58 AM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Never seen this. But interested to see why it happened
    Gunshot-6A likes this.
  5. May 6, 2020 at 11:00 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Battery jump pack for the win.
    t.hornstra, Fitz235, SC4333 and 14 others like this.
  6. May 6, 2020 at 11:03 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    It sounds like something in the circuit was shorting the alternator straight to ground. You might have them check the wiring between battery and alternator too - if the battery is fine and the alternator is toast, that suggests they weren't connected.
  7. May 6, 2020 at 11:03 AM
    TnShooter
    Deogee
    STOCK
    I going to say it had to do with the 10 mins. of “charging” the other guys battery.
    OP’s Alternator was “taxed to the max”.
  8. May 6, 2020 at 11:07 AM
    philwill
    Phillip
    Atlanta, GA
    '07 TRD Offroad
    We were hooked up battery to battery. And yeah eventually he did get started. Thanks for the info! I need to start hooking up that way from now on.
    I agree, after this I'm gonna be very nervous ever jump-starting someone again
    jetfishn and TnShooter[QUOTED] like this.
  9. May 6, 2020 at 11:10 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Sounds like you already know what happened. Ask the dealership if that price is for a new or reman OEM 130A alternator. I thought new isn’t available anymore and if it’s reman you’re getting ripped off.
    FWIW, I keep a battery jump pack in my truck at all times to avoid this stuff and also to help myself if needed of course
  10. May 6, 2020 at 11:11 AM
    0xDEADBEEF
    The key is is the order that you make the connections - 1, 2, 3 4 in the picture. And the idea is to get number 4 far away from the battery, just in case the battery blows up. It doesn't really affect the survival of your alternator, but it will keep acid out of your face.
    azreb and TnShooter[QUOTED] like this.
  11. May 6, 2020 at 11:13 AM
    philwill
    Phillip
    Atlanta, GA
    '07 TRD Offroad
    Yeah I think I'll definitely be picking up a jump pack so I can help people out without the risk.
    What kind of jump packs do you guys have? Are those new compact ones any good or should I stick with one of the larger ones? We have a 3 cylinder diesel Ford tractor at home that needs to be jumped pretty frequently in the winter
  12. May 6, 2020 at 11:17 AM
    TnShooter
    Deogee
    STOCK
    I understand that buddy.
    My Grandfather passed away. He had a Tahoe that set for a little while.
    My Grandmother (bless her heart) tried to jump it off. Unfortunately she hooked the cables up BACKWARDS. It cost her a lot to fix. I can’t remember what all need to be replaced.
    If I jump someone, I usually insist they let me do the “hook up”.
    Most people try help, and that isn’t bad thing, but you never know what the other person does or doesn’t know.
    Hope you get it fixed soon. And for a cheap as possible. (Using quality parts of course)
    Fitz235, Astr0Aar0n and JKU3000 like this.
  13. May 6, 2020 at 11:19 AM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
  14. May 6, 2020 at 11:19 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    NOCO Boost GB40. 1000A unit and has started everything I’ve needed.
    Edit: Two guys I know work for a repo company and they run this brand.
  15. May 6, 2020 at 11:19 AM
    T4RFTMFW
    I’ve never had an issue jumping, but I don’t jump diesels and have no desire to.
    Chako, 12TRDTacoma and JKU3000 like this.
  16. May 6, 2020 at 11:21 AM
    philwill
    Phillip
    Atlanta, GA
    '07 TRD Offroad
    Haha I wish we had talked yesterday!
    JKU3000 and TnShooter like this.
  17. May 6, 2020 at 11:43 AM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Funny not really but the comments on the diesel.
    Could the glow plugs have had something to do with it?
    The capacitor pack I have has a function for glow plugs.
  18. May 6, 2020 at 1:54 PM
    gasgasman
    gasgasman Well-Known Member
    Do the math.
    The diesel has 2, 1000A batteries
    Taco 1, 800A battery.
    Basically, the Taco was overloaded.
    Chako, wilcam47, b_r_o and 1 other person like this.
  19. May 6, 2020 at 2:35 PM
    MR5X5
    MR5X5 Well-Known Member
    That's not the way it works.
    Bob K, Gunshot-6A, BKinzey and 2 others like this.
  20. May 6, 2020 at 2:50 PM
    CTtoNoVa
    CTtoNoVa Well-Known Member
    2017 DCSB TRD OR Magnetic Gray
    Pop N Lock
    Agreed. Ugh I rolled up the other day on two people. This guy was trying to jump his car off this other ladies car with really thin cables and it wasn’t working wasn’t working. I then bring out my heavier gauge wires and let them do the hookup since it was their cars. The dude starts going battery to battery and I told him he should ground to the block or unpainted metal on the dead car... he told me I had no idea what I was talking about....the car started battery to battery with my cables and he looked at me and said “see?”.
    I explained the grounding to the block is better practice not that battery to battery wouldn’t work. Oh well...
    Skyway likes this.
