Alternator not charging battery (fixed)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yota80482, Dec 17, 2023.
  1. Dec 17, 2023 at 3:13 PM
    Yota80482
    Yota80482 [OP] Member
    Cory
    06 tacoma
    Hey a week ago my battery light came on the dash. Had battery checked it was bad, brought a new battery and the light stayed on. So I brought a new alternator and I’m having the same issue. Please help
  2. Dec 17, 2023 at 3:51 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
  3. Dec 17, 2023 at 6:03 PM
    Yota80482
    Cory
    06 tacoma
    @Dm93 so do you think there’s an issue with the grey wire. This is the second alternator and the 1st battery. That day after replacing the first alternator I drove a hour away and the truck started to cut off after draining the battery.
  4. Dec 17, 2023 at 6:05 PM
    Yota80482
    Cory
    06 tacoma
    @Dm93 the rpm’s dropped and the truck bogged down. I’ve seen on some post people would say they cleaned the throttle bottle and it stopped the issue. I’m just not sure why the alternator isn’t charging the battery.
  5. Dec 17, 2023 at 6:11 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Does the charge warning light come on with the key on?
    Have you checked the other wires like I outlined in the thread I posted above?
    That will happen when battery voltage is extremely low.
  6. Dec 17, 2023 at 7:57 PM
    Yota80482
    Cory
    06 tacoma
    @Dm93 yes when I turn the key forward the battery light illuminates and stays on.
  7. Dec 17, 2023 at 8:01 PM
    lr172
    lr172 Well-Known Member
    ‘11 DCLB 4.0 Auto
    Need to check the alt fuses. There are two of them and either being blown will create this issue. The big one doesn’t look like a typical fuse.
    Dm93 likes this.
  8. Dec 17, 2023 at 8:14 PM
    Yota80482
    Cory
    06 tacoma
    @ir172 I checked the 140 A alt fuse but doesn’t appear to be blown, the 7.5 A alt-s fuse looks good,30 A batt chg looks good.
  9. Dec 18, 2023 at 3:35 PM
    Yota80482
    Cory
    06 tacoma
    Could this be my problem?
  10. Dec 18, 2023 at 5:07 PM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    I hope you figure this out but I learned the hard way that using a non-oem alternator is not the best choice when my original alternator finally took a dump at 400,*** something miles. good luck
  11. Dec 18, 2023 at 6:29 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Have you checked everything at the alternator???
    At the alternator connector:
    Pin 1 (White) should have power at all times.
    Pin 2 (Light Green) should have power with the key on.
    The main wire attached to the stud on the back of the alternator should also have power at all times.
  12. Dec 18, 2023 at 9:07 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Most autozone type shops will check the charging system at no charge. Unless you didn't install the alt correctly, or damaged something in the process, my guess is the new alt is bad.
  13. Dec 19, 2023 at 9:23 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Did you check it with an ohm-meter or just eyeball it?
    With the eyeball it may appear to be a good fuse and still be blown.
    Clearwater Bill likes this.
  14. Dec 19, 2023 at 1:50 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    This x2……..
    That light green wire has been known to corrode inside the sheathing.
    How it happens, I don’t know. But it’s happened enough that it’s not “uncommon”.
    Jimmyh likes this.
  15. Dec 22, 2023 at 4:06 PM
    Yota80482
    Cory
    06 tacoma
    @Jimmyh I checked by just eyeballing it. I sent it to the shop but the guy showed pictures of the battery and the alternator both tested positive. Tomorrow I will pull the 7.5 and alternator fuse and ohm them out. Thanks for the help.
  16. Dec 22, 2023 at 4:08 PM
    Yota80482
    Cory
    06 tacoma
    @TnShooter can you explain how to test them use the multimeter please?
  17. Dec 22, 2023 at 4:14 PM
    Yota80482
    Cory
    06 tacoma
  18. Dec 22, 2023 at 4:14 PM
    Yota80482
    Cory
    06 tacoma
  19. Dec 22, 2023 at 4:15 PM
    Yota80482
    Cory
    06 tacoma
    All of my wires are the same color.
  20. Dec 22, 2023 at 5:09 PM
    TnShooter
    Deogee
    STOCK
    Unplug this connector.
    Turn key on, check for 12v on green wire.
    Yota80482[OP] and Dm93 like this.
