Alternator brush lifespan
Discussion in '1st Gen. Tacomas (1995-2004)' started by Old n' slow, Jun 18, 2021.
  1. Jun 18, 2021 at 7:00 PM
    Old n' slow
    Old n' slow [OP] Well-Known Member
    Oak Island, N.C.
    2000 Tacoma 2.4 5 speed flare side
    I just replaced the brushes on my 140,000 mile Tacoma (stock, no heavy amperage draw items). I’d estimate I could have gone another 30,000-40,000 miles on the original brushes..... Maybe this information might help someone out there.
  2. Jun 18, 2021 at 8:22 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    That sounds about right. I've had them go bad around 135,000 miles on some older Toyotas, so depending on how much you use electric accessories 130,000-180,000 is about the range. I'd recommend everyone check and replace them before that instead of waiting until they go bad.
  3. Jun 19, 2021 at 1:59 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Like you said OP it all depends on electrical draw.
    Last I got Brushes from Toyota they were a module you just replaced making it a very easy job.
    Running Board Man likes this.
  4. Jun 19, 2021 at 10:10 AM
    Running Board Man
    Running Board Man Well-Known Member
    Made it to a little under 300k on my 95
  5. Jun 19, 2021 at 12:57 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 405K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    My brushes lasted 19 years, 324,000 miles in my original Denso alternator. When they finally wore out I replaced the alternator with aftermarket and then cleaned and refurbished the original with the brush kit sold by Toyota. It's in the garage sitting as a spare.
  6. Jun 19, 2021 at 10:38 PM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    Mine went to about 325K. Of course they start going out in the dead of winter! I replaced them in an evening after dinner, that included cleaning up the commutator. Should be good for the next 300k!
    On my other truck, I proactively replaced at. 150k since I had the alternator out doing the timing belt and was doing the “big 3” upgrade.
  7. Jun 26, 2021 at 2:52 PM
    AviateGW
    AviateGW Well-Known Member
    Glenn
    Atlanta area
    Black '99 3.4 SR5 4x4. OME/Dakar
    16x8 KONIG Countersteer Offroads from FN, OME/881s in front, OME shocks/Dakar leafs in back. K&N CAI, and last, but not least, TRD Shift knob.
    How do you replace the brushes?
  8. Jun 26, 2021 at 3:36 PM
    Potomus Pete
    Potomus Pete Love my little truck
    Hippy
    Sarasota Florida The Great Place To Live.
    1999 Prerunner single cab. With a BO7A rear end
    All kinds 3 inch body lift/2 1/2 suspension lift. 31/11 1/2/15 tires All work done by myself for years. The only work performed by mechanic was fuel pumps. I also have a 90 Mustang 350 hp and I can never understand how come my Tacoma gets more respect Just got a 99 Jeep TJ that I rebuilt, and painted in the garage
    Me too. When the time comes [so far 287,000] how easy to do brushes. When the time comes , it will be the wrong time of coarse
  9. Jun 26, 2021 at 3:52 PM
    MikeWH
    Colfax, CA
    1999 TRD 4x4 (x2)
    1-disconnect negative battery cable
    2- Remove alternator from vehicle
    3- remove end shroud from alternator, cleaning carbon dust as you go. Check for play in either bearing, replace them if needed
    4- 2 screws hold the alternator kit into the alternator. Remove those, pull old brush kit.
    5- gently clean commutator
    6-you have to use something to depress the brushes in the new kit. Install
    The brush kit and then allow brushes to spring against commutator.
    7- remainder is reverse of a above. If you messed up your battery light will stay on.
    Kiloyard and Potomus Pete like this.
  10. Jun 28, 2021 at 9:32 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Timmy the Toolman made a 29-minute video about replacing alternator brushes. Why don't you check it out (on YT, of course. Here's something to get you started.
    Potomus Pete likes this.
