Alternative to waiting for 105 - 113 Trans Temp to check fluid
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ChrisK7UND, Nov 3, 2016.
  1. Nov 3, 2016 at 12:59 PM
    ChrisK7UND
    ChrisK7UND [OP] Well-Known Member
    Colorado
    2017 Tacoma TRD Sport Double-Cab
    LED Interior Bulbs, Hondo Garage Phone Mount, Tacoma Bed Mat
    Pardon me if I am re-posting something that was already posted. The trick to checking the transmission fluid in these trucks without a dipstick is that they MUST be checked at the perfect temp range of 103 - 113 degrees of transmission temperature to avoid fluid from draining out due to fluid expansion. So, some dealers make you leave the truck all day in order to get it to the recommended temp. However, some dealers may have this alternative method. It uses an adjustable tube to compensate for the heat of the fluid. Brings the time down to around 30 minutes to check vs. all day. Now, the kicker? DOES your dealer have these tools and method. It may be worth asking. Either way, good video to better understand the reasons and how to properly check your fluid. I have seen a lot of conflicting info on these groups.
    https://www.youtube.com/watch?v=cNcecuGzTDg&feature=youtu.be
    Enjoy!
    monsterkx2fiddy and Joe23 like this.
  2. Nov 3, 2016 at 1:31 PM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Woah.. gonna need to go get another degree from Weber State... are you kidding me! What's wrong with a dipstick for crying out loud. Man I'm glad I bought a manual tranny.
    So the big challenge is the trans fluid expands when it's hot.. OK that's a little bit of physics that's been around... now that volume changes with air pressure .. in our case height above sea level, nothing new there either, different temps fluid expands differently... yup there's a law of physics for that.
    I guess it's harder to engineer a fluid without all the changes in density with temp and pressure than it is to develop a convoluted way of checking fluid level that requires a degree in mechanical engineering ... What am I missing?
    I went in to get my transmission fluid level checked and they ruined my transmission doing the check. Cross threading my trans axle fill plug now it's leaking fluid and I'm stranded with CEL and limp mode! Nice...
  3. Nov 3, 2016 at 1:32 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    saw in some post toyota has revised the temp to 95 degrees when checking. could check it on a hot summer day...
  4. Nov 3, 2016 at 1:34 PM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Don't manuals still have a dipstick?
  5. Nov 3, 2016 at 2:23 PM
    illogical
    illogical Well-Known Member
    2017 TRD 4x4 OR MT
    Hoping this is true, would greatly simplify the process.
    Or heres one... How about make the fill hole on the side the proper fluid level. Park on flat surface, transmission cooled, remove fill plug and add fluid until it spills out. Put the plug back in a call it done.
  6. Nov 3, 2016 at 2:26 PM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    automatic vehicle drivers cannot be trusted with that. that privilege is reserved for the obviously more knowledgeable manual transmission owners. :anonymous:
  7. Nov 3, 2016 at 2:29 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    sub'd
  8. Nov 3, 2016 at 2:32 PM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Transmission fluid doesn't expand that much at low temps (120*). Just check it and quit trying to over complicate things
  9. Nov 3, 2016 at 2:48 PM
    Syncros
    Syncros Well-Known Member
    Why not pre-warm the fluid?
  10. Nov 3, 2016 at 2:49 PM
    Aussiek2000
    2016 Offroad AC
    that's called driving it
  11. Nov 3, 2016 at 4:25 PM
    InSight Retrofits
    InSight Retrofits Closed
    A lot of cars have a section on the dash that says transmission temperature.
    A decent scanner when hooked to the OBD2 system will tell you transmission fluid temperature. So you can start it from cold with the scanner hooked up, wait for it to hit proper temperature and check it. Definitely wouldn't take long. But yes it would need to cool if you just drove it to the dealership.
  12. Nov 3, 2016 at 4:35 PM
    illogical
    2017 TRD 4x4 OR MT
    Hah! I knew I should have waited and got the manual. :annoyed:
  13. Nov 3, 2016 at 6:04 PM
    ChrisK7UND
    Colorado
    I like the idea of a scan tool. I know the Techstream is like 2K. Are there known scan tools that offer reliable data and ease of use?
  14. Nov 3, 2016 at 6:14 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Guys.. it only takes like 12-15 minutes of idling (on a level surface) to bring it to Temp Chk Range... then slide under and pull the plug... It ain't Rocket Science...
    SpaceTaco and Sixgun CO like this.
  15. Nov 3, 2016 at 6:26 PM
    ChrisK7UND
    Colorado
    I respectfully disagree. That check range is not very broad and I think using a scan tool to ensure you are in the range is the better way to go.
  16. Nov 3, 2016 at 6:42 PM
    over60
    Muskoka, Ontario
    Sorry, buddy... I'm talking about using a piece of wire in the OB2 hookup, and getting the truck into....Tranny Temp Mode... It's part of doing it right... All I was trying to say it only takes 15 min or so, but you got to get the truck into the mode first.
    I was trying to answer the scan tool idea... a 4" piece of wire will do what you want... read and learn... it's here !!
    Sorry if I was not clear.. Just addressing the "time" to get to temp...issue.
    SpaceTaco and monsterkx2fiddy like this.
  17. Nov 3, 2016 at 8:14 PM
    ChrisK7UND
    Colorado
    Oh cool. No worries. I'll look into that option to then. I just trust the dealer and I've built motors for years but all my stuff had dipsticks. :)
  18. Nov 3, 2016 at 9:01 PM
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
    Thanks for the video. That guy took forever. but really cool to see how they made a product to accommodate service departments and customers.
  19. Nov 4, 2016 at 6:57 AM
    TacoMan2017
    TacoMan2017 Well-Known Member
    All this BS could have been avoided by using a simple dipstick. Talk about complicating things for nothing...Come on Toyota!!!
    There's no common sense anymore.
  20. Nov 4, 2016 at 10:56 AM
    illogical
    2017 TRD 4x4 OR MT
    Serious question... hypothetically, if I were doing a drain and fill of the transmission fluid, even if the fluid was 108 degrees when I started the process the new oil going in would be ambient. How does the inner fluid level tube account for a fluid change at say 80 degrees? Or is the expansion difference so minimal that it doesn't matter below a certain temperature?
