Alternative to Sumosprings?
Discussion in 'Suspension' started by Taco_Ventures, Oct 30, 2024.
  1. Oct 30, 2024 at 9:35 AM
    Taco_Ventures
    Taco_Ventures [OP] Well-Known Member
    N
    SL, UT
    23 Taco OR DCLB
    Was going to replace the front bump stops with the sumo springs (SSF-604-40)- but have had a pretty shitty experience with them, so looking for an alternative.
    Essentially looking for a bump stop that is progressive and has a load bearing aspect. Currently running fox resi coilovers up front for about 2" of lift up front.
    Any recommendations would be appreciated.
  2. Oct 30, 2024 at 9:48 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Been very happy with my Wheelers up front (don't get them for the back though). Not sure they do any additional load (or why you'd need that up front as the coilover should take care of that) but you don't feel them ever <3.
  3. Oct 30, 2024 at 10:11 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Fox and Locked suspension 63's Skinny 33's
  4. Oct 31, 2024 at 6:07 AM
    Cal1630
    Cal1630 Well-Known Member
    1978 FJ40, 2018 Tacoma
    Fox 2.5 Performance Elite, Icon RXT springs, U-bolt flip, Pelfreybilt sliders, DeMello front bumper, BAMF rear high clearance bumper. OTT tune
    I am using the Sumo Springs bump stops. I am happy with them, they work as expected. Shipping when I ordered them in June 2024 took about a month.
    Taco_Ventures[OP] likes this.
  5. Oct 31, 2024 at 12:00 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Timbren Active Offroad front/back.
    BRFab and Taco_Ventures[OP] like this.
  6. Nov 16, 2024 at 6:06 AM
    Redsquirrel
    Redsquirrel Well-Known Member
    perryparts front and back
