Alternative to $587 Power steering return hose. Searched forums, no posts, this is the first
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NWONTaco, Apr 29, 2015.
  1. Apr 29, 2015 at 7:13 AM
    NWONTaco
    NWONTaco [OP] Well-Known Member
    Tony
    Thunder Bay Ontario
    2006 TRD crew cab V6 4x4
    265/70/R17
    So I'm getting the frame recall done on my 06 DCLB 4x4 4.0L. My mechanic calls and tells me the rack and power steering hoses should really be replaced, this is what they look like.
    Disregard the two hose running along the length of the rack, those will come with the new rack. Pay attention to the two hoses running out of the gear box (to the right of the pump pulley) The metal line coming out of the rack is the pressure hose which my mechanic told me is in great shape... GREAT! but the rubber hose that feeds up to the VERY rusty metal hose with green masking tape on it is the return hose which is GARBAGE.
    So I call around looking for an aftermarket return hose, Napa, Carquest, Part Source, Canadian Tire, Rock Auto...... NOTHING. (keep in mind in Canada)
    So I call the dealer.... this is where shit gets crazy. $587 dollars for a power steering hose assembly!!!!! F&%$ ME!!!!! the assembly is both pressure and return hoses assembled with brackets. Doesn't come any other way.
    So considering that the hoses will cost me more than the reman rack I just bought, I was wondering if there is an alternative to this? Can I make a hose? Are they any specific materials I must use (degradation issues with power steering fluid?). Considering that the return hose is rubber on both attachment points (rack and reservoir), can I just run a rubber hose straight from the rack to the reservoir?
    MTopp likes this.
  2. Apr 29, 2015 at 8:37 AM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    I'd see what your local hydraulic hose shop can do.
    Familyj, HisDad, asuchemist and 6 others like this.
  3. Apr 29, 2015 at 8:46 AM
    DanceswithWolves
    DanceswithWolves palabra a tu madre
    Jerry
    Roosevelt UT
    13 DCSB OR
    Agreed. I used to do engine swaps and RHD conversions on 240sx's and had a shop fab all my lines.
  4. Apr 29, 2015 at 4:49 PM
    NWONTaco
    Tony
    Thunder Bay Ontario
    265/70/R17
    So I found a hydraulic shop in town that can supply me with 3000 psi rubber tubing in the size that I need, I will keep the pressure hose, my mechanic removed it from the rack today and said everything came off clean.
    Would it be ok to use a rubber hose all the way back to the return? The only thing I would be concerned with is hydraulic jump (hose will jump during rapid pressure changes) but I think securing it well enough will rememdy this.
    Any suggestions?
  5. Apr 29, 2015 at 10:20 PM
    zeekevin
    zeekevin Well-Known Member
    San Diego
    i would ask if the dealer could goodwill the repair
  6. May 17, 2015 at 10:35 PM
    onedivinetaco
    onedivinetaco Well-Known Member
    botolphston
    '05 dcsb 4x4
    What happened here? I have the same issue with that hard/rubber line. It's leaking rather profusely.
  7. May 17, 2015 at 11:12 PM
    NWONTaco
    Tony
    Thunder Bay Ontario
    265/70/R17
    If its just your return hose then replace it with 3/8 transmission hose from any parts store, thats what I used and it works fine. Ziptie it back upto the resevoir
  8. May 18, 2015 at 6:03 AM
    white91formula
    white91formula Well-Known Member
    Boston, MA
    05 6speed TRD OR
    thats exactly what i did for the low pressure side, cost less than $20, no more leaks
    the local auto parts also had the high pressure line for $87
  9. May 18, 2015 at 8:40 AM
    onedivinetaco
    botolphston
    '05 dcsb 4x4
    I was thinking the same thing. Why can't I just cut the hard line, leaving some on both ends, and just slide in a fuel hose or so? I'm referring to the line with the tape from the OP's pic.
  10. May 18, 2015 at 8:41 AM
    onedivinetaco
    botolphston
    '05 dcsb 4x4
    Can you take a pic?
  11. May 18, 2015 at 10:09 AM
    NWONTaco
    Tony
    Thunder Bay Ontario
    265/70/R17
    Probably would be best you just replace the entire hose, 3/8 hose from napa will do the trick, and it fits the stock hose clamps.
  12. May 18, 2015 at 7:03 PM
    onedivinetaco
    botolphston
    '05 dcsb 4x4
    What did you end up doing?
  13. May 18, 2015 at 7:42 PM
    NWONTaco
    Tony
    Thunder Bay Ontario
    265/70/R17
    exactly that
  14. May 18, 2015 at 8:10 PM
    onedivinetaco
    botolphston
    '05 dcsb 4x4
    I now see I missed it in your first reply. Hooked on phonics! No problems with the flow using the rubber hose?
  15. May 19, 2015 at 5:40 AM
    white91formula
    Boston, MA
    05 6speed TRD OR
    nope its just the low pressure return line, mine has been like that for well over a year and its been disconnected a couple times (frame swap, rack bushings) and put back with no problems
  16. May 19, 2015 at 8:38 AM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    Tell the yoyo's (good name for dealer hands) that they caused the problem doing the frame job.......... Really! Everything is negotiable at this point I'd say.... go up to the sales department - do they want to sell more trucks? We could always "leak" the dealers name.......
    My old Dodge had this trouble (steering return line hose) and O-Reillys actually had kit of the right hose and clamps to fix it.
  17. Jul 14, 2016 at 6:40 AM
    NewfoundlandTaco
    NewfoundlandTaco Well-Known Member
    Newfoundland, Canada
    06 TRD Offroad Indigo Ink
    Billy 5100 at 2.5", 1.5" blocks, tailgate theft mod, extra bed D-rings. General Grabber AT2's.
    I am in the exact same boat right now, truck is on the lift and I can get a rack for 589 and Toyota wants 580 for the hose. Did they have any issues using a non Toyota part?
  18. Jul 14, 2016 at 6:43 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    I just take my old hose to the hydraulic supply store and they replace the bad sections with flex hose, as another poster mentioned. I use "omniflex" on Kipling/queensway in toronto.
    Fiesta346 likes this.
  19. Jul 15, 2016 at 11:08 AM
    tgear.shead
    tgear.shead Well-Known Member
    You can replace the entire return line with a rubber hose.
  20. Jul 27, 2016 at 10:42 AM
    Heaton830
    Heaton830 New Member
    Base 4x4
    Would the new return line from 3/8" transmission need to be the same over-all length as the original hose? Or could it just go straight from reservoir to rack?
