Alpine vs kicker vs j.l audio
Discussion in 'Audio & Video' started by mmcarbo, Nov 4, 2015.
  1. Nov 4, 2015 at 6:59 PM
    mmcarbo
    mmcarbo [OP] Well-Known Member
    Massachusetts
    I'm looking into improving the sound in my 2015 DCLB. Looking at Alpine sps610c, kicker 40css674, and j.l audio tr650csi. I hope to keep the OEM radio. I may add a compact alpine amp into the mix. Which speakers will give me the most complete sound? I will not be installing a sub.
  2. Nov 5, 2015 at 5:57 AM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    I had the JL TR650 components in mine for a while on the stock deck. It made a difference and they sounded great. Excellent speakers for the money
  3. Nov 5, 2015 at 6:24 AM
    mmcarbo
    Massachusetts
    How was the bass compared to the factory speakers?
  4. Nov 5, 2015 at 6:26 AM
    timothom
    There was a tiny bit more bass, but nothing I could really write home about. The stock deck is de-tuned quite a bit to not drive the speakers very hard with bass. The highs and mids definatly sounded better than stock speakers and tweets.
    But if you want bass your going to have to change the deck out at least.
  5. Nov 5, 2015 at 6:30 AM
    mmcarbo
    Massachusetts
    Not really looking for more bass, just cleaner low end and warmer highs.
  6. Nov 5, 2015 at 6:31 AM
    mmcarbo
    Massachusetts
    I was thinking of the compact Alpine amp to help power the speakers too.
  7. Nov 5, 2015 at 7:37 AM
    SlowComa666
    SlowComa666 Well-Known Member
    San Antonio TX
    2014 SR5 Access Cab 2WD
    please stop saying this. it is not true in the slightest unless you have the JBL system
  8. Nov 6, 2015 at 1:54 AM
    mmcarbo
    Massachusetts
    I really want to keep the head unit if possible. I've never installed aftermarket speakers in a car before, so this is a first for me. Usually, first thing is to ditch the radio... Not this time.
  9. Nov 6, 2015 at 6:12 AM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    If you want your speakers to come alive, Toss an amp on them. Furthermore, Toss some deadener on the doors at the very least.
  10. Nov 6, 2015 at 6:05 PM
    mmcarbo
    Massachusetts
    Does the factory radio have enough power to run a new set of speakers or will I need an amp immediately?
  11. Nov 7, 2015 at 7:32 AM
    SlowComa666
    San Antonio TX
    factory radio has enough power. just don't expect to have clear music with the windows down doing 85mph
    i get well over 100db average with the factory deck.
  12. Nov 7, 2015 at 7:59 AM
    SlowComa666
    San Antonio TX
  13. Nov 9, 2015 at 7:25 AM
    EricU
    EricU Well-Known Member
    Englewood, CO
    im running factory touch screen headunit, JL 5 channel amp, all of the high side channels to the front doors, polk audio 6.5 component set and the same dayton rs75-4 3" that slowcoma666 is running.
    the 6.5 woofer is bandpassed off the amp 90hz-(500-700hz) range and the dayton 3" and polk tweeter are ran off the polk passive crossover. the fronts are highpassed around 500-700hz so the dayton only sees 500-700hz up to 4000hz and then the tweeter takes over to 23k hz.
    and then i have 2 8" woofers tossed behind the front seats on the floor.
    would i love to have an aftermarket headunit, sure, do i plan to get one any time soon? not at all.
    I also ran an Alpine Power Pack to the factory speakers and replaced the factory tweeter with the dayton 3" at a 600hz inline filter and it sounded great with just throwing a bit more power to the stock speakers, add some deadening to the doors, and you will get back some mid bass im sure.
  14. Nov 9, 2015 at 7:47 AM
    Rus TRD
    Rus TRD Well-Known Member
    Don
    Pa.
    2015 DC TRD Sport
    Bilstein 5100 with 884 Springs. Full audio system. Stealth 6 Wheels. Cali led light.
    That's what I would do. Amp and sub. Leave factory head unit and speaker in.
  15. Nov 9, 2015 at 7:48 AM
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    Add a survey?
  16. Nov 9, 2015 at 3:08 PM
    mmcarbo
    Massachusetts
    I ordered the Alpine compact amp. I'll post after I install it. Now I'm looking into replacement front speakers...
  17. Nov 14, 2015 at 3:32 AM
    mmcarbo
    Massachusetts
    Installed the Alpine amp yesterday using OEM speakers for now. Massive improvement in bass output and clarity. The Alpine highlights the shortcomings of the factory speakers. Biggest issue for me was the mass of wiring behind the radio. PITA to fit the radio back in the dash.
  18. Nov 14, 2015 at 4:39 AM
    Ravenfan
    Ravenfan Well-Known Member
    Virginia
    15 TRD Sport DCLB
    5100 Bilsteins, 884x, 1 1/2inch Rear block, Toyo Open Country AT2 LT265/75/16 C
    Did you install the amp in dash with radio?
  19. Nov 14, 2015 at 5:07 AM
    mmcarbo
    Massachusetts
    I mounted the amp under the console. I used the metra wiring adapters so I didn't have to alter the factory harness. I only had to add a wire for the illumination circuit.
  20. Nov 14, 2015 at 5:30 AM
    RedRed
    RedRed TACO TUESDAY!!!
    Red
    Lake Norman NC
    15 taco with stuff & things
    1.75" Billy's plus 1/4 spacer on both sides. 1" block in rear. 265/70/17 nitto g2 SCS matte dark bronze 6s
    Which amp did you add to your system? Model #?
