alpine amp mrp f250
Discussion in 'Buy / Sell / Trade' started by 81shark, Oct 4, 2010.
  1. Oct 4, 2010 at 10:58 AM
    81shark
    81shark [OP] Well-Known Member
    Edit... SOLD!!!!
    Good solid working amp. Its been in my truck two years and as you can see, still is.
    i don't have the end caps on, but they will come with. it also comes with the orginal box and instructions.
    Details:
    • 4-channel car amplifier
    • 40 watts RMS x 4 at 4 ohms (50 watts RMS x 4 at 2 ohms)
    • 100 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
    • 2-, 3-, or 4-channel output
    • variable high-pass/low-pass filters (50-400 Hz, 12 dB/octave)
    • tuned Bass EQ (12 dB bass boost at 50 Hz for channels 3 & 4)
    • subsonic filter (15 Hz, channels 3 & 4 only)
    • MOSFET power supply<LI sizset="176" sizcache="30">CEA-2006 compliant
    • STAR Topology (minimizes internal noise and prevents ground interference)
    • speaker- and preamp-level inputs
    • preamp outputs
    • gold-plated screw terminals
    • fuse rating: 15A x 2
    • 8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
    • 11-1/4"W x 2-3/8"H x 9-9/16"D
    Looking for $75 shipped to lower 48. Would be willing to trade if you have something interesting.
  2. Oct 5, 2010 at 6:44 AM
    81shark
    buy it today, have it tommorrow.....if you live close enough
  3. Oct 5, 2010 at 10:40 AM
    adhumston
    adhumston Well-Known Member
    Great little amp. Bridge it and it will push a solid set of components real nice. GLWS
  4. Oct 5, 2010 at 11:00 AM
    hoyta
    hoyta Well-Known Member
    Adam
    Camden,NC
    08 Rugged Trail DC
    trade a mono Kenwood for it?
  5. Oct 5, 2010 at 11:21 AM
    81shark
    thanks, but i'm upgrading to a alpine PDX 5 to avoid dual amps so no need for a mono. but if you wanna buy:)
  6. Oct 5, 2010 at 12:43 PM
    hoyta
    Adam
    Camden,NC
    08 Rugged Trail DC
    I understand that~
    If i can sell a couple things, I will let you know
  7. Oct 5, 2010 at 1:33 PM
    PkTaco
    PkTaco Well-Known Member
    David
    Zanesville Ohio
    I'm tempted to buy it just trying to figure out what head unit I want to pair it up with on a crack head budeget.
  8. Oct 6, 2010 at 6:47 AM
    81shark
    you can get a pretty decent stereo for cheap on ebay. i always suggest alpine HU's, but i'm biased.
