AlphaRex LUXX tail light fitment
Discussion in 'Lighting' started by Justin484, Dec 1, 2022.
  1. Dec 1, 2022 at 3:54 PM
    Justin484
    Justin484 [OP] Member
    2022 Tacoma TRD Sport
    I recently installed the AlphaRex LUXX taillights on my 2022 Tacoma and the fitment is off on the driver side. 66385061-0ED3-41C2-9A85-805B8158D470.jpg
    Has anyone else experienced this and found a fix?
  2. Dec 1, 2022 at 4:28 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    you sure its pressed in all the way?
  3. Dec 1, 2022 at 4:42 PM
    Justin484
    It’s in all way.
  4. Dec 2, 2022 at 5:07 AM
    Tacospike
    Two Trucks
    Pull it out again, make sure no wiring is obstructing anything and try again
  5. Dec 2, 2022 at 6:02 AM
    Justin484
    There isn’t any wiring in the way, I’ve checked that multiple times. I’m going to pull it off this weekend and see what I can do. It’s driving me nuts haha
    Tacospike[QUOTED] likes this.
  6. Dec 2, 2022 at 6:17 AM
    Hunter1923
    Hunter1923 New Member
    Hunter
    2022 Toyota Tacoma TRD Sport
    I have the same issue with both tail lights, I have contacted them to see what can be done about it because they should fit flush I feel like. Don't want water and snow to get in the gaps and ruin them
  7. Dec 2, 2022 at 6:24 AM
    Justin484
    That’s kind of my feelings. I mean I know they aren’t waterproof by any means but I feel like that giant gap is gonna allow too much in there. Plus the look of it drives me crazy!
  8. Dec 2, 2022 at 6:57 AM
    Hunter1923
    Hunter
    Alpharex website states that no matter who you ordered the lights through if they are new within 30 days you can exchange them if you aren't satisfied or there is an issue, I just emailed them to get an exchange set up because I'm not going to risk them getting ruined
  9. Dec 2, 2022 at 7:17 AM
    Justin484
    I ordered mine from Tacoma Lifestyle on November 12 so I think maybe I should do the same. Can you give me the info you got from them please?
  10. Dec 2, 2022 at 7:27 AM
    Hunter1923
    Hunter
  11. Dec 2, 2022 at 8:01 AM
    Justin484
  12. Dec 2, 2022 at 9:22 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    What? The backside of the tail light cavity is completely open to the ground. That's like saying your headlights will be ruined because there's a gap between the hood and fender...
    TacoPandaTRD and HondaGM like this.
  13. Dec 2, 2022 at 12:09 PM
    Justin484
  14. Dec 2, 2022 at 12:13 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Mine did that after i pulled the taillights to connect my bed lights...the metal part where the push pin clips goes in got pulled out /bent ...take the light out and push it in being careful not to bend the bedside... if i remember right there was a metal one on top and a plastic clip on the bottom....the metal is so thin it bends the tabs when removing....i wouldnt sleep or eat till that was fixed
  15. Dec 7, 2022 at 2:31 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    ya'll bend them tabs yet:popcorn:
  16. May 31, 2023 at 11:34 AM
    eric818
    eric818 Well-Known Member
    Eric
    2023 tacoma trd off road
    dude mine are the same.. I have a 23 tacoma.. I got the luxx tailights
    driver side bottom clip isn't being clipped in all the way... passenger side is perfect.
    I went to Toyota and purchased brand new clip housings where the twilight clips into.. and still the same shit.. must be a defect from Alpharex
    I contacted alpharex today and so far I have sent them photos. I am waitigin on a response. I expect a replacement product
  17. May 31, 2023 at 11:43 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^Welcome to the world of aftermarket lights. Alpharex's plastic molds are probably off a bit, due to inaccuracies in the reverse-engineering process, so every LH tail light they produce will be the same.
  18. May 31, 2023 at 11:48 AM
    eric818
    Eric
    70724846898__5B729D26-58A0-4BB1-BFC1-8ED97BF61B6E.jpg 70724848714__FE3C9611-9495-4CF7-975C-E361F648D293.jpg
    so it’s normal?
    these aftermarket taillights r not cheap. They should be built to oem spec as far as fitment goes
    it’s weird. Driver side has a gap. Passenger side has no gap at all. I’m starting to think maybe the side that has no gap is the bad side lol
  19. May 31, 2023 at 12:07 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^They did their best with the reverse-engineering lol. If you want to keep the Alpharex tail lights because you like the styling, best thing to do would be to bend the tabs in the bedside sheetmetal to pull the LH tail light inward a bit.
  20. May 31, 2023 at 1:54 PM
    eric818
    Eric
    I was thinking of that.. I just did not want to break anything..
    maybe when pulling the OEM tail light off, it got bend outwards..but I remember playing with it and its pretty stiff.. its not that easily bent.
