Almost hate to ask- OEM wheels
Discussion in '1st Gen. Tacomas (1995-2004)' started by BradleyS, Sep 16, 2020.
  1. Sep 16, 2020 at 8:07 PM
    BradleyS
    BradleyS [OP] Well-Known Member
    Bradley
    03 Toyota Tacoma TRD
    None, yet.
    I almost hate to ask, this is new to me stuff.
    OEM wheels- both 16"- one with Bolt Pattern of 140mm, the other 139.7mm. This isn't a deal breaker, right? The .3mm diff.
  2. Sep 16, 2020 at 8:14 PM
    Bishop84
    Bishop84 Well-Known Member
    It's rounded, its actually 6 x 5.5 inches. For some reason the only imperial on a car world wide is wheels.
  3. Sep 16, 2020 at 8:19 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    y'know, I never really thought about it. You're right.
    Tires and wheels.
    BradleyS[OP] likes this.
  4. Sep 17, 2020 at 7:55 AM
    BradleyS
    Bradley
    None, yet.
    Do you think swapping will work? Both 16" wheels. A friend in the know says 'you need the 6-139.7mm bolt pattern, and the '05-'20's should be that', but I found a listing for one (the wheels I'm looking to swap) and they say 6-140mm.
  5. Sep 17, 2020 at 7:58 AM
    BradleyS
    Bradley
    None, yet.
    This is what my buddy says-"
    Not sure about 6-140
    I'm thinking you will need to make sure they're the 6-139.7 bolt pattern(also referred to as just a 6-139 or 6x5.5)
    but any 6 lug OE wheel off a '95 through 2020 Taco will have the same 6-139.7 bolt pattern"
  6. Sep 17, 2020 at 8:22 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Are they Toyota wheels you are referring to?
    Your friend "in the know" may not realize that ALL Toyota 6 lug truck wheels have the same bolt pattern; 6 on 5.5. My 86 4Runner had this bolt pattern. They have other differences, like backspacing/offset. The 2nd/3rd gen wheels have smaller backspacing, which puts the wheel closer to the frame which can cause fitment issues with certain tires. There's a whole thread (many, actually) dedicated to 1st gen trucks with 2nd/3rd gen wheels. Search around, you'll find what people are doing to correct that (if anything).
  7. Sep 17, 2020 at 8:25 AM
    tony2018
    tony2018 Well-Known Member
    Oh man...I've looked at a couple oem wheels in the toyota line up that might look good on my 02. Old landcruiser, new 4runner trd pro, new 4runner, sequoia....etc...etc... head spinning.
    Ridgerunner and BradleyS[OP] like this.
  8. Sep 17, 2020 at 8:44 AM
    BradleyS
    Bradley
    None, yet.
    I hear you, I think if I spend enough time, I'll figure it out. Good luck!
  9. Sep 17, 2020 at 8:49 AM
    BradleyS
    Bradley
    None, yet.
    Yes Toyota wheels. I hear you about the other factors. The ones I have now have 15mm offset, looking at some with ('06) w/30mm offset, and ('19) w/25mm offset. I can get the 19's for not much more cash. Thinking I might go with them if it works out. They list the same 6-139.7mm bolt pattern, the 06's list 140mm, I'm not sure about compatability w/those. Though it appears manufacturers are rounding up the 139.7's to 140's I've been told. I don't want to have to use wheel-spacers. Thank you.
    jbrandt[QUOTED] likes this.
  10. Sep 17, 2020 at 9:16 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    any Toyota/Lexus 6-lug(bolt) wheel should fit on your truck. The pattern is the same and no clue why people would put 140mm (I have not seen this myself so :notsure:). Ford/GM/Nissan also have 6x 139.7mm (6 x 5.5) but different center bore size.
    Even with the Tundra Brake Upgrade you can fit any 01+ alloy wheel (steel is a little different). Where you run into issues with the 05+ is when you upgrade tire size. stock size is fine but when you put wider tires on you introduce rubbing due to the backspacing difference
    Hamer95USA likes this.
