alluminum versus polyurethane
Discussion in '1st Gen. Tacomas (1995-2004)' started by mudjunkie, May 20, 2009.
  1. May 20, 2009 at 7:24 PM
    mudjunkie
    mudjunkie [OP] Well-Known Member
    clearwater fl
    96 tacoma sx l
    header,short rack and pinion, heavy duty shocks, grill guard, flowmaster exhaust,pacesetter header without catalytic converter, one 10 inch xant sub with a mtx amp, off road lights,diamondplate tool box,rhinolined inside cab,ngk plugwires.
    looking into a spacer lift for the truck, dont know which to get a polyurethane or an alluninum spacer. doing about 3 inches
  2. May 20, 2009 at 7:26 PM
    mudjunkie
    clearwater fl
    96 tacoma sx l
    oh and the alluminum is the block that goes above to coil and shock assembly
  3. May 20, 2009 at 7:26 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    I ran an aluminum one on mine and did well, poly spacer tend to wear down and sag
  4. May 20, 2009 at 7:27 PM
    mudjunkie
    clearwater fl
    96 tacoma sx l
    did you get a bumpy ride
  5. May 20, 2009 at 7:47 PM
    TRD4x4858
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    Not really, only thing i noticed was that it swayed more than stock, other than that wasnt too bad
  6. May 20, 2009 at 7:55 PM
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    pinto
    33" mudders
    3 inches sounds like a lot for a spacer lift. why not get bilstein 5100s for like $200 and lift it 2.75 inches. :confused:
  7. May 21, 2009 at 3:51 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I'd stay away from a spacer kit that goes above the coil assembly.
  8. May 21, 2009 at 4:00 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    ^^^ +2.......but, if you insist, I have daystar spacers with your name on them, cheap cheap. PM for pics/paypal addy.
  9. May 21, 2009 at 4:28 AM
    Janster
    Jandy
    Lancaster, PA
  10. May 21, 2009 at 2:03 PM
    mudjunkie
    clearwater fl
    96 tacoma sx l
    janster why do you suggest i stay a way from the lift
  11. May 22, 2009 at 11:40 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Actually I have the same crap lift in whatever flavor you want. I never used either, went the right way with 5100s. I have the cast ones for top of strut or the poly for inside the strut. Cheap cheap for whoever wants them or I'll just tho them up in the pay it forward thread. Damn, glad I saw this again cause I was needing something to put up after I take something from there. Spacers coming soon to a free thread near you! Just pay shipping.
  12. May 22, 2009 at 11:42 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Because it extends the strut assembly length & slowly (or not) fucks your ball joints to death by making them extend beyond their normal range of movement. (if offroading much at all) If just poser mall crawler then probably no problems...I said probably.
  13. May 22, 2009 at 11:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It lengthens the shock/spring assembly, causing your balljoints to wear out, and can lead to breakage of your shocks if off roading..
  14. May 22, 2009 at 11:53 AM
    Janster
    Jandy
    Lancaster, PA
    Those guys already answered it nicely.
    As already mentioned, if you don't offroad...you're probably fine.
    Offroading causes lots of suspension travel and that's where the problems can occur.
  15. May 23, 2009 at 1:07 PM
    mudjunkie
    clearwater fl
    96 tacoma sx l
    ordered the bilsteins finally broke down once i fix my engine and figure out whats wfrong ill put them on with the new tires
  16. May 24, 2009 at 9:34 AM
    2009tacomav6
    2009tacomav6 Well-Known Member
    phx AZ
    2012 4x4
    TRD SC TRD Cat Back KMC 17x9 Addicts
    I would agree that is a lot for spacers.. one inch aluminum blocks are ok for back. even two...
  17. May 24, 2009 at 11:39 AM
    Justin723
    Justin723 Dont judge me
    Justin
    Phoenix AZ
    02 Tacoma TRD
    Performance- bored .20 over, Doug Thorely Headers, Magnaflow Exhaust, and K&N cold air intake. Exterior- Trail Gear Solid Axle Swap, ARB compressor, high pinion 4.88 with ARB locker, 4.88 TRD Locker in the rear. Interior- 2 10inch JL W1 subs, Alpine MRX-V70 amp, Alpine type R SPR 17C 6x6 speaker in the back, Focal 165 VR with crossover tweeter up front, and Weather Tech floor mats.
    I had the 2 inch aluminum spacer on my 01 tacoma and it broke the cv join blew the shock and stressed the upper ball joint.
  18. May 24, 2009 at 1:41 PM
    trailinTaco
    trailinTaco Well-Known Member
    Bel Air, MD
    2000 Tacoma SR5 TRD 3.4L 4x4
    3 inch suspension lift, 33 inch bfgoodrich mud terrain tires, toytech diff drop, Procomp alloy wheels, hella fog lights, black projector headlights with 8000k HID's, blacked out tail lights, two 12 inch subs, 20% tint, pioneer head unit and speakers
    either if you go spacer or new struts they both extend the control arms and wear the ball joints. so i dont see any problem with the spacer idea.
  19. May 24, 2009 at 1:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They dont extend the control arms. CA's are fixed in length. Top Plate spacers lengthen the shock/spring combo, thus overextending ball joints, and the shocks. Pre load spacers, or coil springs are "Captive", there for not adding length to the assembly, but rather giveing lift by changing the spring rate.
  20. May 24, 2009 at 2:20 PM
    trailinTaco
    Bel Air, MD
    but if they arent giving it lift to the assembly then how is it considered lifted
