All Warning Lights on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ceebee1111, Nov 5, 2021.
  1. Nov 5, 2021 at 8:52 AM
    ceebee1111
    ceebee1111 [OP] New Member
    2006 Toyota Tacoma quad cab
    All the warning lights are on - ABS, brake, check engine, etc. the speedometer doesn't work nor the odometer. RPM works. Everything is running fine. This happened during the "deep freeze" in February.
    I have not had any issues with the truck during this time. But when i went to get it inspected, they wouldn't pass because of the brake light being on.
    What could be the issue?
  2. Nov 5, 2021 at 8:55 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Welcome to TW.
    More info needed. Your dashboard has been a christmas tree since February?
  3. Nov 5, 2021 at 8:56 AM
    ceebee1111
  4. Nov 5, 2021 at 9:13 AM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    @ceebee1111 pull codes with scanner. Pretty sure most Auto parts store can do this for you free.
    wonder if speedo or ABS sensor broke or cable got torn. I’d check that it’s a little soft hose near brakes. Can’t remember exactly where but google should confirm. Just a guess since it’s running fine
    Rock Lobster likes this.
  5. Nov 5, 2021 at 10:10 AM
    guyfromky
    guyfromky Well-Known Member
    Definitely seems like an ABS/Speed sensor issue with ABS, brake and check engine light on, as well as speedo not working.
  6. Nov 5, 2021 at 10:10 AM
    ceebee1111
    Thanks! I'll go to AutoZone tomorrow!
  7. Nov 5, 2021 at 10:17 AM
    GreenTaco412
    GreenTaco412 Well-Known Member
    Jim
    Pittsburgh
    2021 Army Green Trail
    Is you mileage still going up or has it stopped because the speedo is not functioning? I know a guy here in PA got his CARFAX dinged for some odometer tampering or something like that. I hope this doesn't happen with you. Good luck finding a solution.
