All turn signals stopped working
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SpriggitySprat, Sep 25, 2021.
  1. Sep 25, 2021 at 2:04 PM
    SpriggitySprat
    SpriggitySprat [OP] Well-Known Member
    Ohio
    2017 SR 2.7 4x4 AC Bearded Package
    Window tint (15% sides, 5% rear) Bull bar Bed mat (modified horse stall mat) 265/75 Falken Wildpeaks Hondo Garage radio knobs Better Built slimline toolbox LED replacements for interiors, reverse, and license plate Derped the stock steelies Tinted tail lights and third brake light Faux Pro Grille "Raptor Style" Lights 20" behind grill light bar 2" wheel spacers Cup holders and bottle opener in bed rail Custom bedside stickers and tailgate letters (CBoy808)
    Okay I have been searching google for a while now and can’t figure this out. Hoping for some help. I have a 2017 SR Utility. Stock bulbs all around externally. The only modification to my lighting is the three grill lights that I wired into my drivers side running light so they come on when I turn my DRL on. I have had occasional issues with a turn signal flashing quickly but it went away (happened to both left and right but the other lights always worked). I got in my truck yesterday and all turn signals are not working (front, rear, both sides). All other lights are operational. When I turn on my signal at the stalk I get a fast flash on the dash but no lights on the exterior. When I turn on my hazards I get a normal flash on the dash but no lights on the exterior. From what I’ve seen this model does not have an independent flasher relay (this was my first guess at the issue). Has anyone else dealt with this or found a solution? I’d prefer to fix it myself if I can, I’m fairly mechanically inclined and don’t mind digging into issues but I’m no electrical guru. I saw one thread of someone wiring in a 2nd gen flasher into the all-in-one unit behind the dash but I don’t know if that’s the fix or not. I’d appreciate any sort of insight as to where to begin. Thanks!
  2. Sep 25, 2021 at 2:08 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Check fuses. maybe disconnect the grille lights you installed.
    caribe makaira likes this.
  3. Sep 25, 2021 at 2:36 PM
    ernscott
    ernscott Well-Known Member
    2021 Tacoma
    Hi Maybe start by pulling a bulb and checking for juice. Very odd for all the bulbs to go out but for me - that would be a start point. Also check the ground.
  4. Sep 25, 2021 at 2:40 PM
    caribe makaira
    Caribbean, Puerto Rico
    Each lamp on the turn signal circuit has it's own ground. No function means no juice. If 15A HAZ fuse is gone you wouldn't get an indication in the dash.
    I fear the turn signal module is a crispy one.
    rangers12 likes this.
  5. Sep 25, 2021 at 2:56 PM
    caribe makaira
  6. Sep 25, 2021 at 3:42 PM
    SpriggitySprat
    Ohio
    Thank you for this. I will check there and start working to see what I can figure out. Just hoping to not have to take it into a stealership.
  7. Sep 25, 2021 at 3:43 PM
    SpriggitySprat
    Ohio
    I also thought it was weird that they all went out at the same time. It’s why it got me thinking of a flasher relay or some other component issue outside of a bulb issue.
  8. Sep 25, 2021 at 4:08 PM
    ernscott
    2021 Tacoma
    I always go to the end of the run and check my + & -. Then I work back. I'm for sure no expert, but it has helped me many times. We all have our own starting points when it comes to electrical issues. These guys will steer you right. Hang in there and the answer will appear. Regards Scott
  9. Sep 25, 2021 at 4:17 PM
    caribe makaira
    Verify intermittent power when HAZARDS is selected...
  10. Jun 29, 2022 at 4:03 AM
    madman57
    madman57 Member
    Rick
    Kingsport TN
    2021 Tacoma SR Barcelona Red Metallic
    Did you ever get this problem solved I am putting my truck in the shop because I’ve tried everything
