All-Pro Apex bolt on sliders
Discussion in 'Armor' started by crashnburn80, Sep 11, 2016.
  1. Sep 11, 2016 at 9:46 PM
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    As far as bolt-on sliders go, writeups are not very complicated. When looking for sliders for my truck, my requirements were:
    -Fits close to the body
    -Bolt on
    -Made of high strength DOM
    -Full top plate
    -Kickout
    -As light as possible meeting the above requirements
    Finished product:
    For me sliders are more of an insurance policy. I don't wheel hard enough to use them regularly but do put my self in positions where they would be a good safety net. More importantly they will allow me to tackle runs I might otherwise shy away from.
    Why Apex:
    Everything in my build needs to be clean enough and so well executed it looks like it could have come from the factory. This means the sliders must fit high and exceptionally tight, which also adds functional ground clearance. While armor should be strong, I also care about driving dynamics and want to add as little weight to the vehicle as possible. For a given weight, DOM is significantly stronger and more durable than HREW tubing, and because I believe in buying superior quality once, DOM is the only option.
    If you did not know, there are two types of tubing sliders are made from, DOM (drawn over mandrel) tube or HREW (hot roll electric weld). HREW has a seam, is noticeably weaker and is a fair amount cheaper and is the inferior product. It is actually very surprising how many use the lower quality material for such a critical impact component. If you are in the slider market, be sure to ask, is it DOM? Apex were the lightest bolt-on DOM sliders I found at 140lbs for the pair.
    While the full top plates add undesirable weight (20lbs in this case), I think they make sliders look far more finished and factory like rather than some off road bolt-on. Plus the fill plates protect the side of the truck from any debris spray from the tires and give my 3 year old a solid safe step up into the cab. Worth the weight penalty IMO.
    I personally like kickouts, if you are in a situation where you are using the slider they would be welcomed assistance. Plus they will protect the truck from door dings in the parking lot 100% better. What I like in the All-Pro design is the seamless mandrel bend into the kickout. Some lesser designs have a weld point and a hard angle transition to the kickout. Not ideal.
    I was in no way interested in welding my frame. I liked the design that wraps the full length of the frame slider mount to tie all the slider supports together, unlike many designs that leave the front support floating on its own.
    Apex sliders product page: Install:
    Many places will not powder coat and ship due to powedercoat damage in transit. I got my sliders raw, and had them powdercoated locally.
    How they arrived. To my surprise, All-Pro shipped the 140lb sliders next day air.
    Back from the powdercoater:
    These sliders do require some drilling to the frame. If that is scary to you, Mobtown offers some nice true 100% bolt on DOM sliders, but they do weigh noticeably more.
    A motorcycle or ATV platform jack makes life much easier for the install. I used a 1x4 on the back side to get the angle correct for proper mounting alignment, since the sliders are angled upward for clearance. With a motorcycle jack, this could be a one man job, but I highly recommend having two.
    Not thinking anything of it, I started on the driver side. The driver side has the brake lines and fuel tank in the way. All workable though you will likely have to drop the gas tank skid, but it would be easier to start on the passenger side which has more room and no complications.
    The All-Pro design uses a series of bolts with nuts and locking washers, countersunk bolts and locking nuts, and threaded backing plates for the install. The backing plates ship in raw steel, so I sprayed them with many coats of Rustoleum, and then to be safe coated everything in fluid film. Installation will require you to get intimate with your frame. Elbow deep.
    While torquing the bolts with the backing plate to the specified 44 ft/lbs with my Craftsman torque wrench, I had a plate strip out. I PM'd Tracy at All-Pro and she had one in the mail the same day. (Though I haven't received it yet).
    There are 4 lower bolt holes that need to be drilled, and one rear horizontal hole that will require a 90 degree drill bit. Drilling these lower holes was the worse part, as with the truck on the ground there is not any room to get any leverage on the drill. I am not afraid to drill my truck, but like every Tacoma owner, I am hyper paranoid on frame rust. Each hole got about a dozen coats of Rustoleum, both hand painted and sprayed from the top and bottom of the hole. In addition I purchased powdercoat touch up from my powdercoater. The stuff has more warnings on the can than product info, and also smelled like they were probably appropriate. Hit it with that too. Then to be extra safe I hit all the holes with fluid film before installing the bolts. The countersunk hardware provides a nice smooth underside to the slider.
    While the sliders fit impressively well, the rear most bolt which requires a 90 degree drill bit had a gap between the slider and the frame, where the frame appeared to bend inward and the slider did not. The same on both sides.
    The gap would possibly close with wrenching down the bolt, but these sliders are pretty overkill for my needs, so I'll likely just leave it as is for now.
    All-Pros instructions mention possible grinding of the pinch weld for clearance, which they specify as needing 1/4". I did not have to do that as mine cleared, perfectly.
    Mounted:
  2. Sep 11, 2016 at 9:48 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Great setup :thumbsup: Also my favorite rims from Toyota :thumbsup:
    crashnburn80[OP] likes this.
  3. Sep 12, 2016 at 7:51 AM
    wedgemoose
    wedgemoose Well-Known Member
    Wedge
    Worcester,MA
    2014 TRD Sport
    Beautiful !!!!!!!! Nice job as always. Your truck is awesome(and getting better each Mod)
    Lord Helmet and crashnburn80[OP] like this.
  4. Sep 12, 2016 at 8:00 AM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
  5. Sep 12, 2016 at 11:28 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Thanks! I'm pretty happy with they way it turned out. :)
    BR Pipke, Lord Helmet and ODNAREM like this.
  6. Sep 15, 2016 at 12:01 PM
    allpro
    allpro Well-Known Member
    Montana
    All Kinds Of Toyotas!!!
    Great write up! That small gap will suck up when the bolt is added or you can smack it with a plastic deadblow hammer and it will follow the contour of the frame. :cheers:
    TacoPandaTRD likes this.
  7. Sep 15, 2016 at 12:12 PM
    BDub
    BDub Well-Known Member
    Brandon
    Byrnes Mill, MO
    2015 DCSB Off-Road
    I had the same issue on my 2015. I couldn't get it to suck the gap at all. Ended up placing some grade 8 washers and a new longer grade 8 bolt to fill the gap and create a tight fit.
    Other than that, love my sliders.
    BR Pipke likes this.
  8. Sep 15, 2016 at 3:35 PM
    ChrisSandstorm
    ChrisSandstorm Well-Known Member
    '01 Land Cruiser, '16 TRD OR DCSB
    Great write up, Jon makes top notch stuff!
  9. Sep 16, 2016 at 8:35 AM
    quis23
    quis23 Well-Known Member
    Duan
    good ole' Manassas VA
    Good idea using the wood on the jack! Wish I would have thought of that during my install.
  10. Sep 18, 2016 at 10:54 PM
    Tombiology70
    Tombiology70 Well-Known Member
    San Diego
    2008 4Runner V8 Limited (Formerly 2017 Tacoma)
    Finished installing my sliders this weekend and if you ever get around to it the last bolt sucked the gap up to the frame pretty easily:thumbsup:
  11. Sep 19, 2016 at 3:39 PM
    Stakoner
    Stakoner Well-Known Member
    Santa Cruz ca
    2013 Dcab 4x4
    Alot
    Install sucks on those but they do the job and look good to!
  12. Nov 21, 2016 at 1:56 PM
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    Great write-up, ordered mine today.
  13. Feb 7, 2017 at 8:22 PM
    Evel Taco
    Evel Taco Well-Known Member
    Scott
    2017 Tacoma OR 4x4 MGM
    What color did you powder coat ? Those look great on the MGM color.
  14. Feb 7, 2017 at 8:33 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Thanks, I had them powder coated at: http://www.thermotechcoatings.com in their standard flat black. I got a spray can of color matched touch up for them, labeled as color A-4100-BK147 Black Flat.
  15. Feb 7, 2017 at 8:37 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Your truck is absolutely gorgeous
  16. Feb 7, 2017 at 8:37 PM
    Evel Taco
    Scott
    Flat black.. Looks good. Thanks for the info.
    nkn
  17. Feb 7, 2017 at 8:50 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Thank you.
    Maybe I'm getting old, but I had to google that one. :)
  18. Feb 7, 2017 at 9:02 PM
    Evel Taco
    Scott
    Fat fingered it.. Sorry
  19. Feb 15, 2017 at 6:49 PM
    airfish
    airfish Well-Known Member
    Got mine after seeing this, thx
  20. Nov 10, 2017 at 7:35 AM
    retrogamez
    retrogamez Member
    I really like these as they appear to be the most complete and cleanest looking set of sliders on the market. But shipping to Texas is a killer. I was quoted $275 for shipping. That's the only thing that has kept me from pulling the trigger. Great install and thanks for taking the time to do a write up.
