All metal bed rails (like on the Nissan Frontier)?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mobgma, Dec 19, 2015.
  1. Dec 19, 2015 at 5:26 PM
    mobgma
    mobgma [OP] Well-Known Member
    Edmonton, AB, Canada
    2016 Toyota Tacoma TRD Double Cab Long Box
    Evening
    I tried searching the site and was not able to come up with anything. Has anyone replaced (not strengthened or reinforced) the bed rails/ rail system with an all metal system like what is in the Nissan Frontier truck?
    Any companies at custom fab people that offer something like this. The plastic ones flex so much and I just can't get over it. I have a hard time trust them securing any real weight.
    Thanks
  2. Dec 19, 2015 at 6:49 PM
    mobgma
    Thanks doording. all I could find in the search was people reinforcing them.
    EDIT: those are not what I am after I think. I want the sliding pieces to be metal.
  3. Dec 21, 2015 at 8:50 AM
    mobgma
    Well that sucks.
  4. Dec 21, 2015 at 9:10 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I have Tundra cleats on my rails. They are all metal.
  5. Dec 21, 2015 at 9:42 AM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
  6. Dec 21, 2015 at 11:32 AM
    mobgma
    Thanks for the hat tip! Those just do not look sturdy enough(as additional tie down points) to tie down a quad or dirt bike. Mainly I am after additional tie down points higher up on the bed (not the bed floor) to secure my motorcycle.
  7. Dec 21, 2015 at 11:37 AM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    Then the corner reinforcements are probably what you need. They tie the side and front rails together and provide a tie down point suitable for motorbikes.
  8. Dec 21, 2015 at 11:41 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    And why are the stock mounts insufficient? I haul my track bike in there all the time and tie off to them no problem. My track bike is 430 lbs. I use big ratchet straps on them, they work pisser for tying down a bike. I use all 4 of the sliding stock mounts.
  9. Dec 21, 2015 at 11:49 AM
    mobgma
    800 lb bike. I am aware the stock 4 corner ones are sufficient. Was mainly concerned about additional tie down points that I can trust.
  10. Dec 21, 2015 at 11:53 AM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
  11. Dec 21, 2015 at 11:55 AM
    jethro
    Geoff
    Southern NH
    I'm saying I don't think you have to worry about using the metal rails. I use the corner mounts for the main job of holding the bike. I strap the forward frame to each of the corner bed mounts and ratchet strap the shit out of them, compressing my front shocks quite a bit. Bike isn't going anywhere at that point. Then I use the side rails to tie down to with the stock eye rings. They won't hold the entire bike, but for just holding side to side they will do the job. Even on a big, heavy bike.
  12. Dec 21, 2015 at 12:14 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
  13. Dec 21, 2015 at 1:54 PM
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    I wouldn't trust the Toyota sliding cleats to hold a bike. My dads 11' doesn't have tie dowwns dow in the front of the bed, just the moveable v cleats. We loaded his motorcycle in the bed and used the cleats (all 4) to hold the bike. 1 of them snapped and the bike fell over denting the tank on the bed rail. My 13' has the cleats, but also mounts doen in the bed that I like.
  14. Dec 21, 2015 at 2:11 PM
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
  15. Dec 21, 2015 at 4:23 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    They are rated 200# each if you are breaking them you got too much weight in the bed any way.
  16. Dec 21, 2015 at 4:25 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    If you really want ugly and strong replace them with uni strut.
  17. Dec 21, 2015 at 4:42 PM
    Phoosa
    Phoosa I never saw nothing.
    Truck
    I have a set of metal rails from a long bed Titan that need a new home.
