All Ground Point Locations?
Discussion in '1st Gen. Tacomas (1995-2004)' started by YotaGangYotaGang, Jul 2, 2021.
  1. Jul 2, 2021 at 10:24 PM
    YotaGangYotaGang
    YotaGangYotaGang [OP] PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    97 auto reg cab 4x4 3rz
    Can anyone let me know the ground points on these trucks? Having a start issue and a random ‘cut out’ on idle. Vehicle does have a Viper alarm system when I bought it, truck would lock the doors when I turned it off, still had rough idle, I cut the power wires to the doors and still idles rough. Gonna completly remove that alarm. Thx.
  2. Jul 2, 2021 at 10:29 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    For an 01, but should be close. Grounds are triangles.
    YotaGangYotaGang[OP] likes this.
  3. Jul 2, 2021 at 10:32 PM
    YotaGangYotaGang
    Covina
    what does Id and ie, ih stand for?
  4. Jul 2, 2021 at 10:33 PM
    YotaGangYotaGang
    Covina
    ima take a pic of my engine bay and see if im missing some, would that be strange if some were missing
  5. Jul 2, 2021 at 10:34 PM
    0xDEADBEEF
    Thats a designator that shows up in wiring diagrams, makes it easier to trace out whole circuits.
  6. Jul 2, 2021 at 10:35 PM
    0xDEADBEEF
    What do you mean by cutting out at idle? Could be other things than wiring.
  7. Jul 3, 2021 at 1:41 AM
    YotaGangYotaGang
    Covina
    like for a split second wants to cut out
  8. Jul 3, 2021 at 10:38 AM
    YotaGangYotaGang
    Covina
    Yall see anything missing452958D2-7E48-4698-9157-1F28DE68B828.jpg 12F9E4D1-FD9C-4190-B2EA-48D04E9531EA.jpg
  9. Jul 3, 2021 at 10:40 AM
    YotaGangYotaGang
    Covina
    This one is barely hanging on, idk what its for.
    10BFE6B9-AF27-4C9F-B5A0-7C5F5EA1F1D7.jpg FD9499D5-7AB9-46DC-962A-9CC3F8A94A5C.jpg
  10. Jul 7, 2021 at 12:53 AM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    That goes to the negative terminal on the battery.
  11. Jul 7, 2021 at 1:33 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    That's the main body ground. I've seen weird issues happen if that was corroded/broken but none had to do with drivability.
  12. Jul 7, 2021 at 3:23 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    That is not the correct type of cable for the body ground .
    I wonder how many more are wrong.
    Any idea what the red wire off the Positive terminal is for??
    Is your truck causes any Codes to trip?
    Start issue Failure to Crank or failure to start?
  13. Jul 7, 2021 at 4:41 PM
    YotaGangYotaGang
    Covina
    red is for camper shell light
    no starts up, no codes
