all cylinders throwing misfire code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by alaskasmitty, Jun 14, 2023.
  1. Jun 14, 2023 at 8:33 PM
    alaskasmitty
    alaskasmitty [OP] Member
    09 Tacoma 4.0. When cold starts fine and runs for about 5-10 min. then dies. When trying to restart it runs for couple seconds then dies. It throws 6 codes for all cylinders misfiring. Clear the codes, start it runs for 2 seconds, dies and throws 6 different codes for each cylinder misfiring. Wait for an hour, it starts up plenty of power the dies after 5 to 10 minutes. I changed fuel pump thinking was a fuel issue. no difference. Any thoughts?
  2. Jun 14, 2023 at 8:36 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    What codes are you getting? Is the engine stock? Whats the mileage?
  3. Jun 14, 2023 at 8:37 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    I don't suppose you have pulled the sparkplugs and coils to take a gander?
    That being said with all 6 acting up it would seem like either a fuel or timing issue to me.
  4. Jun 14, 2023 at 8:43 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You're going to need some tools like a spark tester, fuel pressure gauge and a pocket scan tool that will show basic data
  5. Jun 14, 2023 at 9:19 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Is it setting P030x codes or P035x codes?
    TnShooter likes this.
  6. Jun 15, 2023 at 12:40 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    When was the last time plugs were changed? What plugs are in it?
  7. Jun 15, 2023 at 9:48 AM
    alaskasmitty
    Codes are 0351,0352,0353,0354,0355, 0356. the truck is 09, but only has 60,000 mi on it. I didn't look at plugs yet. The darn thing runs so good when cold. goes right to 50 mph with no hesitation or miss. I will look at plugs, but I'm thinking maybe crank position sensor?
  8. Jun 15, 2023 at 9:51 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Do you get a flashing check engine light at a certain RPM?
  9. Jun 15, 2023 at 10:00 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Those are IGF codes.
    What that means is the ECU is not getting confirmation that ignition has taken place.
    We (me and another member) have been here before.
    Let me see if I can find the thread. It would be beneficial for you to read it.
    That way you understand what we are talking about when we try to help you with this issue.
  10. Jun 15, 2023 at 10:05 AM
    TnShooter
    Deogee
    STOCK
    Torspd likes this.
  11. Jun 15, 2023 at 10:05 AM
    alaskasmitty
    According to the owner (my wife's grandfather) everything is stock. Has never done anything to truck besides oil changes and filters. it doesn't have an inline fuel filter(only in tank). Can a bad coil cause all coils to fail?⁷
  12. Jun 15, 2023 at 10:07 AM
    TnShooter
    Deogee
    STOCK
    Possibly, but not likely.
    If a coil is shorting out the IGF wire, yes.
    But I doubt that’s the issue.
    You are going to need a voltage meter and/or test light.
  13. Jun 15, 2023 at 10:13 AM
    alaskasmitty
    thanks for the links to other similar situations. I will look at those
  14. Jun 15, 2023 at 10:16 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    TnShooter[QUOTED] likes this.
  15. Jun 15, 2023 at 10:20 AM
    TnShooter
    Deogee
    STOCK
    Ahh….that is going to suck.
    Toyota coils are pretty robust.
    Eventually I would have gotten to that point.
    But I would have definitely checked all the wire integrity first.
    Like you said, the worst part will be “when it’s acting up”.
    What might be hard is, checking them ALL before the truck cools down.
    the air box is in the way, so you need to have the tools ready and act fast.
  16. Jun 15, 2023 at 10:24 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Well having circuit codes for all 6 coils at the same time and a start/stall is the exact symptom of the IGF circuit being shorted, since it seems to be temperature dependent the most logical thing is a coil getting hot and shorting out.
    Not too bad to have a meter on the IGF circuit and unplug coils till the 5v comes back.
    b_r_o, SR-71A, Torspd and 1 other person like this.
  17. Jun 15, 2023 at 10:28 AM
    TnShooter
    Deogee
    STOCK
    Most of my experience with overheating coils is on lawn equipment. :rofl:
    That’s why it’s good to have guys like you around.
    To teach guys like me the “short cuts” to figuring it out.
    I would have eventually found the bad coil. But it would have taken me about 6 times.
    One truck cycle for each cylinder. And a lot of frustration.
  18. Jun 15, 2023 at 11:09 AM
    alaskasmitty
    I've worked on a lot of different Toyotas and of course, as you all know, it can be a hassle finding a good place to connect fuel pressure tester. What is your favorite spot to connect pressure tester on this 09 4.0? I've ran across situations where lack of fuel can cause misfire codes to come up. although I must admit never had all cylinders show a code. I will be checking the wiring next. Thanks TnShooter for link to troubleshooting steps.
  19. Jun 15, 2023 at 11:15 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    The spark plugs are original? How old is the battery?
  20. Jun 15, 2023 at 11:18 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    If the IGF circuit is shorted it will set codes for all 6 coils and be a start/stall because the PCM disables fuel injectors on any cylinder that sets a coil circuit code so if they all set codes all injectors are disabled.
    TnShooter and SR-71A like this.
