All 2nd gen Tacomas have a steering shake?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacomax4, Feb 23, 2019.
  1. Feb 23, 2019 at 2:53 PM
    Tacomax4
    Tacomax4 [OP] Well-Known Member
    2012 DCLB TRD Sport 4x4
    Hey everyone, just thought I’d share my experience with the steering wheel vibrations that people have so commonly been having problems with on the 2nd gen Tacoma’s. It must be something with the rack and pinion steering system, or the way that the suspensions are designed on these trucks, that allows the steering wheel to vibrate back and forth at speeds between 60-80mph no matter what tire combination, the balancing of the tires, alignment specs, or any other variable. I had a 2005 that wouldn’t quit shaking no matter what I changed in the suspension System from bushings to ball joints to wheel bearings. It frustrated me to no end. Finally, I got a 2012, with much less miles, and different wheels and tires, and it shakes the exact same way.
    So I went to the Toyota dealer and started driving their used vehicles. I drove a 2013, and 3 2014’s, all the steering wheels shook at highway speeds. I then drove a brand new 2018 Toyota 4Runner limited, which seemingly had the same steering system, and it shook at highway speeds. I then drove a 3rd gen Tacoma and it did not shake. I do live in Manitoba Canada and the roads here are kinda like donkey trails, so maybe that’s part of the reason, but it’s a little bit satisfying to know that that’s just the way that these trucks are, and that I’m not going crazy...
    Anyone with a steering wheel vibration issue, don’t be alarmed. From the factory these trucks are susceptible to it, and it’s just another quirk of these vehicles.
    EDIT: must be the roads I’m driving on...
    cleats50 and Heath75 like this.
  2. Feb 23, 2019 at 2:56 PM
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    My 2009 doesn't have a steering wheel shake.
  3. Feb 23, 2019 at 2:56 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    my 11 sport never shook and my 18 4 runner hasnt yet.
  4. Feb 23, 2019 at 3:01 PM
    clifpaul
    clifpaul Well-Known Member
    North Texas
    06 access cab 5 lug
    Too many to fit here now!
    My 06 Tacoma doesn't have a shake even after 220,000 miles.
  5. Feb 23, 2019 at 3:05 PM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    2013 4x4 access cab.
    No shaking at any speed.
    TOMB
  6. Feb 23, 2019 at 3:09 PM
    JC15Taco
    JC15Taco Well-Known Member
    Jeff
    SK, Canada
    '15 TRD DCLB
    No shake on my 2015 at speed either....
  7. Feb 23, 2019 at 3:16 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    This is the problem with talking about car problems on the internet. Literally everyone here is going to have a different threshold for what constitutes a "shake".
    I think the Tacoma has a particularly finnicky steering setup, and doing certain upgrades or mods can intensify sensations that are inherent. For example, if you switch to a "blocky" tire that has a flatter (instead of rounder) profile, then steering is going to have a noticeable "tipping point" where the camber angle related to steering feels like a shake.
    It could also all relate back to the materials used in the steering rack. Aluminum parts will weigh less, but could transmit vibrations more.. steel would be the complete opposite.
    cleats50 and Dan 77 like this.
  8. Feb 23, 2019 at 3:27 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Just mounted up some new chunky mud tires on mine. No shake
    Trouble_The_Tacoma likes this.
  9. Feb 23, 2019 at 3:30 PM
    Stryker420
    Stryker420 Well-Known Member
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    Do you have Parkinson's disease?
  10. Feb 23, 2019 at 3:32 PM
    Bebop
    Nick
    Go test drive a new Bentley continental and see if it shakes
  11. Feb 23, 2019 at 3:32 PM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    Mine only shakes when it's scared :taco:
    cedarpangolin and Stryker420 like this.
  12. Feb 23, 2019 at 3:33 PM
    Bebop
    Nick
    I thought that was only a Prius that did that
  13. Feb 23, 2019 at 3:34 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    agreed with this.
    But OP. I aint got no shake, moms 07 4 runner doesnt, nor does dads 3rd gen (2016)..... FYI all 3 of those vehicles use essentially the exact same steering and suspension components.
    12TRDTacoma and Stryker420 like this.
  14. Feb 23, 2019 at 5:30 PM
    sgage
    sgage Well-Known Member
    2007 Red Tacoma SR5
    Just another data point: 2007 reg cab, no shake.
    Stryker420 likes this.
  15. Feb 23, 2019 at 5:34 PM
    WoodsGhost
    WoodsGhost Well-Known Member
    PA
    2017 DCSB OR:2016 4Runner
    No shakes on either of mine
  16. Feb 23, 2019 at 5:39 PM
    tcjacado
    tcjacado Well-Known Member
    Mine only shook when the wheels were not properly torqued... 07 2nd gen prerunner and now 17 2wd sr5
  17. Feb 23, 2019 at 5:40 PM
    Trouble_The_Tacoma
    Trouble_The_Tacoma Well-Known Member
    Conrad
    Once my tires were balanced properly no shakes up front all the way up to 115mph.
    kfs90 and Stryker420 like this.
  18. Feb 23, 2019 at 5:40 PM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    Mine has the shake
  19. Feb 23, 2019 at 5:42 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    9 years and 4 sets of tires and my 2010 drives as smooth as a baby’s butt. I go down the interstate at 85 MPG. Are you positive your rim(s) aren’t warped?
  20. Feb 23, 2019 at 5:43 PM
    Gerard6778
    Gerard6778 Well-Known Member
    Gerard
    2015 TRD Sport
    My 2015 steering wheel doesn't shake at any speed.
