Alignment keeps going out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MammothTaco1234, Sep 29, 2020.
  1. Sep 29, 2020 at 4:19 PM
    MammothTaco1234
    MammothTaco1234 [OP] Member
    Matthew
    Miami
    2006 Toyota Tacoma 4x4 Double Cab
    31” tires 20” rims 3”/2” rear leveling kit Spyder auto headlights
    Hello, I have a 2006 Tacoma and I put 31” tires with 20” rims around May. Since then I’ve been having serious vibrations with the steering wheel and the whole car once I hit 50 mph but it goes away when I hit 70 mph. My car also steers to the right bad. I got my tires aligned last week, and I’m still having the same problem. I don’t drive on bad roads, I haven’t hit a curb hard, and the car has 150,000 miles. Please help!
  2. Sep 29, 2020 at 5:11 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    What were the before and after alignment numbers? Put the old wheels/tires on and see if it goes away. I'm betting it will, since it started when you took them off and put those other ones on. If it does, then you know it's just shitty wheels and/or tires. What kind of wheels/tires are they anyway? Are you sure they are correct size and fitment for the Tacoma hubs? I'm assuming you have inspected the wheel and hubs since installing and having problems.
    Also, you say "keeps going out" but the understanding I have is that it's been pulling/vibrating since you installed the wheels/tires and after having the alignment checked/adjusted it still has the same problem.
  3. Sep 29, 2020 at 5:20 PM
    MammothTaco1234
    Matthew
    Miami
    Not sure what the before and after numbers were. I don’t have the old wheels because they were worn down and the rims were done for. The rims are from dynamic wheel group, kind of a knock of version of American force. And the tires are form nexen. And they should be the right size cause I went to a well known wheel place called wheel world and they installed it themselves. But I’ll look into to hub and figment sizes.
  4. Sep 29, 2020 at 5:27 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    i know MANY like the 'offset ' BIG Tyre bad azz Look !!
    Ur observation the alignment keeps ................. going out
    the BIG Rubber..........OFFset....puts MORE STRESS
    MORE Leverage
    MORE friction on the front end..............on Urz & others even tho they might NOT
    have Ur issues & complaints
    at 150k miles a really Gooood front end shop is in Ur future
  5. Sep 29, 2020 at 5:29 PM
    GrundleJuice
    Michigan
    2016 TRD Bro
    Sounds like a wheel/tire quality or fitment issue. I would take it back to the installer, describe your problems and that you've had an alignment and ask them to take a look at them. I've heard of problems with nexen tires, but mostly just problems with balancing and vibration.
  6. Sep 29, 2020 at 5:36 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    its probably the Rims
  7. Sep 29, 2020 at 5:43 PM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    The pulling Could also be a tire pressure problem or even a radial pull. A good alignment tech would check the tire pressure during the alignment to make sure that’s not a problem. You can check for a radial pull by swapping the front tires side to side and see if the pull changes directions.
    As far as the vibration goes. A lower profile tire and bigger wheel will be more prone to having vibrations since there’s not as much cushion.. are the wheels the correct center bore? If not did the tire shop install hub centric rings? Or it could be as simple as excessive road force, the tech didn’t know how to balance a tire, or a wheel isn’t true. When it comes to wheels and tires you get what you pay for and I’ve seen plenty of off brand wheels be warped right out of the box.
  8. Jul 15, 2021 at 8:02 PM
    MammothTaco1234
    Matthew
    Miami
    Hello guys, just want to update everyone on what the issue finally was. It was a combination of many things. First my rack and pinion needed to be replaced, second it was a bad tire and rim figment. Didn’t know much when I got them but now I do. Third, it was also a tire pressure issue, didn’t put the correct psi (put too much) and worn down the tire the wrong way. Learned all this after getting a job at Champion 4x4. Thanks everyone!
    Naveronski likes this.
