Alignment Cam Delete - Which ones?
Discussion in 'Suspension' started by steveo27, Sep 17, 2024.
  1. Sep 17, 2024 at 10:09 PM
    steveo27
    steveo27 [OP] Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Gettin tired of the LCA cams getting bumped out of alignment so I’d like to just delete them.
    The truck has stock LCAs and SPC UCAs.
    The LCAs are pushed as far toward as possible and the caster and camber are both set with the UCAs.
    I don’t need any adjustability at the LCAs and would like to replace the factory alignment cams with a non adjustable cam.
    The factory tabs are in good shape, and I plan on reinforcing them instead of replacing them at the moment.
    There’s a buncha different kits out there on the market that all seems to be pretty comparable.
    Bison OR, Solo Motorsports, Poly Performance, KP Off-road, ect.
    What kits are you guys using? Complaints? Criticisms? Ect?
  2. Sep 19, 2024 at 3:34 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    I would replace the factory tabs as well. You're in there just do it. For tabs TC or DK. For the cam bolt eleminators tons of options which ever one you fancy. I went with the 333 Fabrication eleminators and DK tabs. Been alignment free for over a year with many trips.
  3. Sep 19, 2024 at 7:57 AM
    Tulsa Taco
    Tulsa Taco Well-Known Member
    Brennon
    Tulsa
    2020 TRD OR
    I need to look into this. It’s annoying coming off trails and finding my steering wheel is a little more crooked.
  4. Sep 19, 2024 at 8:03 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    I have KP Off Road and no complaints. I only have the bolts and cams, not the tabs installed. Those are stock and I’ve not had an issue with them bending those over. And yep, have been off roading over lots of rocks.
    drizzoh likes this.
  5. Sep 20, 2024 at 7:04 AM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    I run the 333 one's as well. If you have an adjustable UCA like SPC, Dobinson's Billet... then I think that they work pretty well. If you have non-adjustable UCA's then the octagon shaped ones would be better to dial it in right. I max the caster on the inside bolt, then do whatever setting (+- or Neutral) you need for the front bolt and then fix the camber on top with an angle finder. Range should be -.5 to +.8 per Accutune.
    I use a laser meter to do Toe and just try and toe it in a tiny bit. (1/16").
    Drives pretty good. not perfect, but close enough for me rather than getting an alignment 2+ times a year or being denied an alignment with shops bc they don't know what they are doing or try and push services on you that you don't need.
    I was denied an alignment once at rep 4x4 shop in Denver bc I had a torn outer Tie rod boot on a month old tie rod and they couldn't even offer to slip a replacement on in its place, or call me to ask what I wanted to do. Instead told me that my tie rods had play which they didn't. (All Brand New).
  6. Sep 20, 2024 at 7:54 AM
    steveo27
    Pittsburgh
    Yep.
    I fine tune the alignment at the UCA since it’s adjustable.
    Doing the alignment at home has become a piece of cake. I’m just tired of having to do it so often because no matter how tight the alignment cam hardware is, it still moves.
    I mark em with a paint pen and it’s still annoying
    JFriday1 likes this.
  7. Sep 24, 2024 at 10:19 AM
    PathFinder1776
    PathFinder1776 Well-Known Member
    Colorado Front Range
    2003 DCSB TRD OR 4WD
    TRD S/C & TRD Boost Gauge Snugtop Topper Chevy 63 Swap, Gen 1 Raptor Shocks Boxed rear frame Aluminum F/R bumpers, sliders AEM 340 Fuel Pump Odyssey 27F Battery Shifted LCAs UCAs Icon 2.5 Ext. Coilovers
    That is a total pain. And the system shouldn't be reliant on over-torqued cam bolts to maintain the position of the LCA. That's just not how bushings work, even the dumb stock ones probably don't work well over-torqued. It's better to rely on normal force than friction to locate the LCA.
    I've had the Poly Performance Tacotabs on a 2nd gen and now a 1st gen along with modified control arms. Both were able to get in spec despite the limited adjustment resolution. Since you have adjustable uppers they should work well. They're a little more work to align initially (swapping locating washers vs rotating them in place) but maxing out the caster and setting camber to the center setting is where most seem to end up. I'd also recommend welding the backs of the tabs to keep them from smashing over. That system worked great on my 2nd gen with 37s and 35s.
    steveo27[OP] likes this.
  8. Oct 11, 2024 at 11:41 AM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    KP Off-road here. Went with their whole kit, tabs and all.
  9. Jan 14, 2025 at 12:18 PM
    steveo27
    Pittsburgh
    Bumping this back up for more input
  10. Jan 21, 2025 at 6:25 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Fox and Locked suspension 63's Skinny 33's
    KPO has the best fit I have seen. Comparing this to Bison and tacotabs at least.
