Alignment after Upper & Lower Ball Joints replacement?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2001tacomaowner, Jan 13, 2019.
  1. Jan 13, 2019 at 3:01 PM
    2001tacomaowner
    2001tacomaowner [OP] Active Member
    2001 Tacoma TRD Double Cab
    Hi, i just replaced my upper and lower ball joints (both sides) this weekend. I don’t know the last time it was align from previous owner. The ball joint that was starting to go bad was upper- passenger side. After the replacement I immediately notice a good change. There’s no longer a pressure on steering to tend to go to the right. My question is, do i need an alignment after this job?
  2. Jan 13, 2019 at 4:27 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I would, yeah... especially if you noticed some differences in driving it.
    Usually, if you’re careful, and you replaced the exact same balljoints (same brand), you could get away wih not getting one.
    Area51Runner likes this.
  3. Jan 13, 2019 at 4:27 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Everyone has an opinion. Personally, I say YES - go get it aligned :thumbsup:
  4. Jan 13, 2019 at 4:29 PM
    goldentaco03
    goldentaco03 Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    Yes. Things can shift, parts can be different, plus it’s good practice to get an alignment done about once a year. Especially if you have rough roads and encounter potholes often
  5. Jan 13, 2019 at 8:10 PM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    Are their washers between the four bolts of the lower ball joint and the spindle or is that just machining?
  6. Jan 13, 2019 at 8:10 PM
    2001tacomaowner
    Okay, thanks guys for the honest answers. I’ll get it align. And the parts are all OEM. This job was made it easy because i have all kinds of tools accessible for me cause i did it at a hobby shop for $4 an hour (flat stall). Thanks guys!
  7. Jan 13, 2019 at 8:13 PM
    2001tacomaowner
    That’s just machining work, i see what you mean though i had a good stare at it when i was tightening them up
    01GreenTacoma[QUOTED] likes this.
  8. Jan 13, 2019 at 8:39 PM
    TacosConQueso
    TacosConQueso Well-Known Member
    Brian
    1999 Sierra Beige Tacoma 4x4
    Nice work OP. Not trying to derail your thread but you said you did this at a hobby shop, what kind of place is that? Ive heard of spaces like that for woodworking or crafting but never for automotive stuff, sounds pretty awesome if thats what it is.
  9. Jan 14, 2019 at 6:27 AM
    2001tacomaowner
    Yeah i know, it’s $4 for flat, $8 for lift. It’s at Camp Pendleton available for service members only. It’s a recreation thing for us run by base.
    TacosConQueso[QUOTED] likes this.
  10. Jan 14, 2019 at 6:40 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I agree with the alignment, especially since you mentioned no records of it being aligned by anyone else. Even though in most cases just replacing the ball joints has minimal effect on geometry, it can help with camber adjustments that are unnoticed and any left over steering play brought on by the worn ball joint.
    good work OP, and yeah it does look like washers but I think those are just flat bottoms on the bolts right?
  11. Jan 14, 2019 at 6:45 AM
    goldentaco03
    Liam
    NJ
    That’s what the oem lowers look like. They have these sleeve things machined into them to help with alignment of the spindle and lbj. Also looks like it reduces shearing stresses on a the bolts. Might’ve been a design change after all the failures happened
  12. Jan 14, 2019 at 7:15 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    I was thinking of the bottom side where the bolt goes in. Yeah I remember the sleeves when I changed mine on the upper side
